Comparison of tidal forces acting on the Moon vs Enceladus
In summary: So rod with masses at each end... I understand that distance between them and force varies with distance from the center of planet. But I don't know how. What is the change in...?The change in distance between the masses would cause the force in the rod to vary.
Vrbic
407
I have heard about a moon Enceladus. Which is powered by tidal force. I suppose this force press back and forth on the moon and friction in the core causes heat. I hope I'm right :-)
Now tidal force ##F_t=\frac{2GMmr}{R^3}##, where ##G## is Gravitation constant, ##M## is mass of planet causes gravitational field, ##m## and ##r## is mass and radius of body where we looking for tidal force and ##R## is distance of both objects.
I took data from Wikipedia about Enceladus, Saturn, Moon and Earth and put it to this formula (##M_S ##~##100M_E##,
##m_{enc}##~##m_m/1000##, ##r_{enc}##~##r_m/10##, ##R_{enc-S}##~##R_{m-E}##). I find out that force acting on Moon is 100 times stronger. My question is why our Moon is cold and on Enceladus is warm water? Or ok, probably there are other factors (radioactive decay in core of Enceladus and on Moon it is not) but I would expect something more than cold stone :-)
Can anyone explain it?
I took data from wikipedia about Enceladus, Saturn, Moon and Earth and put it to this formula (##M_S ##~##100M_E##,
Can anyone explane it?
Force is not the same as power. What relates the two? How is that different between our moon and Enceladus?
##P=\frac{F s}{t}##, where ##s## is a path induced by the force and ##t## is time duration of acting force.
Honestly, I'm not sure, how find out the path (prolongation or relative prolongation). If I use Hooke's law , I don't know Young's modulus E. And time is also tough nut to crack. Moon and Earth rotate in captured rotation. So Moon is still stretched in same direction. On the other hand now I read that Enceladus also rotates in captured rotation...
Please kick me again :-)
Vrbic said:
where s is a path induced
Well, it does not need to be induced by the force, but certainly influenced by the force.
Right, and that was certainly something to consider. What else about the orbit might cause the force distribution within the satellite to vary over time?
Ok, I know what you point out. Eccentricity. A change in radial distance from center of a planet. Ok so, then some mean power could find out as ##<P>=\frac{\Delta F_t}{T/2}## where ##\Delta F_t=F_t(R_p)-F_t(R_a)## and ##T## is period.
Do you agree?
Do you agree?
I'm unsure of your notation.
Consider a rod length 2r, always pointing at the planet (from some constraint), with a mass at each end. Orbiting independently, the distance between the masses would vary, so the force in the rod varies.
Ok, I found a mistake in my logic :-) There is missing ##\Delta r## the change in distance (the change in diameter of a moon) between pericenter ##R_p## and apocenter ##R_a##.
##<P>=\frac{\Delta F_t *\Delta r}{T/2}##.
So rod with masses at each end... I understand that distance between them and force varies with distance from the center of planet. But I don't know how. What is the change in distance?
That depends on the elasticity. If the satellite were perfectly rigid it would not be warmed.
Likes brainierthaneinstein
Yes, that's what I mentioned above, in second message where I wrote about Hooke's law and Young's modulus.
But back to my question, why the heat induced by tidal friction is not in our Moon so big?
I realized that important isn't force but power, ok. But you asked my what power is induced in both moons but I still don't know how to resolve it.
Is eccentricity important? Or elasticity? I guess both, but I'm not capable to guess what is more important.
It's the combination. Both are necessary (given the locked rotation).
Ok and what about power which you mentioned? And global question why our Moon isn't heated by tidal friction and Enceladus is?
Develop some equations.
Suppose the moon has radius r, the orbital radius varies between Rmin and Rmax, the period is T, the elasticity is k, and whatever other unknowns you think you need. How much energy is stored and released each orbit?
Likes Vrbic
Ok, may I suppose that moon is a kind of dumbbell with massless bar? Or should I choose another approximation?
Ok so I used dumbbell approximation:
##r \textrm{(radius of moon)}<<R\textrm{(distance earth-moon)}## I use approximation ##\frac{1}{(R+r)^2}\doteq \frac{1}{R^2}-\frac{2r}{R^3}...## I hope I may.
In ##R_{max}##
$$F_{max}=GMm(\frac{1}{R_{max}^2}-\frac{1}{R_{max}^2}+\frac{2r_{max}}{R_{max}^3})=\frac{2GMmr_{max}}{R_{max}^3}$$
In ##R_{min}##
$$F_{min}=GMm(\frac{1}{R_{min}^2}-\frac{1}{R_{min}^2}+\frac{2r_{min}}{R_{min}^3})=\frac{2GMmr_{min}}{R_{min}^3}$$
I use eccentricity ##e##:
$$R_{min}=\frac{1-e}{1+e}R_{max}=yR_{max}, y=y(e) $$
and relative prolongation ##l##:
$$l=\frac{r_{max}-r_{min}}{r_{max}} =>r_{min}=(1-e)r_{max}=xr_{max}, x=x(l)$$
So diference of forces on opposite side of orbit is: $$\Delta F=2GMm(\frac{r_{max}}{R_{max}^3}-\frac{r_{min}}{R_{min}^3})=2GMmr_{max}\frac{y^3-x}{(yR_{max})^3}$$ or $$\Delta F=\frac{2GMmr_{max}}{R_{max}^3}(1-\frac{x}{y^3}) $$
Maybe I can suppose that ##e## and ##l## are small so: ##x=1-l## and ##y^{-3}\doteq1+6e## than
$$\Delta F=\frac{2GMmr_{max}}{R_{max}^3}(6e-l)$$
What do you mean about that? Is it ok as a approximation?
Continuation:
Potential energy stored due to half orbit should be: ##U=\int{F(r)dr}##, where ##r## is prolongation from ##r_{max}## (now I see that in my case it's more like a shortening). Integration with substitution ##l_0=\frac{r}{r_{max}}## than is:
$$U=\frac{2GMmr_{max}^2}{R_{max}^3}\int_0^l(6e-l_0)dl_0=\frac{GMmr_{max}^2}{R_{max}^3}(12e-l)l$$
Is it good idea to deal with potential energy of this process like that?
In ##R_{max}##
In ##R_{min}##
The way you involve rmax and rmin in your equations unnecessarily mixes up two things.
For the purpose of finding the differential gravitational forces between min and max R, the variation in r is too small to be relevant. Take r as constant at that stage.
Having found the variation in stress on the satellite, use the elasticity to find the variation in stored PE.
Note that this still does not directly translate into heat generated. When the stress on an elastic body is varied, so that it alternately stretches and contracts, it has two different coefficients. It is the difference between them that causes mechanical work to turn into heat. But the important thing here is that for a given type of body the heat will be proportional to the total turnover of work.
Thank you for leading. I have few question if I may:
1) Is introducing of eccentricity and everything around it alright?
2) How now I find the potential energy due to orbiting? The path is now the distance ##R## from a planet? It is my integration variable? (I don't mean by it energy for a heating, I mean, energy coming from effect of rotation - a changing distance.)
3) Will I find the heat ##Q## in way I subtract my potential energy ##U## and kinetic energy ##E## due to vibration of moon? ##Q=U-E##?
Your expressions for Fmin and Fmax in post #15 are fine, except that you can use just average radius r of the satellite in both.
If the elasticity of the satellite is k, you can find the corresponding min and max elastic PE. The turnover of the elastic work each orbit is the difference between the two. The work turned to heat will be some fixed fraction of that. You can assume the fraction is the same for bodies of similar composition.
The EP is my ##U##? I'm a bit lost in terminology. Now I don't know if my concept of potential energy from post #16 is right i.e what do you mean about question 2 from post #18 .
Also you are mentioned a elasticity k. So you mean to use Hooke's law. Or you mean k use as a spring constant (or find some conection between them)?
What do you mean about question 3 from post #18? Is it good idea?
I was thinking about elasticity: A moon isn't any "material". It is gravitationally bound object. So I believe that main factor acting against stretching is gravity. What do you mean? May I equal gravitational force and force describing spring or Hook's law? And extract elasticity?
Gravity is opposing the stretching by gravity?
Ok I tried it (probably you were talking about that). If the moon is in all position of orbit stable it should be true:
##F## is spring force, ##G## is gravitational force, ##x## is change in diameter
##F_0-F_1=G_0-G_1##
##0+kx=-2Gm(\frac{1}{r^2}-\frac{1}{(r+x)^2}), x>>r => kx=\frac{4Gmx}{r^3}##
##k=\frac{4Gm}{r^3}##
What do you mean about it?
The gravity of the moon is against the gravity of the planet which stretches the moon. No? Wrong assumption?
If you decompose gravity like that, it makes sense.
The gravitational PE is not relevant.
In the dumbell model, the end nearest the planet is trying to go in one orbit, but the far end is trying to go in a different one. The distance between the two orbits varies, stretching the dumbell. The work that ends as heat is a portion of the work goes into stretching and relaxing the dumbell. So it is the variation in elastic PE that matters.
Ok, I understand but I don't know where are you pointing on. Gravitational potential energy is not relevant. Ok but potential energy caused by stretching important is. No? And I hope it these which I tried to find in #18. Or why I dealed with a tidal force? It was useless? Could you be more specific how to find a power which drives a heating? I can't recognize what I have done good and what was useless.
There are a number a factors to consider. Enceladus is less dense than the Moon and thus likely not as rigid. As a comparison, consider what would happen if you were rapidly squeezing and releasing a foam rubber ball, vs. doing the same, with equal force to the ball made of a rigid material. The rubber ball will get warmer, while the rigid ball not so much.
Also consider the difference between repeatedly squeezing the ball in quick succession vs. doing so at a slower pace. The ball will warm more in the first case than in the second. This comes into play when you consider that Enceladus orbits Saturn in just 33 hrs, vs. the 27 1/3 days it take for the Moon to orbit the Earth.
Likes Vrbic
As I wrote, your equations for Fmin and Fmax in post #15 are nearly right. (I assume these are what you mean by tidal force.) The only change needed is to replace rmin and rmax in those with the mean satellite radius, r.
(Actually, I think the tension in the satellite/dumbbell would be half of these, but it does not matter for present purposes.)
We don't know what the elasticity is, and it may different for different satellites. And the work lost to heat depends on the difference between that for the stretching phase and that for the relaxation phase. Let these be ks, kr respectively.
If you plot force against extension this means you get two lines of different slopes, ks above kr. A stretch/relax cycle consists of starting at some point on the upper line, moving to the right and up as it is stretched, up to the max extension. As soon as relaxation starts, you can suppose it drops almost vertically to the lower slope, then follows that line down and to the left until directly under the point where it started. On going back into extension, it rises amost vertically until back on the upper slope. And so the cycle repeats.
This is an example of hysteresis. The work lost to heat each cycle is the area inside the quadrilateral.
Can you compute that area in terms of Fmin, Fmax, kr and ks?
Likes Vrbic
You are right, or ##m## is a weight only one part of dumbbell.
  • #31
I understand what you're saying, but I can't imagine how or why is there different elasticity for stretching and relaxing phase.
Again, mathematically I understand two linear function, quadrilateral, area of quadrilateral is ##A=ef\sin(\phi)/2##, where ##e## and ##f## are diagonals and ##\phi## is angle between them, no problem, but in #15 isn't any elasticity. Formula for a force of spring is F=-kx ok here is k and I suppose ##2GMm/R^3## play a role of ##k##, but still I'm not sure how do you mean it. Or how to compose ##k## in there.
  • #32
Or do you mean that ##k_s=2GMm/R_{min}^3## and ##k_r=2GMm/R_{max}^3##??
  • #33
No.
If the elasticity coefficients were the same for deformation and relaxation then all the work done in compressing or stretching a spring or piece of rubber etc. would be recoverable in the relaxation phase. But we know this is never true. Balls never bounce to the original height. Rubber bands warm up when repeatedly stretched and released.
  • #34
haruspex said:
No.
Ok,
and now back
How I get elasticity to my formula for ##F_{min}## and ##F_{max}##?
  • #35
Not the most convenient formula here. The sides are vertical, which makes it much simpler.
The two elasticities give the slopes at top and bottom of the quadrilateral, and you know both lines pass through the origin.
You need to decide which vertex corresponds to Fmin and which to Fmax. Any thoughts?
