MHB Complementary & Supplementary Angles
  • Thread starter Thread starter bernardl
    Angles
The discussion focuses on solving problems involving complementary and supplementary angles. For the first problem, it is established that the measures of angles P and Q sum to 180 degrees, with P being defined as three less than twice Q. The second problem involves angles B and C, which sum to 90 degrees, with B being two more than three times C. The participants emphasize the importance of showing work to facilitate better assistance. The solutions involve setting up equations based on the definitions of supplementary and complementary angles.
bernardl
The m<P is three less than twice the measure of <Q. If <P and <Q are supplementary angles, find the measures of both angles.
The m<B is two more than three times the measure of <C. If <B and <C are complementary angles, find the measures of both angles.
Mathematics news on Phys.org
Hello! :D
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Can you post what you have done so far?
I honestly don't know how to do both of those questions!
O.k., let's try the first one. mP + mQ = 180 degrees. mP = 2mQ - 3. Make sense? Can you solve it now?
"The m<P is three less than twice the measure of <Q. If <P and <Q are supplementary angles, find the measures of both angles."
Do you know that "supplementary angles" means their measures sum to 180 degrees? m<P+ m<Q= 180. You are also told that m<P= 2m<Q- 3 so (2m<Q- 3)+ m<Q= 3m<Q- 3= 180. Solve that for m<Q then use m<P+ m<Q= 180 to find m<P "The m<B is two more than three times the measure of <C. If <B and <C are complementary angles, find the measures of both angles."
"Complementary angles" are angles whose measures add to 90 degrees. So m<B+ m<C= 90.
"m<B is two more than three times the measure of <C" means that m<B= 3m<C+ 2.
So m<B+ m<C= (3m<C+ 2)+ m<C= 4m<C+ 2= 90. Solve that for m<C then use m<B+ m<C= 90 to find m<B.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
