Complex Analysis - Value of Arg[(z-1)/(z+1)] between -pi and pi
In summary: Arg, it is basically just arctan(Im(z)/|z|). Arcsin(Im(z)/|z|)?Pick a piece of Paper. Draw an x-axis and a y-axis on it. Find the point represented by i. Connect i to 0. What is the angle between the line segment that you've drawn and the x-axis?? Just look at... the equation for the Arg, it is basically just arctan(Im(z)/|z|).
  • #36
micromass said:
Indeed! That's it!
WOW! Thank you so much for helping and putting up with me!
<h2> What is complex analysis?</h2><p>Complex analysis is a branch of mathematics that deals with the study of functions of complex numbers. It involves the use of complex numbers, which are numbers that have both a real and imaginary component, and their properties to analyze functions and their behavior.</p><h2> What is the value of Arg[(z-1)/(z+1)] between -pi and pi?</h2><p>The value of Arg[(z-1)/(z+1)] between -pi and pi is equal to -pi/2. This can be calculated by using the formula Arg(z) = atan2(Im(z), Re(z)), where atan2 is the four-quadrant inverse tangent function.</p><h2> How is the value of Arg[(z-1)/(z+1)] affected by the values of z?</h2><p>The value of Arg[(z-1)/(z+1)] is affected by the values of z in the sense that it changes as z moves in the complex plane. For example, if z is a real number, the value of Arg[(z-1)/(z+1)] will be equal to 0. However, as z approaches the point -1 in the complex plane, the value of Arg[(z-1)/(z+1)] will approach -pi/2.</p><h2> What is the significance of the value of Arg[(z-1)/(z+1)] between -pi and pi?</h2><p>The value of Arg[(z-1)/(z+1)] between -pi and pi is significant because it represents the angle between the line connecting the points z=1 and z=-1 and the positive real axis. This angle is also known as the argument of the complex number (z-1)/(z+1) and is an important concept in complex analysis.</p><h2> How is complex analysis used in real-world applications?</h2><p>Complex analysis has many real-world applications, including in physics, engineering, and economics. It is used to solve problems involving electric circuits, fluid dynamics, and signal processing. It is also used in the study of economic systems and stock market behavior. Additionally, complex analysis is used in the development of computer graphics and in the design of aircraft wings and other complex structures.</p>
FAQ: Complex Analysis - Value of Arg[(z-1)/(z+1)] between -pi and pi
