Components of a vector - don't know what I am doing wrong
In summary: O.M.E.W.S.In summary, the two medical field teams lost track of each other and the first team's GPS showed the second team's position as 15 km away, 15° north of west. The second team's GPS showed the first team's position as 32 km away, 33° east of north from base camp. When the first team checked the second team's position using their emergency GPS, it showed the second team's distance as 24 km away and direction as east due east.
Hemingway
42
Two medical field teams set out for a reconnaissance mission and lose one another. The GPS at their original camp shows the location of the first medical team as 43 km away, 15° north of west. The second medical team strayed 32 km away, 33° east of north from base camp.
When the first team uses its emergency GPS to check the position of the second team, what does it give for the second team's (a) distance from them and (b) direction, measured from due east?
Rx = ax + bx
Ry = ay + by
a2 + b2 = c2
tan -1 = opp/adj
ax = cos 15° x 43km
= -41.53km
ay = sin 15° x 43km
= 11.13km
bx = sin 33° x 32km
=17.42
by = cos 33° x 32km
= 26.83
Rx = ax + bx
= -41.53km + 17.42km
= - 24.11km
(or if we take positive direction of x the other way)
= +24.11km
Ry = ay +by
= 11.13km + 26.83km
= 37.96km
Rx2 + Ry2 = Rhypotenuse
= [tex]\sqrt{}-24.112 + 37.962[/tex]
= [tex]\sqrt{}2022.3[/tex]
= 44.97km
tan-1 = opp/adj
= 57.6°
both answers were wrong. I cannot see what little mistake I am making
Sorry about code problem, hopefully you understand what I mean. ignore the 'sup'
=√( 24.11 ^2 + 37.96^2)
= √(2022.3)
= 44.97km
Yeah, it's clear. You're just mixing up the LaTeX and BBcode syntaxes but we're kind of used to both around here :wink:
Hemingway said:
Rx = ax + bx
Ry = ay + by
Take a close look at those formulas. They're not correct. (Hint: if a and b are the same vector, what should you get for R?)
Okay so I worked out that Rx = ax + bx but ignored the Ry as it wasn't required, turned out to be correct. So thank you for that.
My only drama at this point is the angle for east. I apply an axis for direction at team A and look for angle at east. I wish I knew how to diagram this on here. But basically incorrectly assumed the east angle is the angle at the left vertice of the triangle, And since the I am not sure if this is a correct assumption. I struggle with direction sometimes. There is no right angle so I cannot do that, so need geometry rules am I correct-ish??
Sorry that was a brain dump. I cannot use inverse tan /cos/sine here as it is not a right angled triangle correct? and is my assumption of measuring the angle from team A's corner of triangle correct? Thank you so much by the way!
Did you notice I said the formula Rx = ax + bx was incorrect? If you got the right answer using that formula, it was completely by accident.
But you can draw a right triangle :wink:
If you can draw a picture of what you're talking about using some image editor, you can attach it to your next post. I think that might help.
Ah, damn it. I did see that but obviously I was misled by the fortuitous accident :) I got the angle wrong obviously so I have been given a new set of numbers now for the problem. I will post my working, images and ideas a little later after I go to work.
Thank you so much for your assistance diazona, I really very much appreciate you taking the time and patience :)
H.
Related to Components of a vector - don't know what I am doing wrong
1. What are the components of a vector?
The components of a vector are the magnitude and direction. The magnitude is the length of the vector, while the direction is the angle at which the vector points.
2. How do I calculate the components of a vector?
To calculate the components of a vector, you can use trigonometric functions such as sine and cosine. The magnitude is calculated using the Pythagorean theorem, while the direction can be found using inverse trigonometric functions.
3. What is the difference between a vector and a scalar?
A vector has both magnitude and direction, while a scalar only has magnitude. This means that a vector describes both the size and direction of a quantity, while a scalar only describes the size.
4. Can a vector have negative components?
Yes, a vector can have negative components. In fact, the direction of a vector can be in any quadrant of a coordinate plane, including the negative quadrants. Negative components indicate that the vector is pointing in the opposite direction of the positive components.
5. How do I know if I have calculated the components of a vector correctly?
You can check your calculations by converting the vector back to its original form. If the magnitude and direction are correct, then you have calculated the components accurately. Additionally, you can use vector addition and subtraction to verify your results.
11K
17K
