Complex Analysis Integral Question
In summary, the integral from 0 to infinity of (d(theta)/(5+4sin(theta)) can be computed from 0 to 2pi using the equation integral 0 to 2pi (d(theta)/1+asin(theta)) = 2pi/(sqrt(1-a^2)) (-1<a<1). There may be a typo in the given bounds, as the integral from 0 to infinity would result in an infinite value. It is more practical to integrate from 0 to 2pi, where the answer is 2pi/3.
RJLiberator
63
Computer the integral:
Integral from 0 to infinity of (d(theta)/(5+4sin(theta))
I've seen this integral be computed from 0 to 2pi, where the answer is 2pi/3 using the integral from 0 to 2pi (d(theta)/1+asin(theta)) = 2pi/(sqrt(1-a^2)) (-1<a<1)
Is there a typo in the bounds? Should the bounds be from 0 to 2pi instead of 0 to infinity? :/ Or can this problem be solved with another trick/the same trick?
It looks like the bounds should be 0 to 2pi. Otherwise you have:
##\int_0^\infty \frac{1}{5+4\sin\theta} \, d\theta = \infty \int_0^{2\pi} \frac{1}{5+4\sin\theta} \, d\theta##
since there are an infinite number of periods between 0 and 2pi.
The function is always positive >1/9, so there is no practical application to integrating over infinity, since the integral will clearly be greater than ##\infty \frac19##.
Likes RJLiberator
Beautiful! As I suspected.
Thank you for this.
Related to Complex Analysis Integral Question
1. What is complex analysis?
Complex analysis is a branch of mathematics that deals with the study of complex numbers and their functions. It involves the use of complex numbers, which are numbers that have both a real part and an imaginary part, and their properties to solve problems in various fields of mathematics and science.
2. What is an integral in complex analysis?
In complex analysis, an integral is a mathematical concept that represents the area under a curve in the complex plane. It is used to calculate the total value of a function over a given region in the complex plane, similar to how integrals are used in calculus to calculate the area under a curve in the real plane.
3. How is complex analysis integral different from real analysis integral?
The main difference between complex analysis integral and real analysis integral is that complex analysis deals with complex numbers and their functions, while real analysis deals with real numbers and their functions. Additionally, complex analysis integrals can have different paths of integration, unlike real analysis integrals which are usually calculated along a single axis.
4. What are some applications of complex analysis integral?
Complex analysis integrals have many applications in various fields such as physics, engineering, and economics. They are used to solve problems involving electric and magnetic fields, fluid dynamics, signal processing, and many other areas where complex numbers and functions are involved.
5. What are some important theorems in complex analysis integral?
Some important theorems in complex analysis integral include Cauchy's integral theorem, Cauchy's integral formula, and the residue theorem. These theorems provide powerful tools for evaluating complex integrals and are widely used in various fields of mathematics and science.
