Complement of a 'Hood of the Solid Torus in S^4
All.In summary, the author's statement about the complement of the tubular neighborhood being another D^2 x S^1 x S^1 is incorrect. The complement is actually a D^2 x S^1, not a D^2 x S^1 x S^1. The boundary of the tubular neighborhood is not topologically equivalent to a solid torus, but rather a solid disk cross a circle. This clarification helps to better understand the problem at hand. Thank you for bringing this to our attention.
Bacle
662
Hi, All:
This is a followup to the post :
https://www.physicsforums.com/showthread.php?t=491211
Here Lavinia gave a couple of nice arguments showing that the complement of the solid torus the 3-sphere S^3 is a solid torus; one of which was using the Hopf fibration, taking a disk D^2 within a local trivialization of S^2, so that its lift is D^2 x S^1 , and then the complement of the disk in S^2 is itself a disk, which also lifts to a D^2 x S^1.
Now, I am trying to see if a tubular 'hood (neighborhood) (D^2 x S^1 )x S^1 of the solid torus in S^4 is again a tubular neighborhood D^2 x S^1 x S^1.
The whole thing came up from a paper which argues that a given twist extends by using a result by J.M Montesinos in which a Dehn twist extends from the embedded copy of S_3 (orientable genus-3 surface)into the whole 4-sphere S^4, if a map defined on S^1 x S^1 x S^1 induces a special type of map on the first homology.
The author starts by sugering the S^4 into a B^3 x S^1 and D^2 x S^2, after which he glues the two along their common boundary S^2 x S^1.
From what I understood, the author deforms the S_3 into a D^2 x S^1 x S^1, so that the twists are defined on the boundary S^1 x S^1 x S^1 , and then he shows that this map satisfies the conditions . But s/he seems to be saying that the complement of the tubular 'hood D^2 x S^1 x S^1 in S^4 is another D^2 x S^1 x S^1.
Is this correct?
Hello,
Thank you for bringing this interesting problem to our attention. After reading through the original post and your follow-up, I believe that the author's statement about the complement of the tubular neighborhood being another D^2 x S^1 x S^1 is incorrect.
Firstly, let's clarify what a tubular neighborhood is. In general, a tubular neighborhood is a neighborhood of a submanifold that is topologically equivalent to a solid cylinder. In this case, the submanifold in question is a solid torus, which is topologically equivalent to a disk (D^2) cross a circle (S^1). So, a tubular neighborhood of this solid torus would be a neighborhood that is topologically equivalent to a solid torus (D^2 x S^1).
Now, let's consider the complement of this tubular neighborhood in S^4. This complement would be the rest of S^4 minus the neighborhood, which would include the boundary S^2 x S^1. This boundary is not topologically equivalent to a solid torus (D^2 x S^1), but rather to a solid disk (D^2) cross a circle (S^1). So, the complement is not another D^2 x S^1 x S^1, but rather a D^2 x S^1.
In conclusion, I believe that the author's statement about the complement of the tubular neighborhood being another D^2 x S^1 x S^1 is incorrect. I hope this helps clarify the situation. If you have any further questions or comments, please don't hesitate to ask. Thank you for your contribution to the forum.
Related to Complement of a 'Hood of the Solid Torus in S^4
1. What is the complement of a 'Hood of the Solid Torus in S^4?
The complement of a 'Hood of the Solid Torus in S^4 refers to the set of points in S^4 that are not contained within the 'Hood of the Solid Torus. In other words, it is the space outside of the solid torus in the four-dimensional sphere.
2. How is the complement of a 'Hood of the Solid Torus in S^4 different from the solid torus itself?
The solid torus in S^4 is a three-dimensional object that exists within the four-dimensional sphere. Its complement, on the other hand, includes all points outside of the solid torus in S^4, which can be thought of as the "empty space" surrounding the solid torus.
3. What is the topology of the complement of a 'Hood of the Solid Torus in S^4?
The topology of the complement of a 'Hood of the Solid Torus in S^4 is the same as that of a three-dimensional sphere, as it can be thought of as the space outside of a solid object within a higher-dimensional space. This means it is a closed, compact, and simply connected surface.
4. How is the complement of a 'Hood of the Solid Torus in S^4 relevant to mathematics or physics?
The complement of a 'Hood of the Solid Torus in S^4 is relevant in various fields of mathematics and physics, such as topology, geometry, and string theory. It can be used to study the properties of higher-dimensional spaces and objects, and has applications in areas such as knot theory and cosmology.
5. What are some possible real-world examples of the complement of a 'Hood of the Solid Torus in S^4?
Although it may be difficult to visualize, the complement of a 'Hood of the Solid Torus in S^4 can be thought of as the space outside of a solid torus within a four-dimensional sphere. In real-world terms, this could be similar to the space outside of a donut within a larger sphere-shaped container. Other examples could include the space outside of a spherical planet or a balloon within a higher-dimensional space.
  • Differential Geometry
