- #71
- 28,059
- 19,574
A. Neumaier said:Yes, but it doesn't change anything. Any theory represented in first order logic is independent of the model used to represent it.
Guten Appetit!
No. Most sets of rationals are not definable. (There are uncountably many sets of rationals, but only countably many of them can be defined.)
Yes.
No. Their number is countable but they do not form a model for the reals since the supremum axiom fails for them.
This is not a well-defined set, as you specify neither the meaning of the ##a_i## nor the meaning of ##\dots##.
It is a well-defined set in the usual mathematical framework. All of mathematics generally deals with objects being defined only by their properties. E.g. let ##f## be a continuous function, of which there are uncountable many.
You have introduced a non-standard approach where numbers, sets and functions (presumably) are restricted to ones that can be specified by some further criteria. Leaving the remaining numbers, sets or functions "anonymous". Presumably , however, these objects still exist in the new mathematical framework. For example, you don't have any uncountable sets of numbers with non-zero measure over which to integrate, unless you include all the real numbers..
In particular, you are now confusing your new definition of a definable set with the concept of a well-defined set in standard analysis.
Finally, there is no paradox in standard real analysis with the set of all real numbers. It's not a definable set in your terminology but that doesn't make it paradoxical.
