Complex Kinematics and Dynamics
In summary, two pucks, each weighing 5 kg and made of Teflon, are on a long Teflon table. Puck A is at rest on the left end of the table while Puck B is 15 m away at the right end, moving towards Puck A with an initial speed of 0.5 m/s. A person on the left pushes Puck A forward from rest with a force of 20 N at an angle of 30° to the horizontal. The coefficient of friction between the Teflon and Teflon is 0.04. Using the equations of motion, we can determine that Puck A will travel a distance of 20.41 m before striking Puck B.
Vraj Patel
Two pucks (5 kg each) made of Teflon are on a long table, also made of Teflon. Puck A is sitting at
rest on the left end of the table. Puck B is 15 m away at the right hand end of the table, and is
travelling toward Puck A with an initial speed of 0.5 m/s. A person on the left waits 1.5 seconds and
then pushes Puck A forward from rest with a force of 20 N applied at an angle of 30° to the horizontal.
If that force is maintained at a steady rate for the entire question, how far will puck A travel before it
strikes puck B? (The coefficient of friction between the Teflon and Teflon is 0.04.
2. The attempt at a solution:
Puck A
Fax = 20NSin30
Fax = 10N
Fay = 20NCos30
Fay = 17.32N
Fg = mg
Fg = (5kg)(9.8m/s^2)
Fg = 49N
Fn = Fay + Fg
Fn =17.32N + 49N
Fn = 66.32
Ff = uFn
Ff = (0.04)(66.32N)
Ff = 2.65
Fnet = Fax - Ff
Fnet = 10N - 2.65
Fnet = 7.35N
a = Fnet/m
a = 7.35N/5kg
a = 1.47m/s^2
d = v1t + 1/2at^2
15-x = 1/2(1.47)(y-1.5)^24
x = -0.74y^2 + 2.22y +13.33
Puck B
Fg = mg
Fg = 49N
Ff = uFn
Ff = (0.04)(49N)
Ff = 1.96N
Since there is no applied force Fnet = -Ff
a = Fnet/m
a = -1.96/5kg
a = -0.39m/s^2
d = v1t + 1/2at^2
x = (0.5)(y) + 1/2(-0.39)(y)^2
-0.74y^2 + 2.22y +13.33 = 0.5 - 0.195y^2
0 = 0.545y^2 - 1.72y-13.33
I then put it in the quadratic formula and got:
y = 6.77s and y = -3.61s(omited)
Puck A Distance
d = v1t + 1/2at^2
d = (0m/s)(6.77s-1.5s) + 1/2(1.47m/s^2)(6.77-1.5s)^2
d = 20.41m(This answer doesn't make sense)
Hi,
First thing that comes to mind is your decomposition of the 20 N in ##F_x## and ##F_y## ... :rolleyes:
Second thing I notice is that you deleted part 2 of the template -- not good !
Third is I miss a list of variable names. What is ##d## ? (and: are you sure that is what you think it is ? -- a drawing might help an awful lot here ! )
Likes hmmm27
Pushing down or pushing up?
Let's assume pushing down :wink:
pushing down
BvU said:
Hi,
d represents distance.
BvU said:
Hi,
I tried to upload a photo of my diagram but it wouldn't let me, but the pucks are heading toward each other.
I know. How does your expression for ##d## deal with the fact that the pucks are moving towards each other (as opposed to: moving away from each other, or moving in the same direction) ?
Hint: Puck B has no external force affecting it other than friction. So why not find out how far it can coast before coming to rest, and how long it takes to come to rest? Is it less than or greater than the 1.5 s pause before puck A starts to move?
Related to Complex Kinematics and Dynamics
1. What is the difference between kinematics and dynamics?
Kinematics is the study of motion without considering the forces that cause it, while dynamics is the study of motion in relation to the forces that act on an object.
2. What is meant by complex kinematics and dynamics?
Complex kinematics and dynamics refer to the study of motion and forces in systems that involve multiple interacting objects or have non-uniform motion. This includes systems such as rotating bodies, fluids, and systems with varying mass or shape.
3. How do we mathematically represent complex kinematics and dynamics?
Complex kinematics and dynamics are typically represented using mathematical models such as equations of motion, free body diagrams, and vector analysis. These models help us understand the motion and forces acting on a system.
4. What are some real-world applications of complex kinematics and dynamics?
Complex kinematics and dynamics have numerous applications in fields such as engineering, robotics, biomechanics, and fluid mechanics. Some examples include designing efficient car engines, analyzing the movement of human joints, and predicting the behavior of fluids in pipes.
5. What are some challenges in studying complex kinematics and dynamics?
One of the main challenges in studying complex kinematics and dynamics is the complexity of the systems involved, which can make it difficult to accurately model and predict their behavior. Additionally, the math and physics concepts used in this field can be challenging for some students to grasp.
