Complex, holomorphic and integration
In summary, a complex number is a number with a real and imaginary part, written as a + bi. A holomorphic function is one that is differentiable at every point in its domain, with a derivative that is also a complex number. Integration in the complex plane involves calculating the area under a curve, considering both real and imaginary components. The Cauchy-Riemann equations are necessary and sufficient conditions for a function to be holomorphic. Complex numbers and integration have various real-world applications in fields such as engineering, physics, and economics. They are used to solve problems involving alternating currents, quantum mechanics, and optimization, among others.
Potage11
1.Represent the following rational functions as sums of elementary fractions and find the primitive functions (indefinite integrals);
(a) f(z)= z-2/z^2 +1
2.Now, I am pretty sure that I have to split up this equation into real and imaginary parts in order to show that it is holomorphic. Once I have show that, I can use that fact to find a g'(z)=f(z)
3. The Attempt at a Solution :
So I tried f(z)=f(x+iy)= x+iy-2/(x+iy)^2 +1
u= x-2/(x+iy)^2 +1 and v= y/(x+iy)^2 +1
but by Cauchy-Reimann I am not getting du/dx=dv/dy, even though I know I should.
du/dx= -x^2 -y^2 +4x+1+4iy and
dv/dy= x^2 + y^2 +1
so I got frustrated, and attempted to do the integral anyways, first by substitution, then by parts;
This is my best attempt so far:
Int[z/z^2+1] + Int[-2/z^2+1]
Int[z/z^2+1]=1/2ln|z^2+1|
Int[-2/z^2+1]= Int[-2/(z+i)(z-i)]
I don't feel like listing everything, but by partial fractions:
Int[-2/z^2+1]= Int[i/z-i] + Int[-i/z-i]= iln(z-i) - iln(z+i)
Final answer: 1/2ln|z^2+1|+ iln(z-i) - iln(z+i) +c
I would like to know if my answer makes even remote sense, and if you guys can figure out why my cauchy-reimann equation isn't working, that would be awesome too.
Your integral looks reasonable. The reason Cauchy-Riemann isn't working is that if you are writing f(x+iy)=u(x,y)+v(x,y)*i, u and v should be real functions. You haven't gotten rid of all of the i's in them.
i'm not sure what constitutes a elementary function (i always thought rational functions were elementary!).
But the reason your not getting the cauchy reimann equations satisfied, well look at how you split up u(x,y) and v(x,y)
Notice something wrong? Remember that the C-R equations work when u and v are of the form f(x,y)=u(x,y)+iv(x,y), where u and v are REAL functions of two variables. Your u and v above have complex numbers in them!
Where is the function:
g(z) = 1/2ln|z^2+1|+ iln(z-i) - iln(z+i) +c
differentiable? We know that wherever it IS differentiable, it's derivative is your original function - but the problem is asking for the subset of the plane under which this is true.
Thanks Dick, that's such a morale boost!
So I'm trying to remove the i's:
I multiplied out x+iy-2/x^2 - y^2 + 2ixy +1
I'm pretty sure I can't do u=x-2/x^2 - y^2 +1 and v=y/2xy
I am honestly out of ideas :(
If you have a fraction like c/(a+bi), to make the denominator real, multiply top and bottom by (a-bi). That will put all of the i's in the numerator where you can collect them.
Just for fun, Maple gave me 2/z+ln(z)+z for that integral.
How it got there, I have no idea, but it looks much cleaner :)
omg, I can't believe I forgot the conjugate... thanks again
Ok, so that took forever, but it pretty much worked, thanks for the help guys!
If you differentiate that, do you get what you started with? I don't think so. I think you typed something wrong into Maple.
FAQ: Complex, holomorphic and integration
What is the definition of a complex number?
A complex number is a number that has a real part and an imaginary part. It is written in the form a + bi, where a and b are real numbers and i is the imaginary unit, defined as the square root of -1.
What does it mean for a function to be holomorphic?
A holomorphic function is a complex-valued function that is differentiable at every point in its domain. This means that the derivative of the function exists at every point and is also a complex number.
How is integration defined in the complex plane?
In the complex plane, integration is defined as the process of calculating the area under a curve in the complex plane. This involves taking into account both the real and imaginary components of the function being integrated.
What is the Cauchy-Riemann equations?
The Cauchy-Riemann equations are a set of necessary and sufficient conditions for a complex-valued function to be holomorphic. They state that the partial derivatives of the real and imaginary components of the function must satisfy a certain relationship at every point in the domain.
How are complex numbers and integration used in real-world applications?
Complex numbers and integration have numerous applications in fields such as engineering, physics, and economics. They are used to model and solve problems involving alternating currents, quantum mechanics, and optimization, among others.
