Complexification of rsin(at)+rcos(at)
  • Thread starter marmot
In summary, the conversation discusses complexifying a differential equation and the process of finding the real and imaginary parts of the solution. It also mentions the use of R*cos(x+a) form and provides a resource for finding the constants R and alpha.
marmot
55
Sorry for this dumb questions! its that i am just trying to find multiple ways of solving problems: Basically i have
y'' + 9y' = 648sin(9 t) + 648cos(9 t)
i don't know how can you complexify this, would it be p(D)y=648exp(9t)?
if so, what part do i extract, the imaginary or real? because it has both...
i can solve this with uknown coefficients but i am trying to look for efficient ways of doing this.
Mathematics news on Phys.org
complexify?
Hi marmot! :smile:
Do you mean y'' + 9y' = i648sin(9 t) + 648cos(9 t)? :confused:
(and do you mean 3t?)
if so, yes, that's 648ei9t
no, it lacks the imaginary number, its just like that. i am trying to complexify it so that the differential equation becomes relatively straightforward. the problem i encounter is that generally when i want to complexify something, its either sin(x) or cos(x) that is in the right of the equation, not both. so i am wondering how to complexify it and then, whether if i have to extract from the solution the real or imaginary or both parts.
thanks
You need both [itex]e^{i\omega t}[/itex] and its complex conjugate.
I would rewrite the right hand side in the form R*cos(9t+a), where R and a are two new constants, because then it is the real part of R*e^i(9t+a).
thank you!
however marmoset
i am trying to do this
p(D)y=P(D)exp(at)
where p(D)=D^2+D
thus
the solution would be
y=exp(at)/P(a)
however, how can i do this when i have two unknown variables, which in your case, are R and a?
FAQ: Complexification of rsin(at)+rcos(at)
What is the purpose of complexification in the equation rsin(at)+rcos(at)?
The purpose of complexification in this equation is to introduce the concept of complex numbers, which consist of a real and imaginary part. By using complex numbers, we can represent and solve problems that involve both real and imaginary quantities, which cannot be solved using only real numbers.
How does complexification change the behavior of the equation rsin(at)+rcos(at)?
Complexification changes the behavior of the equation by allowing for a wider range of solutions. In the original equation with only real numbers, the solutions are limited to a single line or curve. However, with the introduction of complex numbers, the solutions can now include a spiral or a helix, resulting in a more complex and interesting behavior.
Can complexification be applied to other types of equations besides rsin(at)+rcos(at)?
Yes, complexification can be applied to many different types of equations, including polynomial, exponential, and trigonometric equations. It is a useful tool in many areas of mathematics, physics, and engineering.
Does complexification always result in a more complex solution?
No, not always. In some cases, complexification may not result in a more complex solution, but rather in a simpler and more elegant solution. This is because complex numbers have certain properties and relationships that can simplify the solving process for some equations.
Are there any limitations or drawbacks to using complexification in equations?
Complexification can sometimes lead to solutions that are not physically meaningful, especially in physics and engineering problems. Additionally, it requires a good understanding of complex numbers and their properties in order to be applied correctly. It may also make the equations more complicated and difficult to solve, so it should be used with caution and only when necessary.
