Complete the parametric equation for the line where the planes cross
In summary, the task involves determining the parametric equation for a line defined by the intersection of two planes. This requires identifying the direction vector of the line, which is derived from the normal vectors of the planes, and a point on the line, which can be found by solving the equations of the planes simultaneously. The parametric equation is then established by combining the point and the direction vector.
MP97
Complete the parametric equation for the line where the planes cross.
Plane 1: x-12z=-36
Plane 2: -11x16y-14z=-30
Note: the first parametric equation is given as x(t)=-72t
First, I use the unit vector of each plane, and I compute their cross-product to obtain a vector parallel to the line of interception.
Then, I algebraically use x=0 to obtain the coordinates of the point in the line of interception. However, not having a y coordinate in plane one is confusing me.
  • Care
Likes Delta2
It seems you're missing a sign in Plane 2. Also, please use Latex for your Math content.
Likes Delta2
MP97 said:
Homework Statement: Complete the parametric equation for the line where the planes cross.
Relevant Equations: Plane 1: x-12z=-36
You haven't mentioned how this equation will come into play.
You don't need a unit vector for each plane, but you do need a normal vector for each one.
You can use the given equation of x as a function of t to solve for z in the first plane, and then use your equations of x and z as functions of t to solve for y in the second plane.
In any case, please show us what you have done.
Plane 1: x-12z=-36
Ok the first one is a plane ...
##x-12z=-36##
##x+36=12z##
##\frac{x}{12}+\frac{36}{12}=z##
##z=\frac{x}{12}+3##
... parallel to the y axis
An second "plane" is ...
##-11x16y-14z=-30 ##
##-176xy+30=14z##
##z= \frac{-176xy}{14}+\frac{30}{14}##
... is not a plane at all, but a saddle ( hyperbolic paraboloid )....
Wolfram Alpha -> https://www.wolframalpha.com/input?i=z=+\frac{-176xy}{14}+\frac{30}{14}
... I don't understand the goal?
##x-12z=-36##
##-176xy+30=14z##
Very likely, there is a typographical error in the equation for the second plane. Probably it should be
##\displaystyle -11x+16y-14z=-30 \ \ ## or ##\displaystyle \ \ -11x-16y-14z=-30 ##.
If OP had shown us any significant amount of his work on this problem, the correct equation would have been evident.
Likes WWGD and Bosko
I had asked for clarification in that respect too.
I'm 99.44% certain that the equation above is missing a '+' sign between -11x and 16y.
  • Love
Likes Bosko and SammyS
Me to, either + or - sign.
FAQ: Complete the parametric equation for the line where the planes cross
What is a parametric equation for a line?
A parametric equation for a line expresses the coordinates of the points on the line as functions of a single parameter, usually denoted as t. For a line in 3D space, the parametric equations are typically written as x(t), y(t), and z(t), where each coordinate is a linear function of t.
How do you find the direction vector for the line where two planes intersect?
The direction vector for the line where two planes intersect can be found by taking the cross product of the normal vectors of the two planes. The normal vector of a plane Ax + By + Cz = D is given by (A, B, C).
What are the steps to find the parametric equations for the line of intersection of two planes?
1. Find the normal vectors of the two planes.2. Compute the cross product of these normal vectors to get the direction vector of the line.3. Find a point of intersection by solving the system of equations given by the two planes.4. Use the point of intersection and the direction vector to write the parametric equations.
Can you provide an example of finding the parametric equation for the line where two planes intersect?
Consider two planes: Plane 1: x + 2y + 3z = 6 and Plane 2: 4x + 5y + 6z = 12. The normal vectors are (1, 2, 3) and (4, 5, 6). The cross product of these vectors gives the direction vector (-3, 6, -3). Solving the system of equations, we find a point of intersection, such as (0, 0, 2). Thus, the parametric equations are x = -3t, y = 6t, z = 2 - 3t.
Why is the cross product of the normal vectors used to find the direction vector?
The cross product of two vectors yields a vector that is perpendicular to both of the original vectors. Since the normal vectors of the planes are perpendicular to their respective planes, the cross product gives a direction vector that lies along the line of intersection, which is perpendicular to both planes' normal vectors.
