Complex products: perpendicular vectors and rotation effects
If you just switch the components of the other vector, you don't get a negative slope.In summary, the concept of perpendicularity and rotation plays a critical role in the definition of multiplication in all number spaces. In the complex plane, this is evident in the calculation of products of complex numbers and the use of negation in the real part. This concept can also be extended to higher number spaces such as quaternions and octonions, where rotations and perpendicularity have even more profound effects. While some may argue that these concepts are arbitrary human inventions, they have proven to be fundamental and consistent with other mathematical operations.
Ventrella
29
My question is perhaps as much about the philosophy of math as it is about the specific tools of math: is perpendicularity and rotation integral and fundamental to the concept of multiplication - in all number spaces?
As I understand it, the product of complex numbers x = (a, ib) and y = (c, id) can be calculated as:
( (ac-bd), i(ad+bc) )
I noticed that this expression uses a particular mixing of the real and imaginary components of x and y, and it includes a negation in the real part. And I understand that this negation is related to the square root of -1. I have noticed a similarity between the multiplication of complex numbers and the operation for finding the perpendicular of a 2D vector (x, y) as (-y, x). The other perpendicular is (y, -x). It appears that negation of one component is critical for calculating perpendicularity.
Is there a way to express the concept of multiplication in a general way such that the behaviors of complex numbers is consistent with that of real (1-dimensional) numbers? Or do these properties of perpendicularity, negation, and rotation apply only to the higher number spaces (complex, quaternion, octonian, etc)? Might there be higher-order behaviors in the higher-dimensioned number spaces that are supersets of rotation and perpendicularity that our 3D brains cannot visualize or even comprehend?
Finally, what higher-order principle dictates that multiplication in higher-order number spaces should involve rotational effects? Some philosophers of mathematics would argue that these techniques are an invention of humans - an extrapolation of the concept of multiplication of real numbers to higher dimensions, which is arbitrary (although extremely useful and fully-consistent with all other mathematical concepts and operations).
Mathematics news on Phys.org
No. The definition of multiplication must allow it to represent rotations. The regular 2D vector space, R2 does not have a multiplication that represents rotation. There is a dot product and a cross product but not a product that is a rotation. That is one of the great advantages of the complex plane over R2. In three dimensions, the quaternions have operations for rotations, but the 3D vector space, R3, needs something like rotation matrices.
One thing to notice is that a multiplication which represents rotations in the complex plane has some tremendous advantages: Every rotation has an inverse, which is a rotation in the opposite direction. So there are always multiplicative inverses and division is defined. That allows a derivative based on (f(z)-f(z0))/(z-z0), which mimics the derivative of introductory calculus. This leads to very profound results.
PS. I like your fractal avatar.
In R3, the vectors (1,1,0) and (0,0,1) are perpendicular. I don't see how your idea would apply to that. The general condition for two vectors to be perpendicular is that they have a zero dot product. The vectors A=(a1, a2, ..., an) and B = (b1, b2, ..., bn) are perpendicular if and only if Σaibi = 0. That works in any number of dimensions and can be generalized to orthogonal functions, and is a better way to think of "perpendicular" in equation form.
The key point here is slope. The vector <x, y> has a slope of ##\frac y x##. This is easy to see if you sketch the line segment from the origin to the point (x, y). In the plane, two line segments are perpendicular if their slopes are negative reciprocals of each other; that is, the slopes multiply to make -1. Clearly a slope of ##\frac {x} {-y}## will do, as will ##\frac {-x} y##. The vector <-y, x> has a slope of ##\frac x {-y}##.
The vector <y, -x> "points" in the opposite direction that <-y, x> does. Again, the key point for vectors in the plane is that their slopes are negative reciprocals.
Related to Complex products: perpendicular vectors and rotation effects
1. What are perpendicular vectors?
Perpendicular vectors are two or more vectors that intersect at a 90 degree angle. This means that they are orthogonal to each other and do not share any common direction or magnitude. Perpendicular vectors are commonly used in physics and mathematics to describe the relationship between two objects or quantities.
2. How do you determine if two vectors are perpendicular?
To determine if two vectors are perpendicular, you can use the dot product or cross product method. The dot product of two perpendicular vectors will equal zero, while the cross product will result in a vector that is perpendicular to both original vectors. Another way is to use the angle between the two vectors - if it is 90 degrees, then they are perpendicular.
3. What is the significance of perpendicular vectors in complex products?
In complex products, perpendicular vectors are important because they allow us to describe the rotation effects of the product. When two perpendicular vectors are multiplied together, the resulting vector will be perpendicular to both original vectors, indicating a rotation in the product. This is useful in fields such as engineering and computer graphics.
4. How do you calculate the rotation effect of a complex product using perpendicular vectors?
To calculate the rotation effect of a complex product using perpendicular vectors, you can use the cross product method. Take the two original vectors and find their cross product. The resulting vector will have a magnitude equal to the product of the magnitudes of the original vectors and a direction perpendicular to both original vectors, indicating the rotation effect of the product.
5. Can perpendicular vectors ever be parallel?
No, perpendicular vectors can never be parallel. Perpendicular vectors, by definition, intersect at a 90 degree angle and do not share any common direction. Parallel vectors, on the other hand, have the same direction and may have different magnitudes. Therefore, it is impossible for two vectors to be both perpendicular and parallel.
  • General Math
  • General Math
  • Quantum Physics
  • Linear and Abstract Algebra
  • General Math
