Complex numbers: Conformal mapping
In summary, conformal mapping is a mapping which preserves angles. To understand conformal mapping, you need to have studied complex variables at least through the properties of an analytic function.
Niles
1,866
Hi all.
I have seen a conformal mapping of z = x+iy in MAPLE, and it consists of horizontal and vertical lines in the Argand diagram (i.e. the (x,y)-plane).
On the Web I have read that a conformal map is a mapping, which preserves angles. My question is how this mapping is constructed? I.e., how is it that I find that the conformal mapping of z = x+iy is horizontal and vertical lines?
Regards,
Niles.
To understand conformal mapping, you need to have studied complex variables at least through the properties of an analytic function. Analytic functions are the only ones that possesses conformal maps (conformal meaning that angles between two curves are the same in both original and mapped geometries). Since all books on complex variables also cover conformal mapping, I presume that you haven't had a chance to study this topic yet. I recommend starting with Churchill's "Complex Variables" which is written very clearly.
What do the contours of the lines x=constant and y=constant in the x-y plane look like in the z=x+iy Argand plane? This is a pretty easy conformal mapping.
I do know about analytic functions and the Cauchy-Riemann conditions.
So I just have to plot Re(z) = constant and Im(z)=constant, and then I get the conformal mapping?
Not quite. If z=x+iy and f(z)=u(x,y)+iv(x,y), then mapping that takes the point (x,y) in the plane to (u(x,y),v(x,y)) is the conformal mapping. It's the same as taking z->f(z) in the Argand plane.
Ok, so if we take f(z) = z = z+iy, then we have (x,y) -> (u,v) = (x,y). How is it that this results in constant curves?
If you plot, say u(x,y)=constant in the xy plane the resulting curve will map to a vertical line in the uv plane, right? v(x,y)=constant corresponds to a vertical line in uv. Try it with f(z)=z^2. f(z)=z is almost too easy to convey the idea clearly. You should get two sets of orthogonal hyperbolae.
For f(z)=z^2 we have that u(x,y) = x^2-y^2 and v(x,y) = 2xy.
I want to plot this in (u,v), so I insert u(x,y) in v(x,y) and get
v(x,y)=2*sqrt[u(x,y)+y^2]*y.
Is this correct?
Nooo. A line of constant u, u=C corresponds to x^2-y^2=C in the xy plane right? That's a hyperbola, right?
Ok, a few issues:
1) When you say (x,y)-plane, do you mean the Argand-diagram or the usual (x,y)-coordinate system?
2) Ok, so the reason why we equal u and v to constants is because we want the contours (atleast I think this is the reason).
So u(x,y) gives us 1 hyperbola, and 2xy = constant is the other one?
1) either one. It doesn't make much difference. They both look alike. 2) u and v are CONSTANT because those are horizontal and vertical lines in the uv plane. You want to find the corresponding curves in the xy plane. Yes, 2xy=constant is the other. Except they aren't just '1 hyperbola'. There is a different hyperbola for every different choice of the constant.
What I meant was that in the Argand diagram x and y are part of z, but in the normal (x,y), then x is input and y is output. I was just wondering if I had to isolate y or something when doing this, but I guess it is apparent what the curves look like (like the hyperbola).
No, don't think of y as a function of x. They are both independent variables. w is a function of z.
Ok, great. Thanks for helping - I really appreciate it.
Related to Complex numbers: Conformal mapping
What are complex numbers?
Complex numbers are numbers that contain both a real and an imaginary part. They are written in the form a + bi, where a is the real part and bi is the imaginary part with i being the square root of -1.
What is conformal mapping?
Conformal mapping is a mathematical technique used to map one complex plane onto another while preserving angles. This means that the shapes and angles of the original plane are maintained in the new plane.
What is the significance of conformal mapping?
Conformal mapping has various applications in mathematics, physics, and engineering. It can be used to solve problems involving fluid flow, heat flow, and electrical fields, as well as in the study of complex functions and their properties.
How are complex numbers used in conformal mapping?
Complex numbers are used in conformal mapping to represent points on the complex plane. By manipulating these numbers using mathematical operations, the mapping can be achieved while preserving angles and shapes.
What are some common examples of conformal mapping?
Some common examples of conformal mapping include the Mercator projection used to create maps of the Earth's surface, the stereographic projection used in cartography, and the z-transform used in signal processing.
