Compasses and Magnetic Field: B of Earth with respect to B of wire
In summary, the conversation discussed the direction of the magnetic field of a wire and how it would interact with the Earth's magnetic field. It was determined that the direction of the resultant field would be at a 45 degree angle between the Earth's magnetic field and the wire's magnetic field, assuming the magnitudes are equal. Homework Equations were not necessary for this discussion.
jamba88
The current in the wire is going down. The wire is in the z axis position going up and down. A compass is placed below the wire...for example the wire passes through (0,0) the origin on the x, y plane. The compass would be placed in the (0,-1) position on the x,y plane.
Show the vector diagram of the two magnetic fields (B of Earth and B of wire) and the resultant field.
None
I'm not sure if my answer is right:
The direction of the magnetic field is clockwise. If a compass is placed south of the wires the direction of the magnetic field should be pointing directly to the left, since at a pt the direction of a magnetic field is tangent to that point on the magnetic field.
Therefore, should the vectors look like this: B of Earth pointing directly North and B of wire pointing directly west. the resultant field should be between those two vectors making a 45 degree angle with a direction Northwest.
It looks like you've got the directions right, but unless the magnitude of the B field from the wire is equal to that of Earth, it would not necessarily be at 45 degrees would it?
Your answer is partially correct. The direction of the magnetic field of the Earth is indeed pointing north, but the direction of the magnetic field of the wire depends on the direction of the current. Since the current is going down, the magnetic field of the wire would be pointing in the opposite direction, which is up.
Therefore, the vectors would look like this: B of Earth pointing north and B of wire pointing up, resulting in a resultant field that is pointing in a northwestern direction.
It is important to note that the strength of the magnetic field of the wire would depend on the distance from the wire, while the strength of the Earth's magnetic field would remain constant. This means that the resultant field would also vary in strength depending on the distance from the wire.
In conclusion, the compass would point in a northwestern direction due to the combined effect of the Earth's magnetic field and the magnetic field of the wire, with the strength and direction of the resultant field depending on the distance from the wire.
FAQ: Compasses and Magnetic Field: B of Earth with respect to B of wire
How does a compass work?
A compass works by utilizing the Earth's magnetic field. The needle inside the compass is a small magnet that aligns itself with the Earth's magnetic field. This allows the needle to point towards the Earth's magnetic north pole, giving us a sense of direction.
What is the relationship between the Earth's magnetic field and the magnetic field of a wire?
The Earth's magnetic field and the magnetic field of a wire are both created by the movement of charged particles. However, the Earth's magnetic field is much larger and stronger due to the vast amount of iron in the Earth's core. The magnetic field of a wire is much smaller and can be influenced by the Earth's magnetic field.
Can a wire affect the Earth's magnetic field?
Yes, a wire can affect the Earth's magnetic field to a certain extent. When an electric current flows through a wire, it creates a magnetic field around the wire. This magnetic field can interact with the Earth's magnetic field and cause changes in its direction or strength.
How does the Earth's magnetic field protect us?
The Earth's magnetic field acts as a shield against the sun's harmful radiation. The magnetic field deflects these charged particles away from the Earth, preventing them from reaching the surface. Without this protection, these particles would damage our atmosphere and potentially harm living organisms.
Can the Earth's magnetic field change over time?
Yes, the Earth's magnetic field is not constant and has been shown to change over time. These changes can be caused by various factors such as movements in the Earth's core or external influences like solar activity. Scientists study these changes to better understand the Earth's magnetic field and its effects on our planet.
