Complex Analysis - Harmonic Functions
In summary, to show that ln(az) is harmonic, we must show that it is analytic in the specified region. This can be done by using the Cauchy-Riemann equations to show that its real and imaginary parts are harmonic functions. Harmonic functions are defined as those that satisfy Laplace's equation, which states that the sum of the second derivatives of a function with respect to its variables is equal to zero.
chill_factor
903
Show ln(az) where a is a real number and z = x + iy is harmonic everywhere except z = 0.
z = x + iy = rcos(θ) + irsin(θ) = re^iθ
z = u(x,y) + iv(x,y)
Cauchy Riemann test for analyticity:
∂u/∂x = ∂v/∂y
∂u/∂y = -∂v/∂x
ln(az) = ln (rcos(θ) + irsin(θ)) = ln(rcos(θ+2nπ) + irsin(θ+2nπ))
= ln(a*re^iθ) = ln(ar) + i(θ+2nπ) <- this is multivalued, not harmonic.
How do I show it is harmonic?
Either rewrite ln(az) using x and y or the C-R relations using r and θ (this is the easier option) and proceed to check that they hold. The multivaluedness is in a constant which vanishes when you take derivatives.
writing it in terms of r, theta and using CR, that shows it is analytic. how do i show it is harmonic? the e^iθ, after you take the ln, will no longer be harmonic!
What is the definition of a harmonic function? Harmonic and periodic are not the same thing.
Why do you think θ isn't harmonic? It's basically just arctan(y/x). That's perfectly fine harmonic function.
sorry, perhaps I was confused, but I think the definition of a harmonic function should be one such that for f(x), ∂^2f/∂x^2 = kf(x). Or as wikipedia says:
In mathematics, mathematical physics and the theory of stochastic processes, a harmonic function is a twice continuously differentiable function f : U → R (where U is an open subset of Rn) which satisfies Laplace's equation
http://en.wikipedia.org/wiki/Harmonic_function
That's true for sine: ∂^2/∂x^2 (sin x) = -1*sin x
Also true for cosine: ∂^2/∂x^2 (cos x) = -1*cos x
However it is not true for arctan.
for u = arctan(y/x), ∂^2u/∂x^2 =/= k*u. thus it is not a harmonic function.
∂^2u/∂x^2 (arctan(y/x) = -(2 x y)/(x^2+y^2)^2 instead.
So that's why I'm confused. Yes, harmonic doesn't necessarily mean periodic, e^x is an example, but I'm having a hard time finding a function from ln(az) that can satisfy the 2nd derivative rule.
I think you need to look up Laplace's equation, because it is not ∂^2f/∂x^2 = kf(x).
To quote Tai L Chow's Mathematical Methods For Physicists,
Mathematical Methods For Physicists said:
If [itex]f(z)=u(x,y)+iv(x,y)[/itex] is analytic in some region of the [itex]z[/itex] plane, then at every point in the region the Cauchy-Riemann conditions are satisfied:
[tex]\frac{ \partial u }{ \partial x } = \frac{ \partial v }{ \partial y } \quad \text{and} \quad \frac{ \partial u }{ \partial y } = -\frac{ \partial v }{ \partial x }[/tex]
and therefor:
[tex]\frac{ \partial^2 u }{ \partial x^2 } = \frac{ \partial^2 v }{ \partial x \partial y } \quad \text{and} \quad \frac{ \partial^2 u }{ \partial y^2 } = -\frac{ \partial^2 v }{ \partial y \partial x }[/tex]
provided these second derivatives exist. In fact,one can show that if [itex]f(z)[/itex] is analytic in some region [itex]R[/itex], all its derivative exist and are continuous in [itex]R[/itex]. Equating the two cross terms, we obtain
[tex]\frac{ \partial^2 u }{ \partial x^2 } + \frac{ \partial^2 u }{ \partial y^2 } = 0[/tex]
throughout the region [itex]R[/itex].
Similarly, by differentiating the first of the Cauchy-Riemann equations with respect to [itex]y[/itex], the second with respect to [itex]x[/itex], and subtracting we obtain
[tex]\frac{ \partial^2 v }{ \partial x^2 } + \frac{ \partial^2 v }{ \partial y^2 } = 0[/tex]
Equations (6.12a) and (6.12b) are Laplace's partial differential equations in two independent variables [itex]x[/itex] and [itex]y[/itex]. Any function that has continuous partial derivatives of second order and that satisfies Laplace's equation is called a harmonic function.
We have shown that if [itex]f(z)=u(x,y)+iv(x,y)[/itex] is analytic, then both [itex]u[/itex] and [itex]v[/itex] are harmonic functions. They are called conjugate harmonic functions.
So, when you are being asked to show that [itex]\ln(az)[/itex] is harmonic, you are really being asked to show that the two-variable functions describing its real and imaginary parts are harmonic. From the above quote, you should see that this is equivalent to showing that [itex]\ln(az)[/itex] is analytic over the specified region (which is where the Cauchy Riemann equations come in, as clamtrox suggested).
Your textbook likely says something similar. Whenever you don't know how to tackle a problem, it is usually a good idea to open up your textbook and make sure that you understand the definitions of the relevant terms in the problem statement. Textbooks (good ones, anyways) are useful references to have.
Related to Complex Analysis - Harmonic Functions
1. What is complex analysis?
Complex analysis is a branch of mathematics that deals with the study of functions of complex variables. It is an extension of real analysis and involves the use of complex numbers to understand the properties of functions.
2. What are harmonic functions?
Harmonic functions are functions that satisfy Laplace's equation, which is a second-order partial differential equation. In simpler terms, these functions have the property that the value at any point is equal to the average of its neighboring points.
3. What is the relationship between complex analysis and harmonic functions?
Complex analysis is closely related to harmonic functions because harmonic functions can be expressed as the real or imaginary part of a complex analytic function. This means that the techniques and tools used in complex analysis can be applied to study harmonic functions.
4. What are some applications of complex analysis and harmonic functions?
Complex analysis and harmonic functions have many applications in physics, engineering, and other fields. For example, they are used to solve problems involving heat flow, electrical circuits, and fluid dynamics. In addition, they are also used in the study of functions in quantum mechanics and signal processing.
5. Is complex analysis and harmonic functions difficult to understand?
Like any other branch of mathematics, complex analysis and harmonic functions can be challenging to master. However, with patience and practice, it is possible to gain a good understanding of these topics. It is recommended to have a strong foundation in calculus and real analysis before studying complex analysis and harmonic functions.
