Complexation Equilibria problem
  • Thread starter Saitama
  • Tags
    Equilibria
In summary, Homework Statement The Homework Equations state that when AgBr is dissolved in NH3, Ag+ is consumed, and the NH3 is left with a 0.2 M concentration of the Ag+ complex.
Saitama
4,243
93
How much AgBr could dissolve in 1.0 L of 0.40 M NH3? Assume that Ag(NH3)2+ is the only complex formed. [Kf=1*108 ; Ksp=5*10-13]
Let Ag+ and Br- formed from AgBr be x. Since Ag+ form a complex with NH3, let the amount of Ag+ remaining be x-y, hence amount of NH3 remaining is 0.4-2y and amount of complex formed is y.
Therefore
[tex]K_{sp}=(x-y)x[/tex]
[tex]K_f=\frac{y}{(x-y)(0.4-2y)^2}[/tex]
I hope my equations are correct.
Now the trouble is solving the equations. I can easily plug them in a calculator and get the answer but I want to know if there is a way to do this problem without using one.
Since Kf is so large, I think that ammonia will be almost completely used and hence, y=0.2 M but I don't see if this helps or if my assumption is correct.
Any help is appreciated. Thanks!
I think you can solve the problem this way:
reaction 1:
[tex]AgBr(s) => Ag^+ + Br^-,\,\,\,K_{sp}[/tex]
reaction 2:
[tex]Ag^+ + 2NH_3=> Ag(NH_3)_2^+,\,\,\,K_f[/tex]
the total reaction:
[tex]AgBr(s) + 2NH_3=> Ag(NH_3)_2^+ + Br^-[/tex]
[tex]K=K_f*K_{sp}=5*10^{-5}=\frac{[Br^-]*[Ag(NH_3)_2^+]}{[NH_3]^2}[/tex]
[tex]K=5*10^{-5}=\frac{x*x}{(0,4-2x)^2}[/tex]
that's another equation, I believe...
where
x >> sqrt(Ksp(AgBr))
reaction 1:
reaction 2:
the total reaction:
where
I was expecting someone to post this. I have already seen this way to solve the problem and it does give the right answer. But what's wrong with my approach?
from the first equation you have assumed [Ag^+] not equal [Br^-]
that's wrong...you said above that equation: "Let Ag+ and Br- formed from AgBr be x"
i.e:
[Ag^+] equal [Br^-] = x
i.e:
Yes, I did say that but Ag+ gets consumed when it forms complex with ammonia. I assumed that the amount of Ag+ getting consumed be y.
Anyone?
These things sound simple then when you start they seem to become quite confusing, hard to get in focus. It is good IMHO to do a complete treatment as Pranav tries, but also good to look at all approximations and then at end compare.
(Premiss - I don't know what the official definition of these constants are, and whether molarity is built into them so they are dimensionless. I am always happier to see units, like M-2 for this Kf but maybe that's not today's textbook.)
For approximations, I would say that the complex is pretty tight, and AgBr is pretty insoluble, and I would expect therefore the ammonia to near 100% complex the Ag+, so it would be an 0.2M solution of complexed Ag, 0.2M Br- to first approximation. To a second approximation at first sight the amount of free Ag+ would be a very insignificant amount more. I mean it would be much less even than in solution of saturated AgBr. Because then you have only a tiny amount of Br- in solution. But here you have around 0.2M Br- held in solution as it were by complexing of the Ag+ which is still charged. So the solubility product will give an utterly minuscule amount of Ag+ in solution, much less even than AgBr on its own. Easily calculated from the Ksp equation putting [Br-] = 0.2 (M?) giving free [Ag+] = 2.5X10-12M (as compared with a whopping 7X10-7M for ordinary saturated AgBr solution) if I am not mistaken. So I'm thinking incomplete complexation might be the more important effect at second approximation.
In connection with what I just said, if I understand, janhaa would be wrong to say [Ag^+] equal [Br^-] if by [Ag^+] he means the free Ag+ concentration. The Ag+(NH3)2 is still charged and this nearly = [Br-]. However I agree it is a good idea to multiply Ksp by Kf and get rid of at least one nuisance factor. I mean I think you get
Ksp.Kf = (x - y)x/[0.4 - 2y]2 which is no worse than a quadratic.
The OP said he has has done the complete calclations so it would be interesting to know the results and the comparisons with the approximations I sketched.
I too agree that [Br-] should be 0.2 M as Ag+ gets used up again and again in forming the complex but janhaa's method gives a very small value for [Br-] So do we have to use Kf here?
Why do you get (x-y) in the numerator? If we consider the net reaction, K comes out to be very small, so it is safe to assume that y is much smaller than 0.4 . If 2y amount of NH3 is used up, we get y amount of the complex and the Br- ion. Hence
[tex]K_{sp}.K_f=\frac{y\cdot y}{(0.4-2y)^2} =\frac{y^2}{0.16}[/tex]
Solving this, y=2.8*10^(-3). This is the amount of AgBr which dissolves in the ammonia solution.
From your first comment that they could be easily plugged in etc. I thought you had done the exact calculations. If so please give us the results, so we see how they compare with mine below.
I thought "ammonia will be almost completely used" too, and it is a mistake, in fact rather little is used, from which there are mistakes in my comments in earlier posts, in particular the eventual free [Ag+] is very low but not nearly as low as I estimated. Almost all the [Ag+] is complexed, true, but there can be very little free [Ag+] in solution in equilibrium with it because it precipitates - two factors acting opposite ways.
If you don't mind I found your notation confusing so will use explicit chemical notation.
I start from your equations
Ksp = [Ag+][Br-] = 5.10-13 M (1)
Kf = [Ag+(NH2)2]/[Ag+][NH3]2 = 108 (2)
The total AgBr is
[Ag+] + [Ag+(NH3)2] = [Br-] (3)
But because of the tightness of the complex we can approximate
[Ag+(NH3)2] ≈ [Br-] (4)
As before we have
KspKf = [Ag+(NH3)2][Br-]/[NH3]2
Using (4) plus other things above, we have to very good approximation
5.10-5 = [Br-]2/(0.4 - 2[Br-])2
so we have only a square root to take instead of solving a quadratic equation. Then
0.00707 = [Br-]/(0.4 - 2[Br-])
Only now can I see that little of the ammonia (about 1%) is complexed. I don't know if anyone can see a way I could have seen that before.
I finally find the answer [AgBr] = [Br-] = 0.00279
From which I can also calculate for the free silver ions [Ag+] = 1.79.10-10 , much more than I said before, but more importantly still more than 100 tines less than in plain saturated AgBr solution for the reason I said.
Now I see you seem to have followed this same idea and have the same result. Any corrections by not making the approximation must be vanishingly small.
Likes 1 person
I am not sure if I understand your reply completely but it looks good to me, I will spend some more time on it.
I plugged the equations I posted in Wolfram|Alpha, I have attached the image of the solutions. Sorry, I cannot post the link because Wolfram asks you to continue with additional time and you have to go through the trouble of signing-in.
The solutions by wolfram alpha match your answer (x is the [Br-]). I guess I understand most of this now. I liked your explanation about complex being formed in a very less amount.
Thanks a lot for your effort and time epenguin. It was a great learning experience for me. :smile:
I didn't check the correctness of all the equations you wrote down. Just one point.
You want to know whether it is permissible to neglect 2y in comparison with 0.4.
To find the answer just do the calculation with 0.4 in place of (0.4-2y), which presumably can be done by hand, and then check whether 2y is really much smaller than 0.4.
That's called check for self-consistency.
Related to Complexation Equilibria problem
What is a complexation equilibrium?
A complexation equilibrium is a type of chemical equilibrium where a complex forms between a metal ion and a ligand. This complex is usually more stable than the individual components, and the equilibrium is characterized by the formation and dissociation of this complex.
How are complexation equilibria defined mathematically?
Complexation equilibria are typically described using equilibrium constants, such as the formation constant (Kf) and the dissociation constant (Kd). These constants represent the relative concentrations of the complex and its components at equilibrium.
What factors influence the formation of complexes in complexation equilibria?
The formation of complexes in complexation equilibria is influenced by a variety of factors, including the nature and concentration of the metal ion and ligand, the pH of the solution, and the temperature. These factors can affect the stability of the complex and the equilibrium constants.
How do you calculate the equilibrium concentrations of the components in a complexation equilibrium?
The equilibrium concentrations of the components in a complexation equilibrium can be calculated using the equilibrium constants and the initial concentrations of the metal ion and ligand. These calculations can be done using an ICE (initial, change, equilibrium) table or by solving the equilibrium equations.
What are some real-world applications of complexation equilibria?
Complexation equilibria have many important applications in fields such as chemistry, biochemistry, and environmental science. They are used to understand and control the behavior of metal ions in biological systems, industrial processes, and environmental remediation. For example, chelating agents that form stable complexes with metal ions are used in medicine to treat metal poisoning and in laundry detergents to remove metal ions from water.
10K
  • Topology and Analysis
  • Chemistry
