Complicated disk rolling problem (Angular Momentum and it's ilk)
In summary, a disk with a mass of 3kg and outer radius of 50cm is given a hard kick along a horizontal surface, acquiring a linear velocity of 3.5 m/s and no initial angular velocity. The coefficient of friction between the disk and surface is 0.06. The disk eventually begins to roll without slipping, with a linear speed equal to its rotational speed. The ratio of final kinetic energy to initial kinetic energy is conserved. To solve a 5 part problem involving this scenario, one must use equations for torque, angular acceleration, and angular velocity. The problem involves finding the time it takes for the disk to roll without slipping, its linear speed, the distance it slides before rolling without slipping,
ultrapowerpie
58
A disk has mass 3kg and outer radius 50 cm with a radial mass distribution (which may not be uniform) so that its moment of inertia is (2/7)mR^2. The disk is given a hard kick (impulse) along a horizontal surface at time t0. The kicking force acts along a horizontal line through the disk's center, so the disk acquires a linear velocity 3.5 m/s but no initial angular velocity. The coefficiant of friction between disk and surface is .06
The kinetic friction force between the surface and the disk shows down its linear motion while at the same time making the disk spin on its axis at an accelerating rate. Eventually, the disk's rotation catches up with its linear motion, and the disk begins to roll at time Trolling without slipping on the surface.
1) How long after the kick does it take for the ball to roll without slipping? The acceleration of gravity is 9.8 m/s^2
2) Once the disk rolls without slipping, what is its linear speed?
3) How far does the ball slide until it begins to roll without slipping?
4) Through what angle does the disk rotate while sliding before it begins to roll without slipping?
5) What is the ratio of final kinetc energy (when pure rolling occurs) to the initial kinetic energy?
No idea, terribly sorry, please see below.
My professor had to go to Denmark or something for the second lecture of the week, so instead of finishing rotational motion, we get hit with statics. So, this problem would probably have been easier to understand with that lecture. However, I only have time to do stuff over the weekend due to commuting/schedule. So, can anyone please tell me how the heck I'm supposed to even approach this problem? And why does it matter if something is slipping or not? Is there some sort of "non slipping condition" formula?
Thank you in advance. This is a 5 part problem, and I just can't ignore it/wait for the next lecture to hopefully get something answered.
Edit: Here is a picture of the problem, if it helps at all: http://img340.imageshack.us/my.php?image=discrollmz0.png
Start with what you know.
Put yourself in the frame of reference of the disk. There is a tangential force of friction u*m*g that would be going into angular momentum and increasing angular speed.
From what you are given can't you figure the angular acceleration? You have the moment of inertia. You have the force supplied.
Won't it stop slipping when the linear speed is the same as the rotational speed? And isn't there a conservation of momentum involved here? The increase in angular momentum is coming from the linear momentum?
I don't have a clue about angular momentum, sorry, the lecture hasn't gotten that far, which is one thing that makes this problem hard.
And also, the slipping thing confuses me, so I really can't answer that question. I know there's a law of angular conservation of momentum. I do not know how linear and angular momentum relate to each other.
See, if I knew more about angular momentum and some of it's formulas, I could probably figure out how to start this monster problem. But without that knowledge, it makes it harder. Sorry. <.<
Torque = F * r = I * a
where I is moment of inertia and a is angular acceleration. This gives you angular acceleration immediately.
Here are some equations
http://hyperphysics.phy-astr.gsu.edu/Hbase/rotq.html#drot
Notice how similar they are to the linear motion equations.
They are conserved. What one gains the other loses.
Alright, that's a start, thanks, I'll post again if I run into trouble further along the line. Thanks for your help.
Things you need to know are F = [tex]I \omega^{2}[/tex]
[tex]\omega[/tex] is the angular velocity of the disc in radians per second
[tex]\omega[/tex] =[tex]\frac{\Delta \theta}{t}[/tex]
Ok, I tried working out the problem for the first part, and it's saying the answer is wrong, and I"m not quite sure where in my math I'm screwing up, so here's my work:
Torque = r x F
r= .50 m (outer radius)
F= u*M*G
u= .06 (coeficiant of friction)
M= 3 KG
G= 9.8 m/s^2
So, F= 1.764 N
and Torque = .882 N-m
T = I * a -> a= T/I
I = (2/7)M*r^2 = .2142...
a = 4.116
With Angular Accerleation, I can find time now
w = wi +at
w= 3.5 (linear speed, since the angular needs to match the linear speed)
wi (initial)= 0
a= 4.116
t= (w-wi)/a
t=.85 seconds
Can someone please see where I made the mistake in my work? Thanks.
Torque = r x F
F= u*M*G
M= 3 KG
G= 9.8 m/s^2
So, F= 1.764 N
T = I * a -> a= T/I
a = 4.116
I'm with you up until there.
What you are needing to do now is determine when the forward momentum has slowed and the angular momentum has increased so that the w*r of the angular momentum is the same as the speed of the linear momentum v.
Won't that be when
I*w + m*v = m*vo
That makes sense...
Thoough now I'm a tad confused, as I see two unknowns (w and v) and only one equation to solve them.
Where's the second equation? Or am I missing something here?
ultrapowerpie said:
That makes sense...
What you're missing is that w = v/r
Ahhhh, yes, that makes it so I can solve it with algebra now. Thank you, I'll post if I have trouble, though hopefully I won't run into any more.
Sorry to bug you again, but for some reason something's not quite right.
Ok, I calculated the final linear velocity as 21, and the final angular velocity as 42. I plugged it back into the first equation, and everything matches up.
So, I tried plugging in 42 into the w= w0 +at equation, and it says it's the wrong answer. Did I skip a step?
I now have 10.2 seconds as my answer.
Whoa. How so big?
You start at 3.5 m/s.
And it slows down.
I * w + m * v = m * vo = 2/7*m*r2 * v/r + m * v
2/7 r * v + v = vo
v = 3.5/1.14
ultrapowerpie said:
Hold on, let me double check my math real fast...
I'm not quite sure what happened, I re-ran the numbers and got what you have, guess my calculator freaked out or something. Anyways, thanks for the help.
The best double check is always to review the original problem to make sure that the answer seems reasonable.
Good luck.
Ok, I re-ran those numbers, got the w = 6.14
However, when I plug it into the w= w0+at equation, the homework STILL says it's wrong.
I have t = 1.49
Sorry to keep bugging you, but this problem just seems to be made to throw me off. >.>
Incidentally, is the 3.07 for the final v here, that would be the linear speed of the disk once it stops slipping, correct?
Also, this is my last attempt for the homework here, so I need to make sure that I get it right <.<
Ok, as a small update, I assumed that the linear velocity found via the equation you gave me was the answer for number 2.
Upon inputing it, the homework system said it was wrong. So, does this mean that I calculated the linear velocity wrong?
I have t = 1.49
That looks like what I get. And v/r = 3.07/.5 = 6.14 and that gets to 1.49.
But hold on. If that's wrong maybe I should have worked it as rotational kinetic energy and linear kinetic energy. Let me look at that a little.
I suppose after looking at it that the work done in creating angular kinetic energy was what I should have been thinking. So I apologize for misleading - both of us really.
In which case, the rotational kinetic energy and the linear kinetic energy are the two quantities related by the work of the friction.
Hence the relationship:
1/2*I*w2 + 1/2*m*v2 = 1/2*m*(3.5)2
Eliminating 1/2*m
2/7*r2*(v/r)2 +v2 = 3.52
That gets to v2 = 7*(3.5)2/9
Which gets to V = 3.087
Hmmmmmmmmmmm...
Quick question, would the answer to the second part of my problem be the V you just calculated?
ultrapowerpie said:
Hmmmmmmmmmmm...
I believe so. You would want to calculate it your way to be sure.
If you can use it as the basis for later parts of the problem that you aren't close to exhausting your tries on you may be able to be sure, if this is your last try.
FAQ: Complicated disk rolling problem (Angular Momentum and it's ilk)
1. What is the concept of angular momentum in relation to complicated disk rolling problems?
Angular momentum is a measure of the rotational motion of an object around a fixed axis. In the context of complicated disk rolling problems, it refers to the tendency of a spinning disk to continue rotating in the same direction and at the same speed unless acted upon by an external force.
2. How does angular momentum affect the motion of a rolling disk?
Angular momentum plays a crucial role in determining the motion of a rolling disk. As the disk rolls, its angular momentum remains constant. This means that if the disk starts with a certain amount of angular momentum, it will maintain that same amount of angular momentum throughout its motion, unless acted upon by an external torque.
3. What is the relationship between angular momentum and the moment of inertia in complicated disk rolling problems?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. In complicated disk rolling problems, the moment of inertia affects the amount of angular momentum the disk has. The higher the moment of inertia, the more angular momentum the disk will have for a given speed of rotation.
4. How can conservation of angular momentum be applied to solve complicated disk rolling problems?
The law of conservation of angular momentum states that the total angular momentum of a system remains constant unless acted upon by an external torque. This principle can be applied to complicated disk rolling problems to determine the final angular velocity of the disk after rolling down an incline or encountering other forces.
5. How do external forces and torques affect the angular momentum of a rolling disk?
External forces and torques can cause changes in the angular momentum of a rolling disk. For example, if a disk rolling on a flat surface encounters a frictional force, it will experience a torque that will slow down its rotation and decrease its angular momentum. Similarly, an external torque applied to a disk can cause changes in its angular momentum.
