MHB Complex numbers simplification
To find \( z^5 \) where \( z = e^{(2-\frac{i \pi}{4})} \), the power rule for exponents can be applied. This results in \( z^5 = e^{5(2-\frac{i \pi}{4})} \). Expanding \( (2-\frac{i \pi}{4})^5 \) is unnecessary and more complex than needed. The simplified expression provides a clearer solution. Understanding the application of the power rule is key to solving such problems efficiently.
Guest2
If $z = e^{(2-\frac{i \pi}{4})}$ what's $z^5$?
The only way I can think of doing this is expanding $(2-\frac{i \pi}{4})^5$, but I think I'm supposed to use a simpler method (not sure what it's).
Mathematics news on Phys.org
Hi Guest, (Smile)
Let's substitute and apply a power rule:
$$z^5=\left(e^{(2-\frac{i \pi}{4})}\right)^5
=e^{5(2-\frac{i \pi}{4})}
I like Serena said:
Hi Guest, (Smile)
Thank you, I like Serena. I get it now. (Smile)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
