Complete augmented by row operations
In summary, complete augmented by row operations is a method for solving systems of linear equations by manipulating the rows of a matrix using elementary row operations. It is an efficient and systematic approach that provides a clear visual representation of the process. However, it may not work for all types of matrices and can become more complex for larger matrices. It is commonly used in fields such as engineering, physics, and economics to solve real-world problems.
karush
MHB
3,269
$\left[
\begin{array}{rrrr|r}
1& -5& 4& 0&0\\
0& 1& 0& 1&0\\
0& 0& 3& 0&0\\
0& 0& 0& 2&0
\end{array}\right] $
OK my first move on this is $r_3/3$ and $r_4/2$.
$\left[
1& -5& 4& 0&0\\
0& 1& 0& 1&0\\
0& 0& 1& 0&0\\
0& 0& 0& 1&0
\end{array}\right]$
$r_2-r_4=r_2\quad$
doesn't this whole thing zero out?
yep ... reduced row-echelon form is
$\begin{bmatrix}
1 & 0 & 0 & 0 &0\\
0 & 1 & 0 &0 &0 \\
0 & 0 & 1 & 0 &0 \\
0 & 0 & 0 & 1 & 0
\end{bmatrix}$
FAQ: Complete augmented by row operations
What is the purpose of using row operations in a complete augmented matrix?
Row operations are used to simplify and solve systems of linear equations represented in a matrix form. By performing row operations, we can manipulate the matrix in order to find the solution to the system of equations.
What are the different types of row operations that can be performed on a complete augmented matrix?
The three types of row operations are: multiplying a row by a non-zero constant, swapping two rows, and adding a multiple of one row to another row. These operations do not change the solution of the system of equations.
How do you know when a complete augmented matrix is in reduced row-echelon form?
A complete augmented matrix is in reduced row-echelon form when it satisfies the following conditions: all rows with all zero entries are at the bottom, the first non-zero entry in each row (called a leading entry) is a 1, each leading entry is the only non-zero entry in its column, and the leading entry in each row is to the right of the leading entry in the row above it.
Can row operations change the solution of a system of equations represented by a complete augmented matrix?
No, row operations do not change the solution of a system of equations. They simply rearrange the matrix in order to make it easier to find the solution.
How can I use row operations to solve a system of equations represented by a complete augmented matrix?
By performing row operations, we can transform the matrix into reduced row-echelon form. Once the matrix is in this form, we can easily read off the solution to the system of equations. The variables will correspond to the columns without leading entries, and the constants will be the values in the last column.
