missingmyname
- 3
The length L or the curve given by
[tex]\frac{3y^{4}}{2}+\frac{1}{48y^{2}}-5[/tex]
from y=1 to y=2
Setting up the formula is easy. First I found the derivative of f(y) which is:
[tex]f'(y)=6y^{3}-\frac{1}{24y^{3}}[/tex]
Then I plugged all the given data into the formula
[tex]L=\int_{1}^{2}\sqrt{1+(6y^{3}-\frac{1}{24y^{3}})^{2}}~dy[/tex]
I expanded out the binomial and simplified to
[tex]L=\int_{1}^{2}(36y^{6}+\frac{1}{48y^{6}}+\frac{1}{2})^{1/2}~dy[/tex]
It is from here I get stuck. It looks to me like I need to use a u-substitution. I checked out the step-by-step solution from wolfram alpha's integral calculator and it uses the following
[tex]u=\frac{1}{x^{6}}~\therefore~du=-\frac{6}{x^{7}}dy[/tex]
I could go on and list each next step (another substitution is used down the line), but that would do me little good. I do not understand how the value [itex]\frac{1}{x^{6}}[/itex] for ##u## was chosen.
