Components of vectors (polar coordinates)
In summary, a vector is not fixed in space and can be moved around without changing its components in a cartesian coordinate system. However, in polar coordinates, the components of a vector may change if the coordinate system is curvilinear. This means that in polar coordinates, the vector cannot be freely moved around without affecting its components.
PFuser1232
479
I have always been under the impression that a vector is not "fixed" in space. Given any vector, we could just move it around and it would still have the same components (in a cartesian coordinate system). What confuses me, however, is how we define the components of a vector in polar coordinates. If we "move the vector around", we don't seem to get the same components (in polar coordinates). Does that mean that when talking about vectors in a polar coordinate system, we are not allowed to "move" the vector around?
Science news on Phys.org
The vector itself, as expressed in terms of the sum its components times the coordinate system unit vectors will not change, but, if the coordinate system is curvilinear (so that the directions of its unit vectors vary with spatial position), then the components expressed with respect to these unit vectors will change. Cartesian coordinates are not curvilinear, so its unit vectors are pointing in the same directions at each spatial position, and the components of a vector expressed with respect to this coordinate system do not change.
Chet
Likes PFuser1232
FAQ: Components of vectors (polar coordinates)
What are polar coordinates?
Polar coordinates are a way of representing a point in a two-dimensional space using a radial distance from a fixed origin and an angle from a fixed reference direction.
What is the difference between polar coordinates and Cartesian coordinates?
Cartesian coordinates use perpendicular axes (x and y) to represent a point in a two-dimensional space, while polar coordinates use a radial distance and an angle.
How do you convert from polar coordinates to Cartesian coordinates?
To convert from polar coordinates (r, θ) to Cartesian coordinates (x, y), you can use the equations x = r*cos(θ) and y = r*sin(θ).
What are the components of a vector in polar coordinates?
In polar coordinates, a vector has two components: a magnitude (r) and a direction (θ).
How do you add and subtract vectors in polar coordinates?
To add or subtract vectors in polar coordinates, you can use the law of cosines and law of sines to find the magnitude and direction of the resulting vector.
