Complex numbers and physical meaning
In summary: They were originally created to solve equations that could not be solved with real numbers. They have become a fundamental tool in many areas of physics, including quantum mechanics, because they allow for a more comprehensive and accurate mathematical representation of physical phenomena. While some may question their physical existence, they are a necessary and powerful tool in understanding and describing the physical world.
  • #36
akhmeteli said:
you should explain where and why his published article was wrong.
Before being able to be wrong one has to be precise about what one is talking about. The argument you point to is the simple observation that for every particular section of a complex line bundle there is a local trivialization where it is given by a real function. Sure. Notice however that:
  1. other sections than the particular chosen one that the gauge is adapted to will not have such a real representation;
  2. if we speak about Klein-Gordon or Dirac fields, then these are classical fields that still need to be quantized. They look like quantum states, but they are not, they are the input of "second quantization". An actual wave function will be a complex-value function on the space of all such KG/Dirac fields (an element in the corresponding Fock space, say) and clearly these are again complex valued functions.
But of course to just arrive at the conclusion that it is false that quantum physics may work with just real valued wave functions only, you don't need to detour into relativistic wave equations. Just open any basic QM textbook and check that it all breaks down in p. 3 if you insist in replacing all complex numbers by real numbers.
Likes bhobba
  • #37
muscaria said:
I didn't really appreciate or think about what you were saying, sorry about that, I'll try to pay attention more carefully in the future and "listen". Unfortunately I don't have access to my University portal and couldn't find Schrodinger's paper you mention in free view..
So if you end up with a real wavefunction, the gauge potential coupled to the charge must then be identical to the mechanical momenta along the streamlines (integral curves/thinking quantum Hamilton Jacobi formalism) traced out by every initial infinitesimal volume of the wave, right? If one is to describe any real non-stationary wavefunction that is. So that the gauge potential effectively serves as a velocity field for the wave?
It's just I'm finding it a bit hard because usually the vector potential couples to the current and simply curves the path taken by the current without changing its magnitude, but you need current in the first place for this to take effect. Or is the idea to find a condition for a dynamic scalar potential field which somehow constrains the phase to 0 everywhere, and the vector potential then serves as a mechanical momentum field for the wave?
Thinking again in H-J/de Broglie-Bohm terms, a real wavefunction would give the following scenario for some free space H in the non-relativistic limit:
Taking $$i\partial_t\Psi = \left[\frac{(\textbf{p}-\textbf{eA})^2}{2m} -e\phi\right]\Psi$$
and $$\Psi=Re^{i\theta}$$
where I'll take the phase to be constant over space and time after our calculation. Otherwise we end up simply with a continuity equation and no quantum H-J equation and we lose potential insight into a possible relation existing between the gauge potential and the quantum potential which would yield an effectively real wavefunction. So doing that the usual pair of equations of continuity and QHJ: $$\nabla\cdot(R^2\textbf{v})+\frac{\partial R^2}{\partial t}$$ $$\frac{\partial\theta}{\partial t}+\frac{(\nabla\theta -e\textbf{A})^2}{2m} -e\phi + Q =0$$ reduce to
$$\nabla\cdot\left(R^2\frac{\textbf{A}}{m}\right)=\frac{\partial R^2}{\partial t}$$ $$\frac{(e\textbf{A})^2}{2m} -e\phi + Q =0.$$
Is the last equation the gauge condition which gives rise to a real wavefunction? I'm not sure if what I've done is wrong, but if it isn't then it would seem like the quantum potential ##Q\propto\frac{\nabla^2R}{R}##, which depends on the form of the wave, and the electromagnetic potentials are constrained, giving rise to a situation where the form of the wave constrains the E-M field potentials which in turn dictates the current of the wave from the role taken on by the vector potential as a velocity field. Hmm...seems like a non-linear gauge condition in any case, with some effective feedback between wave and EM field?
I'm guessing carrying this out relativistically may lead to a more symmetric gauge condition, which must be what Schrodinger did for the K-G field? Any thoughts? Also, does this have any significant implications for the divergence of A? Is this complete rubbish? :p
Thank you very much for your interest.
As for Scroedinger's article, I believe I reproduce much of its contents in my articles:
http://akhmeteli.org/wp-content/uploads/2011/08/JMAPAQ528082303_1.pdf
(Journal of Mathematical Physics, beginning of Section II)
http://akhmeteli.org/akh-prepr-ws-ijqi2.pdf
(International Journal of Quantum Information, beginning of Section 3. You may be also interested in my paraphrase of the Dirac's 1951 article (that inspired the Schroedinger's 1952 article) in Section 2. Another interesting thing there - the Lagrangian of Eq. (14) (derived by other people) - the matter field is real there, but the physics is the same as with the standard Klein-Gordon-Maxwell Lagrangian)
http://link.springer.com/content/pdf/10.1140/epjc/s10052-013-2371-4.pdf
(European Physical Journal C, beginning of Section 2)
However, when you have a chance, you might wish to read the beautiful but almost forgotten Schroedinger's article.
I confess that your post is a bit difficult for me: your point of view and (physical) language seem unusual. Furthermore, I was not much interested in the non-relativistic case, as the relativistic case is much more realistic.
Indeed, the 4-potential of electromagnetic field in the unitary gauge (where the scalar wave function is real) has the same direction as the current of the matter field in every point for the Klein-Gordon-Maxwell system, but I suspect this is not so for the Dirac-Maxwell system.
You mention de Broglie-Bohm, and I show that the electromagnetic field in the unitary gauge plays the role of the guiding field of dBB.
Maybe I'll try to answer your specific questions later.
  • #38
[URL='https://www.physicsforums.com/insights/author/urs-schreiber/']Urs Schreiber[/URL] said:
  1. Yes, but those "other sections" are not necessary to describe the physics of this system, so you can do just with real wave functions (the other sections give the same physics)
  2. [URL='https://www.physicsforums.com/insights/author/urs-schreiber/']Urs Schreiber[/URL] said:
    [*]if we speak about Klein-Gordon or Dirac fields, then these are classical fields that still need to be quantized. They look like quantum states, but they are not, they are the input of "second quantization". An actual wave function will be a complex-value function on the space of all such KG/Dirac fields (an element in the corresponding Fock space, say) and clearly these are again complex valued functions.
  3. I guess this paragraph of yours hints that you need more sophisticated arguments than those of your previous post to prove that real functions are not enough. And I am not sure your latest argument is waterproof either. Classical fields in 3+1 dimensions can have the same unitary evolution as quantum field theories (please see, e.g., Section 4 of my article http://link.springer.com/content/pdf/10.1140/epjc/s10052-013-2371-4.pdf in European Physical Journal C, where I use other people's results)
I don't quite see how "it all breaks down in p. 3". It may be more difficult to describe wave functions of non-relativistic quantum physics using only real functions, but we don't need it, as the relativistic wave equations are more realistic.
Let me summarize. You can do just with real functions at least in some general and important cases, so one can indeed at least question the absolute necessity of complex functions in quantum theory.
  • #39
Looks that way for Klein-Gordon-Maxwell, not sure about Dirac-Maxwell, probably not.
[QUOTE="muscaria]It's just I'm finding it a bit hard because usually the vector potential couples to the current and simply curves the path taken by the current without changing its magnitude, but you need current in the first place for this to take effect.[/QUOTE]
Let me note that current arises in the Maxwell equations as well, not just in the Klein-Gordon equation.
[QUOTE="muscaria]Or is the idea to find a condition for a dynamic scalar potential field which somehow constrains the phase to 0 everywhere, and the vector potential then serves as a mechanical momentum field for the wave?[/QUOTE]
I am not sure I quite understand this phrase. Scalar potential does not seem to define the phase uniquely: for example, you can change the phase by a constant without changing the scalar potential. Even the expression "scalar potential" is a bit strange in this context - I guess you mean a component of the 4-vector potential.
As for the idea... It is the same as in Dirac-1951 and Schroedinger -1952: the Maxwell equations in a certain gauge can describe both the electromagnetic field and the matter field.
[QUOTE="muscaria]Thinking again in H-J/de Broglie-Bohm terms, a real wavefunction would give the following scenario for some free space H in the non-relativistic limit:
I'm guessing carrying this out relativistically may lead to a more symmetric gauge condition, which must be what Schrodinger did for the K-G field? Any thoughts? Also, does this have any significant implications for the divergence of A? Is this complete rubbish? :p[/QUOTE]
I did not read this very carefully, but I don't like the idea of making the wave function real in a non-relativistic equation: on the one hand, it gives a gauge choice that is different from the choice required to make real the wave function in a relativistic wave equation, on the other hand, the relativistic equation is more realistic.
Likes The Count
  • #40
Can you please give me more details about this?
What do you mean the "matter field"?
Where I can find bibliography on this subject?
  • #41
The matter field is the field describing massive particles, say, electrons/positrons, e.g., the Klein-Gordon field or the Dirac field.
For bibliography and details, please see my published articles quoted in post 37 in this thread. The IJQI paper cites Dirac-1951 and Schroedinger-1952 articles. A recent preprint http://arxiv.org/abs/1502.02351 shows how to rewrite the Dirac equation for one real wave function in a general case.
The most representative examples can be found in the EPJC article. For example, after a gauge transform, the matter field can be algebraically eliminated from scalar electrodynamics (Klein-Gordon-Maxwell electrodynamics), and the resulting equations define independent evolution of electromagnetic field. Thus, modified Maxwell equations in the unitary gauge (where the scalar matter field is real) describes both electromagnetic field and the matter field).
  • #42
Richard Feynman's book QED The Strange Throery of Matter and Light used clever graphics to illustrate what the OP asks. At the very least, you see that if you simplify those little vectors to real numbers and add them up, you get the wrong answer. The vectors must have both magnitude and direction to get the right answer. That is what complex numbers do for us.
OP, if you want to learn more. I reccomend Feynman's book.
  • #43
Thank you all for your time.
You gave me a lot of homework.
I really appreciate the interest that you showed to the question.
I have to say that finally I did not get an answer, but maybe there is not any (yet).
I must insist that there is no way that a mathematical tool used in physics not to have a physical interpretation.
The only close enough interpretation that seems to have a point to me is the relation of imaginary part with time.
I mentioned it in my first question, that the unitary matrix of the progression of time is imaginary.
I found it in wikipedia on Henri Poincaré and Minkowski 4 dimensional space.
I found a relation to some of your answers too.
I would appreciate if anybody could help...
  • #44
I thought you got many answers.
That's been the whole issue here. You have decided what is just a mathematical tool and what is a physical explanation. Physics is written in the language of math. The math is the physical explanation.
Imaginary time is a trick associated with Wick rotation:
https://www.physicsforums.com/insights/useful-integrals-quantum-field-theory/
But of course you do not accept mathematical tricks as physical. That means many many things will perplex you.
Thanks
Bill
  • #45
Thanks again for your interest in my stubbornness.
I want first to thank all of you once more for your time and let you know that it was appreciated.
I must repeat that you all helped me a lot to think, but, as I see it, I did not understood a clear physical interpretation to be given.
I may be wrong, but for me mathematical interpretation is not enough for physics. I cannot imagine relativity to leave the curvature of spacetime, without the interpretation of mass/energy.
In this point I would prefer to use Plank's quote for black body radiation.
"Six years I struggled with the problem of thermal equilibrium radiation and matter without success. I knew that this problem was fundamental to physics. I knew the formula that represents the energy distribution of the spectrum. A theoretical interpretation had to be given, at all costs, no matter how high."
Thanks for imaginary time link, I will study it and come back.
