Complex Number Equation: Why Does a+bi=1 Not Give the Final Answer?
In summary: Every complex number has 2 representations: the $a+bi$ or cartesian form and the $r^{}e^{i\phi}$ or polar form.In this case they are asking for the cartesian form.
Raerin
46
Solve the following equations in the form a +bi.
a) z^3-1=0
b) 3z^4+i=1-2i
Apparently, the solution for a) is this:
z^3=1
z=1
z=a+bi=1
sqrt(a^2+b^2)=1
I don't understand why a+bi=1 is not the final answer. Why do you have to make it into a modulus?
Mathematics news on Phys.org
a) z^3-1=0
b) 3z^4+i=1-2i
z^3=1
z=1
z=a+bi=1
sqrt(a^2+b^2)=1
To solve a polynomial equation in complex numbers, there are always as many roots as the order of the polynomial. I'd advise simplifying as much as possible (e.g. up to z^3 = something), writing the RHS in a general exponential form, and going from there...
a) z^3-1=0
b) 3z^4+i=1-2i
z^3=1
z=1
z=a+bi=1
sqrt(a^2+b^2)=1
There are 3 solutions for a).
Every complex number can be written as the combination of the modulus and the angle (aka its "argument").
If we multiply 2 complex numbers, the result has a modulus that is the product of the 2 moduli, and it has an angle that is the sum of the 2 angles.
Suppose the modulus of $z$ is $r$, and the angle of $z$ is $\phi$.
Then the modulus of $z^3$ is $r^3$, and its angle is $3\phi$.
To solve $z^3=1$, we need that $r^3 = 1$ and that $3\phi = 2n\pi$ (where $n$ is a whole number).
It follows that the modulus $r$ must be $1$.
And that the angle $\phi = 0,\ 2\pi/3,\ 4\pi/3$.
In other words, the solutions are:
\begin{aligned}
z&=1 \\
z&=-\frac 1 2 + \frac 1 2 \sqrt 3 i \\
z&=-\frac 1 2 - \frac 1 2 \sqrt 3 i
\end{aligned}
\begin{aligned}
z&=1 \\
\end{aligned}
So how am I supposed to write that in a+bi form?
The first solution has $a=1,\ b=0$.
The second solution has $a=-\frac 1 2,\ b=\frac 1 2 \sqrt 3$.
In other words, the solutions I gave are in $a+bi$ form.
Oh, I see, I was under the impression that I only need one answer in a+bi form.
Thanks!
Thanks!
FAQ: Complex Number Equation: Why Does a+bi=1 Not Give the Final Answer?
What is a complex number?
A complex number is a number that contains both a real and an imaginary part. It is usually written in the form a + bi, where a is the real part and bi is the imaginary part, with i representing the square root of -1.
How do you add and subtract complex numbers?
To add or subtract complex numbers, simply combine the real parts and imaginary parts separately. For example, (2 + 3i) + (4 + 5i) = (2 + 4) + (3 + 5)i = 6 + 8i. To subtract, simply change the sign of the second complex number and follow the same steps.
What is the conjugate of a complex number?
The conjugate of a complex number is another complex number with the same real part, but the opposite sign for the imaginary part. For example, the conjugate of 3 + 2i is 3 - 2i.
How do you multiply and divide complex numbers?
To multiply complex numbers, use the FOIL method (First, Outer, Inner, Last). For example, (3 + 2i)(4 + 5i) = 12 + 15i + 8i + 10i^2 = 12 + 23i - 10 = 2 + 23i. To divide, multiply the numerator and denominator by the conjugate of the denominator, then simplify.
What is the complex plane?
The complex plane is a graphical representation of complex numbers, where the horizontal axis represents the real part and the vertical axis represents the imaginary part. This allows for complex numbers to be visualized and plotted as points in a plane.
