MHB Complex Numbers VI: Finding Least Value of |z-2√2-4i|
The discussion focuses on finding the least value of |z-2√2-4i| given the constraints |z-4i|≤√5 and π/4≤arg(z+4)≤π/2. Participants have sketched the loci on an Argand diagram and are exploring the intersection of these sets. The key challenge is determining the shortest distance from a point to a semi-disk, which involves identifying the complex number z_1 that minimizes this distance. There are also technical issues regarding the use of LaTeX for mathematical expressions. Ultimately, the goal is to find the exact form of z_1 and the corresponding least value.
Punch
Sketch on an Argand diagram the set of points satisfying both |z-4i|<=\sqrt{5} and \frac{\pi}{4}<=arg(z+4)<=\frac{\pi}{2}.
I have already sketched the 2 loci. The problem lies in the following part.
Hence find the least value of |z-2\sqrt{2}-4i|. Find, in exact form, the complex number z_1 represented by the point P that gives this least value.
Mathematics news on Phys.org
Over which set of z? The intersection defined in the first part? It seems that you need to find the shortest distance from a point to a semi-disk.
Why don't you wrap the [tex]...[/tex] tags around your formulas?
Why don't you wrap the \(z_1\) tags around your formulas?
Yes, how do I then find the complex number z_1 in the following part?
I tried using the latex but they didnt seem to work
See the following picture.
Type [tex]\frac{\pi}{4}\le\arg(z+4)\le\frac{\pi}{2}[/tex] to get \frac{\pi}{4}\le\arg(z+4)\le\frac{\pi}{2}.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
