MHB Complex numbers simultaneous equations
The discussion revolves around solving the simultaneous equations involving complex numbers: z = w + 3i + 2 and z² - iw + 5 - 2i = 0. Initial attempts to substitute and simplify led to confusion and incorrect results. A suggested method involves substituting z into the second equation and applying the quadratic formula. Ultimately, the solutions found are z = 2i with w = -i - 2, and z = -i with w = -4i - 2. The thread emphasizes the importance of careful substitution and algebraic manipulation in solving complex equations.
lemonthree
Hi all, I have spent a couple of hours on this perplexing question.
Solve the simultaneous equations:
z = w + 3i + 2 and z2 - iw + 5 - 2i = 0
giving z and w in the form (x + yi) where x and y are real.
I tried various methods, all to no avail.
I have substituted z into z2 , I got the wrong answers.
I also tried letting z be (a + bi) and w be (c + di) and tried to combine the 2 equations together, and I got a horrible mess with many unknowns.
Please help me, thank you!
Mathematics news on Phys.org
Just substitute $z=w+3i+2$ in $z^2-iw+5-2i=0$ and use the fact that $(a+b+c)^2=a^2+2ab+2ac+b^2+2bc+c^2$.
What do you get?
What do you get?
I got w = -2 + 2i or -2 - 7i, which is not the right answer :o
$z = w + 3i + 2 \implies w = z-3i-2$
$z^2 - i(z-3i-2) + 5-2i = 0$
$z^2 - iz + 2 = 0$
now use the quadratic formula to solve for $z$ ... you should get
$z = 2i \implies w = -i-2$
or
$z =-i \implies w = -4i-2$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
