Complex function of several variables
In summary, the speaker asks for the definition of continuity of a complex function of several complex variables, and also asks for clarification on the definition of metric in the complex euclidean space. The conversation then shifts to asking for book recommendations on the basic concepts of complex functions of several variables, and whether the Heine-Borel theorem holds in the complex euclidean space. The expert summarizes that the Heine-Borel theorem does hold in the complex euclidean space as it is isomorphic with \mathbb{R}^2.
gotjrgkr
90
Hi!
While studying Global Cauchy Theorems in complex analysis, I've realized that I need to know a definition of continuity of a complex function of several variables...
Thus, I ask you the definition of continuity of a complex function of several complex variables.
What I mean is ... ; Given a complex valued function F of several complex variables(F:A[itex]\rightarrow[/itex]C where A is a subset of C[itex]^{n}[/itex] for a positive integer n and C implies the complex plane), What does it mean F is continuous at a point x in A for this function??
In addition, I also ask you whether the definition of metric of a point x=(z[itex]_{1}[/itex],...,z[itex]_{n}[/itex]) in the comples euclidean space C[itex]^{n}[/itex] is just [itex]\sqrt{\sum^{n}_{i=1}\left|z_{i}\right|^{2}}[/itex] or not??
Yes, it's a metric space. So the definition of continuity is the same as in any metric space. But a metric is the distance between two points [itex]x=(z_1,...,z_n)[/itex] and [itex]x'=(z'_1,...,z'_n)[/itex] and that would be [itex]d(x,x')=\sqrt{\sum^{n}_{i=1}\left|z_{i}-z'_{i}\right|^{2}}[/itex].
Oh,, I see...
I also wanted to get such an answer for my question.
1. But, I couldn't find any book dealing with a complex function of several variables.
Of course, there's a book dealing with such a kind of field. But, it seems that almost every book omit the basic part of it such as continuity, limit, and topology related with higer dimensional complex metric space... So, could you recommend a book explaining such basic parts of the complex function of several variables ( basic concepts such as continuity, definition of metric of the space, limit, etc).
I know this is a quite a different question for the main question, but
2. I also want to ask you if in the complex euclidean space(considered as a metric space as you show) Heine-Borel Theorem still holds or not(I mean that a subset is compact in the metric space iff the subset is closed and bounded in the metric space)...
Yes. [itex]\mathbb{C}[/itex] is isomorphic with [itex]\mathbb{R}^2[/itex] and the Heine-Borel theorem holds in [itex]\mathbb{R}^2[/itex].
FAQ: Complex function of several variables
What is a complex function of several variables?
A complex function of several variables is a mathematical function that takes multiple variables as inputs and produces a complex number as its output. It can be represented as f(z1, z2, ..., zn) = w, where zi and w are complex numbers.
How is a complex function of several variables different from a regular function?
A complex function of several variables differs from a regular function in that it takes multiple complex numbers as inputs instead of just one. This allows for a more complex relationship between the input and output values.
What is the importance of studying complex functions of several variables?
Studying complex functions of several variables is important in many fields of science and engineering, including physics, economics, and engineering. It allows for the analysis and understanding of complex systems and phenomena that cannot be described by a single variable.
What are some applications of complex functions of several variables?
Complex functions of several variables are used in a wide range of applications, including image processing, signal analysis, and fluid dynamics. They are also essential in the development of mathematical models for complex real-world systems.
How can one solve complex functions of several variables?
Solving complex functions of several variables involves finding values for the input variables that result in a specific output value. This can be done using various methods, such as substitution, elimination, or graphing. Advanced techniques, such as contour integration, are also used in more complex cases.
