Complete Metric Space: X, d | Analysis/Explanation
In summary, the first interval $[0,1]$ is complete since it is a closed subset of the complete metric space of real numbers with the usual metric. The second, third, and fourth intervals $[0,1), [0,\infty), (-\infty,0)$ are not complete as they are not closed subsets of the same metric space. A sequence in $[0,1)$ that is Cauchy does not converge to a point in $[0,1)$, making it not complete.
shen07
54
Hi i am confused of the following question.
Suppose we have a Metric Space (X,d), where d is the usual metric. Now are the following subsets complete, if so why??
1.$$X=[0,1]$$
2.$$X=[0,1)$$
3.$$X=[0,\infty)$$
4.$$(-\infty,0)$$
1.$$X=[0,1]$$
2.$$X=[0,1)$$
3.$$X=[0,\infty)$$
4.$$(-\infty,0)$$
Hi she07, :)
Since any closed subspace of a complete metric space (in this case the complete metric space is the set of real numbers with the usual metric) is complete, the fist interval is complete (refer >>this<<).
Conversely, a complete subset of a metric space is closed. Therefore the second third and fourth intervals are not complete since they are not closed.
I think the third interval is indeed closed, since its complement:
$(-\infty,0)$ is open.To see why the second interval is NOT complete, consider the sequence:$a_n = \dfrac{n}{n+1}$.It is clear that the set $A = \{a_n: n \in \Bbb N\} \subseteq [0,1)$ and that $\{1\}$ is a limit point of $A$ (and thus of $[0,1)$), but is not in $[0,1)$.Put another way, the sequence above is Cauchy, but not convergent to a point in $[0,1)$.
Thanks for pointing out the mistake. Yep, the second interval is indeed closed. :)
A complete metric space is a metric space in which every Cauchy sequence converges. In other words, a complete metric space is one in which there are no "missing points" or "gaps" between the elements. In this context, a Cauchy sequence is a sequence of points in the metric space such that for any given distance, there exists a point in the sequence after which all other points are within that distance.
1. The subset X=[0,1] is a closed and bounded subset of the real numbers. Since the real numbers are a complete metric space, any subset that is closed and bounded will also be complete. Therefore, X=[0,1] is a complete metric space.
2. The subset X=[0,1) is an open and bounded subset of the real numbers. However, the endpoint 1 is not included in the subset. This means that there is a "gap" between the elements in the subset and the endpoint 1. Therefore, X=[0,1) is not a complete metric space.
3. The subset X=[0,∞) is a closed and unbounded subset of the real numbers. Since the real numbers are a complete metric space, any closed subset will also be complete. However, since X is unbounded, there may be Cauchy sequences that do not converge in X. Therefore, X=[0,∞) is a complete metric space, but there may be Cauchy sequences that do not converge in X.
4. The subset X=(-∞,0) is an open and unbounded subset of the real numbers. Similarly to X=[0,1), there is a "gap" between the elements in the subset and the endpoint -∞. Therefore, X=(-∞,0) is not a complete metric space.
In summary, subsets that are closed and bounded or closed and unbounded in a complete metric space will also be complete. However, subsets that are open and bounded or open and unbounded may not be complete due to the potential for "gaps" between the elements.
FAQ: Complete Metric Space: X, d | Analysis/Explanation
1. What is a complete metric space?
A complete metric space is a mathematical concept in which all Cauchy sequences converge to a point within the space. In simpler terms, it is a set of points with a distance function defined between them, where every sequence of points that gets closer and closer together eventually converges to a specific point within the space.
2. What is the significance of completeness in a metric space?
Completeness is important in a metric space because it guarantees the existence of limits for sequences of points within the space. This allows for more precise analysis and calculations, as well as the ability to prove the convergence of certain functions and series.
3. How is completeness different from compactness in a metric space?
While completeness refers to the existence of limits within a metric space, compactness refers to the existence of finite subcovers in an open cover of the space. In other words, a complete metric space guarantees the convergence of sequences, while a compact metric space guarantees the existence of finite covers.
4. Can a metric space be complete but not compact?
Yes, a metric space can be complete but not compact. For example, the space of real numbers with the standard Euclidean metric is complete, but it is not compact because it is not bounded. This means that there exist sequences that converge to a point within the space, but there is no finite cover that can encompass all points within the space.
5. How is completeness related to the convergence of series in a metric space?
In a complete metric space, a series converges if and only if its sequence of partial sums is a Cauchy sequence. This is known as the Cauchy criterion for series convergence. Therefore, completeness plays a crucial role in determining the convergence of series in a metric space.
