Completely Inelastic Collision
In summary, the conversation discusses the attempt to prove that when two objects collide and stick together, there is maximum energy loss. The conversation includes a mathematical proof using kinetic energy equations and the concept of a center of mass reference frame. It also addresses potential errors and clarifies the conservation of momentum in both elastic and inelastic collisions.
MathewsMD
433
I'm currently trying to make a proof to convince myself that when two object collide and stick afterwards, there is maximum energy loss. I've been thinking about it and trying to come up with a mathematical proof to solidify the idea in my head.
Please tell me if there's any errors in my explanation or if there's anything that should be added.
Case 1: object 1 is moving and object 2 is stationary (with no external forces, a frame of reference can always be used in which the motion is 0 m/s, and I realize this is a proof in itself, but I want to come up with something mathematically instead of intuitively)
Ki = (1/2)m1vi2 [1]
Taking the derivative and solving for 0 will give me an extreme value for the kinetic energy.
Kf = (1/2)(m1+m2)vf2 [2]
K'f=p=(m1+m2)vf
and if vf=0 m/s, then this system will have 0 J (which, using the right frame of reference, is possible in any situation where the velocity of the two "stuck" objects is constant"
pi = pf since there is no net external force
m1vi=(m1+m2)vf
vf=m1vi/(m1+m2) [3]
Plugging [3] into [2] and dividing by [1], to see the ratio between Kf and Ki
=[(1/2)(m1)[m12vi2/(m1+m2)2]/(1/2)m1vi2
=m12/(m1+m2)2
I'm just confused now since this ratio doesn't seem to tell me much about two kinetic energies, does it? What else should I do now?
Try working the problem in a frame in which the total momentum is zero. Then, before you go through the work of finding the extreme value, look carefully at the pre-collision and post-collision state.
Firstly, where K is kinetic energy, m is mass, v is velocity, and p is momentum, it could be technically debated that, if:
then:
K'fp = (m1+m2)vf
What has K been differentiated with respect to?
Another more easily addressed problem appears to be;
pi = pf
This is true if momentum is conserved, as is the case with ideal elastic collisions. In an inelastic collision, KE from equation [1] in the OP is lost to heat and other processes involved in the coalescing of the two objects, regardless of whether the final velocity; has been fixed to be zero, is measured to be zero, or otherwise. So pi ≠ pf , and therefore equation [3] is incorrect.
Lastly if K is dependent on v, and the final velocity of the coalesced objects is 0m.s-1, it becomes clear that the ratio Kf / Ki provides no useful information.
Momentum is always conserved, in both elastic and inelastic collisions, whether ideal or not.
Use the center of mass reference frame. In this frame the objects are at rest after the collision (by momentum conservation) which means the energy is a minimum (since its zero, and cannot be negative).
Related to Completely Inelastic Collision
What is a completely inelastic collision?
A completely inelastic collision is a type of collision where two objects stick together after impact and move as one combined mass. This means that the kinetic energy of the system is not conserved.
What is the difference between an elastic and an inelastic collision?
In an elastic collision, both kinetic energy and momentum are conserved. This means that the total kinetic energy before the collision is equal to the total kinetic energy after the collision. In an inelastic collision, only momentum is conserved and some kinetic energy is lost.
What factors affect the degree of inelasticity in a collision?
The degree of inelasticity in a collision is affected by the materials and masses of the objects involved, as well as the velocity and angle of impact. Objects with higher elasticity and lower mass are more likely to have an elastic collision.
How is the coefficient of restitution related to a completely inelastic collision?
The coefficient of restitution is a measure of the elasticity of a collision. In a completely inelastic collision, the coefficient of restitution is 0, meaning that there is no bounce back or separation between the objects after impact.
What real-life examples demonstrate completely inelastic collisions?
A car crashing into a wall, a ball sticking to a wall after being thrown, and a clay ball hitting a hard surface and sticking to it are all examples of completely inelastic collisions. These collisions result in the objects sticking together and losing some kinetic energy in the process.
