Comparison between two numbers
In summary, a comparison between two numbers is the process of determining the relationship between two numerical values, such as finding which number is larger, smaller, or equal to the other number. To compare two numbers using the greater than symbol, simply place the symbol (>), also known as the "greater than" operator, between the two numbers. The terms "equal to" and "equivalent" have slightly different meanings, with equal to referring to two values being exactly the same and equivalent referring to two values having the same value or meaning. The purpose of comparing two numbers is to understand their relationship and make decisions, solve problems, or analyze data. To compare two numbers using the less than or equal to symbol, place the symbol (<=),
anemone
MHB
POTW Director
3,883
115
Determine, without the help of calculator, which of the following is bigger:
\(\displaystyle 1016^{11}\cdot 3016^{31}\) versus \(\displaystyle 2016^{42}\)
Mathematics news on Phys.org
We know $3^6(= 729) > 2^9(=512)$ hence $3^{30} > 2^{45}$
Or $3^{31} > 3 * 2^{45} > 24 * 2^{42}$
so $(1000)^{11} * {3000}^{31} > 24 * {2000}^{42}$
Hence $(1016)^{11} * {3016}^{31} > 24 * {2000}^{42}\cdots(1)$
Now $2016^{42} = 2000^{42}( 1+ \frac{1}{125})^{42} < 2000^{42}( 1+ \frac{1}{125})^{125} < 2000^{42} * e < 2000^{42} *3$
from above and (1) we have $(1016)^{11} * {3016}^{31} > {2016}^{42}\cdots(3)$
Hence $(1016)^{11} * {3016}^{31}$ is larger
Awesome! Thanks kaliprasad for participating!(Cool)
My solution:
I first assume \(\displaystyle 1016^{11}\cdot 3016^{31}\gt 2016^{42}\).
From the prime factorization of \(\displaystyle 1016=2^3\cdot 127,\,2016=2^5\cdot 3^2\cdot 7,\,3016=2^3\cdot 13\cdot 29\)
I need to prove
\(\displaystyle (2^3\cdot 127)^{11}\cdot (2^3\cdot 13\cdot 29)^{31}\gt (2^5\cdot 3^2\cdot 7)^{42}\)
Simplify the above we get:
\(\displaystyle 2^{33}\cdot 127^{11}\cdot 2^{93}\cdot 13^{31}\cdot 29^{31}\gt 2^{210}\cdot 3^{84}\cdot 7^{42}\)
\(\displaystyle 127^{11}\cdot 13^{31}\cdot 29^{31}\gt 2^{210-33-93}\cdot 3^{84}\cdot 7^{42}\)
\(\displaystyle 127^{11}\cdot 13^{31}\cdot 29^{31}\gt 2^{84}\cdot 3^{84}\cdot 7^{42}\)
\(\displaystyle 127^{11}\cdot 377^{31}\gt 6^{84}\cdot 7^{42}\)*
Observe that:
$7^2=49,\,7^3=343\implies 373\gt 7^3$
Therefore $373^{14}\gt (7^3)^{14}$ which is $373^{14}\gt 7^{42}$
At this point, if we can prove
\(\displaystyle 127^{11}\cdot 377^{17}\gt 6^{84}\)
Then we can conclude \(\displaystyle 1016^{11}\cdot 3016^{31}\gt 2016^{42}\) is correct.
Observe again that
$127\cdot 377=47879\gt 6^6=46656$
Taking 14th power on both sides of the inequality we get:
$(127\cdot 377)^{14}\gt (6^6)^{14}$
\(\displaystyle 127^{14}\cdot 377^{14}\gt 6^{84}\)
It's obvious that
\(\displaystyle 127^{11}\cdot 377^{17}\gt 127^{14}\cdot 377^{14}\) is true, therefore, our assumption has been justified, therefore \(\displaystyle 1016^{11}\cdot 3016^{31}\) is bigger than \(\displaystyle 2016^{42}\).
FAQ: Comparison between two numbers
What is a comparison between two numbers?
A comparison between two numbers is the process of determining the relationship between two numerical values. This can involve finding which number is larger, smaller, or equal to the other number.
How do you compare two numbers using the greater than symbol?
To compare two numbers using the greater than symbol, simply place the symbol (>), also known as the "greater than" operator, between the two numbers. The number on the left should be larger than the number on the right for the statement to be true.
What is the difference between equal to and equivalent?
The terms "equal to" and "equivalent" are often used interchangeably, but they have slightly different meanings. Equal to refers to two values being exactly the same, while equivalent refers to two values having the same value or meaning, but not necessarily being identical.
What is the purpose of comparing two numbers?
The purpose of comparing two numbers is to understand the relationship between them and to determine which number is greater, smaller, or equal to the other. This can be useful in making decisions, solving problems, and analyzing data.
How do you compare two numbers using the less than or equal to symbol?
To compare two numbers using the less than or equal to symbol, place the symbol (<=), also known as the "less than or equal to" operator, between the two numbers. The number on the left should be less than or equal to the number on the right for the statement to be true.
