Complex Numbers: Finding the least value of |z-w|
In summary, the given inequalities describe two circular discs with centers at (3,2) and (7,5) and radii 2 and 1 respectively. The minimum distance between z and w can be found by considering the intersection of the circles and the line joining their centers. The minimum value of |z-w| is achieved when the points z and w are at maximum distance from each other on the circles.
ecy5maa
30
The complex numbers, z and w satisfy the inequalities |z-3-2i|<=2 and |w-7-5i|<=1
Find the least possible value of |z-w|
No clue at all.
Since its |z-w| i figured that the least possible value will only be when both are max. I tried finding the maximum distance of each complex number by using [tex]\sqrt{}(x^2+y^2)[/tex]+r and came up with a Z=[tex]\sqrt{}13[/tex]+2 and W being [tex]\sqrt{}74[/tex]+1
Both of which are incorrect as z-w gives 4 while the answer is 2
The triangle inequality gives you
[tex]|z-w| \leq |z| + |w|[/tex]
This gives you an upper bound for the distance.
You can also use the triangle inequality to obtain a lower bound, as follows:
[tex]|z| = |(z - w) + w|[/tex]
[tex]|w| = |(w - z) + z|[/tex]
Now apply the triangle inequality to the right hand sides of both of the above equalities and rearrange to get a lower bound for [itex]|z - w|[/itex].
They describe two circular discs. The closest points will be on the line between their centers.
Could you kindly explain this a little bit:
I first get |z| by using |z|<= 2+|3+2i| and then put z= 2+|3+2i| in the formula for |z| that u have given?
OK, to keep the notation simpler, let [itex]z_0 = 3 + 2i[/itex] and [itex]w_0 = 7 + 5i[/itex].
Then you can write
[tex]z - w = (z - z_0) - (w - w_0) + (z_0 - w_0)[/tex]
Therefore
[tex]|z - w| = |(z - z_0) - (w - w_0) + (z_0 - w_0)|[/tex]
You can apply the triangle inequality in reverse to obtain
[tex]|(z - z_0) - (w - w_0) + (z_0 - w_0)| \geq | |z_0 - w_0| - |(z - z_0) - (w - w_0)||[/tex]
Now, [itex]|z_0 - w_0|[/itex] is just a positive constant (call it [itex]c[/itex]), so the minimization of the right hand side is easy. The task is to mimimize
[tex]|c - |(z - z_0) - (w - w_0)||[/tex]
If there are [itex]z,w[/itex] that make this zero, then the minimum is zero. Otherwise, the minimum is achieved by maximizing [itex]|(z - z_0) - (w - w_0)|[/itex], which you can easily do by using the triangle inequality again.
By the way, this procedure will give you a lower bound. You still have to justify why there are [itex]z,w[/itex] that achieve the lower bound. (Think: under what condition does the triangle inequality become an equality?)
Do u mean it will be |3+2i - ( 7+5i)|?? but that gives the answer 5 while it is 2 in the book
No. |z - (3+2i)| is the distance from x + yi to 3 + 2i. If that is equal to 2 it says the point (x,y) is distance 2 from the point (3,2) in the xy plane. That describes a circle and the inequality describes the interior of that circle. Similarly for the other inequality. Draw a picture.
Likes PeroK
hmm..I get this part. You are saying that Z and W lie on the circumference of the circle with center 3,2 and radius 2 and center 7,5 with radius 1 right?
I cannot get beyond this point. The question is asking for the minimum value of |z-w| so this means that both Z and W should be at maximum distance from the origin?
Then you can write
Therefore
Thanks! Although i would like to find a simpler way to do it as well.
Ok by drawing a picture the shortest distance between Z and W is coming out too be[tex]\sqrt{}74[/tex]-[tex]\sqrt{}13[/tex]-3=1.9996
I did this by calculating W by [tex]\sqrt{}74[/tex]- 1 and Z by [tex]\sqrt{}13[/tex] + 2, then subtracted the distance W from Z to get its smallest value.
I would be greatly obliged if someone can check my method, or better yet do the whole question.
Thanks in advance
Why would you think that? It asks for the minimum distance between z and w, nothing about how far from the origin they are. As I said in my first post, the points closest to each other on the circles will be on the line joining the centers. Draw a picture. Look at it. It is simple geometry. You can do it in your head.
Likes PeroK and chwala
Another thing you can do to simplify the problem is to translate and rotate the points so that one of them is at the origin and the other one is on the positive x axis.
The question remains the same: what is the minimum distance between two points given that they have to live within disks of a certain radius around the points. Rotating and translating the picture will not change the answer, but it can make it easier to picture (and compute) the answer.
Related to Complex Numbers: Finding the least value of |z-w|
1. What are complex numbers?
Complex numbers are numbers that consist of a real part and an imaginary part. They are represented in the form a + bi, where a is the real part and bi is the imaginary part (with i being the imaginary unit equal to the square root of -1).
2. How do you find the least value of |z-w|?
To find the least value of |z-w|, you can use the distance formula from analytic geometry, which is the square root of the sum of the squares of the differences between the real and imaginary parts of z and w. This formula gives the distance between two points on a complex plane, and the least value of |z-w| would be the smallest distance between the points.
3. What is the significance of finding the least value of |z-w|?
Finding the least value of |z-w| is important in various mathematical applications, particularly in optimization problems. It can also be used in determining the closest distance between two complex numbers, which can have practical applications in fields such as physics, engineering, and computer science.
4. Can the least value of |z-w| be negative?
No, the least value of |z-w| cannot be negative. The absolute value of a complex number is always a positive real number, so the least value of |z-w| would also be a positive real number.
5. How can complex numbers be visualized on a complex plane?
Complex numbers can be represented and visualized on a two-dimensional complex plane, with the real axis representing the real part and the imaginary axis representing the imaginary part. The complex number a + bi would be plotted on the plane as the point (a,b). This allows for a graphical representation of complex numbers and operations on them.
