Complex numbers and completing the square
In summary, to find a complex number z in terms of a and b such that z^2 = z', one can compare the real and imaginary components of z^2 and z' and solve for x and y. Then, by substituting z = x+yi and z' = a+bi, one can solve for z in terms of a and b. Alternatively, one can also convert z' to polar form and find the roots of z^2 = z' in a straightforward manner.
HMPARTICLE
95
let z' = (a,b), find z in C such that z^2 = z'
let z = (x,y) then z^2 = (x^2-y^2, 2xy)
since z^2 = z', we have,
(x^2-y^2, 2xy) = (a,b)
comparing real and imaginary components we have;
x^2-y^2 = a,
2xy = b.
Now, this is where i am stuck.
i know i have to find z in terms of a and b.
here is an attempt at what to do next;
subtracting the second equation from the first,
x^2 - 2xy - y^2 = a - b
completing the square,
(x - y)^2 - 2y^2 = a - b.
Not asking for the answer or anything, just a push in the right direction.
You have z' as a+bi and you know then that z is a-bi so shouldn't you just solve for a in terms of b or vice versa?
x^2-y^2 = a,
2xy = b.
Write ##z' = a + ib## in polar form. Then, finding the roots of ##z^2 = z'## is straightforward.
It might be worth calculating |z| and |z2|. Also investigating what (kz)2 looks like and thinking about the implications for z.
Thanks guys! My textbook hadn't yet defined polar form so I was reluctant to use it. I solved in the way I was progressing via substitution.
I don't think it helps to convert to polar form. What you already have looks great to me except that you have written z as x+ yi and z' as a+ bi. So exactly what does z' mean here? You are treating it as just "some other" complex number but I would have interpreted it as the complex conjugate of z. If that is correct then the problem is much easier than what you are doing.
no, some other complex number (not complex conjugate), i should have denoted it as ## z_0 ## or something similar!
FAQ: Complex numbers and completing the square
What are complex numbers?
Complex numbers are numbers that include both a real component and an imaginary component. They are typically written in the form a + bi, where a is the real component and bi is the imaginary component with i representing the imaginary unit.
How are complex numbers used in completing the square?
Completing the square is a method used to solve quadratic equations. When the coefficient of the x^2 term is not 1, complex numbers are often introduced to complete the square and find the solutions to the equation.
Can complex numbers be graphed on a coordinate plane?
Yes, complex numbers can be graphed on a coordinate plane known as the complex plane. The horizontal axis represents the real component and the vertical axis represents the imaginary component.
What is the difference between a real and imaginary number?
A real number is any number that can be represented on a number line and includes both positive and negative numbers. An imaginary number is a number that, when squared, results in a negative number. It is typically represented as bi, where b is a real number and i is the imaginary unit.
How are complex numbers used in real-world applications?
Complex numbers have many applications in fields such as physics, engineering, and economics. They are used to represent alternating currents, model electrical circuits, and analyze the behavior of systems with oscillating components. They are also used in signal processing and in calculating interest rates in finance.
