Complex conjugate of a pole is a pole?
docnet
This isn't a homework problem, but a more general question.
Let ##f## be a function with two singular points ##r## and its complex conjugate ##r^*##.
let
$$f=\frac{g}{z-r} \quad \text{and assume} \quad g(r)\neq 0$$
so ##r## is a simple pole of ##f##.
we have conjugates that are singular points of ##f##,
can we say that ##r^*## is also a simple pole of ##f## because it is a complex conjugate of ##r##? if so, what property of complex functions can we invoke to avoid doing the same calculations for ##r^*##?
Why are you defining u?? But OK
The function $$f(z)=\frac 1 {z^2-a^2} $$ has poles at $$z=\pm a $$ This is a characteristic of the function and is not generally true.
  • Love
Likes Keith_McClary and docnet
. -r is not the complex conjugate of r in most cases.
And I think ##f=\frac{1}{(z-1)(z+1)^2}## satisfies your post but does not have a simple pole at both roots.
docnet said:
can we say ##-r## is also a simple pole of ##f## because it is a complex conjugate of ##r##?
##-r## is not the complex conjugate of ##r## unless ##r## is purely imaginary.
docnet said:
if so, what property of complex functions can we invoke to avoid doing the same calculations for ##-r##?
If ##g(z)## is a polynomial with real coefficients and ##r## is a root, then ##\bar {r}## is also a root.
PS. I assume that you are using '##r##' to designate a root rather than a real
No. If you insist -r is the complex conjugate of r then r is imaginary, so let's say ##r=i##. Then consider
##f(z)=\frac{1}{(z-i)(z+i)^2}##
that makes sense. sorry, think i was confusing this with the case of real valued functions always having complex valued roots in conjugate pairs. my brain is not working its best tdaoy
