Composite and Inverse Functions Problem
In summary: A function is specified by its domain, its range, and the rule that takes each value of the domain to the corresponding value in the range.In this case, the domain of f(x) is ##x > 0##, the range of f(x) is ##(-\infty, \infty)##, and the rule is ##f(x) = \log_{10}(x)##.In this case, the domain of f^-1(x) is ##(-\infty, \infty)##, the range of f^-1(x) is ##x > 0##, and the rule is ##f^{-1}(x) = 10^x##.
AN630078
242
25
Hello, I have a question on composite and inverse functions which I have attempted to answer fully but I am little unsure of my solutions, especially my comments in part a on the functions of f and g, I do not know whether I am required to add anything further. I would be very grateful of any advice or evaluation of my methodology. 👍
1. a If f:x→2x+1 and g:x→1/2(x-1)
Find fg(x) and gf(x).
What can you say about the functions f and g
b.If f:x→log 10 (x)
How can the graph of f^-1 be found from f? What are the ranges and domains of f and f^-1?
f(x)
1. a.
fg(x)=2(1/2(x-1))+1
fg(x)=2(x/2-1/2)+1
fg(x)=x-1+1
fg(x)=x
gf(x)=1/2((2x+1)-1)
gf(x)=1/2(2x+1-1)
gf(x)=x+1/2-1/2
gf(x)=x
The functions functions f(x) and g(x) are inverses of each other. This can be demonstarted by
f(x)=2x+1
y=2x+1
x=2y+1
x-1=2y
(x-1)/2=y
Thus, y=1/2(x-1) = g(x)
And, g(x)=1/2(x-1)
y=1/2(x-1)
x=1/2(y-1)
2x=y-1
2x-1=y=f(x)
Besides from stating that the functions are inverses of each other, is there anything else that I could comment about the two functions which would be relevant here?
b. f^-1 is the inverse function of f(x), therefore, the graph of f^-1 can be found by reflecting the graph of f(x) in the line y=x.
The inverse function of f(x) can be found by rewriting f in terms of y, swapping x and y and then making y the subject.
i.e. y=log 10 (x)
x=log10(y)
If log a(b)=c then b=a^c
Thus, y=10^x
f^-1=10^x
The domain of f(x) would be x>0, since the graph of f(x) reaches the y-axis where x=0 but it is never less than zero, x must be positive.
The range of f(x) would be f(x)ϵ ℝ, because the values of y increase to infinity and decrease to negative infinity, so the range is any value of y.
The domain of f^-1(x) would be xϵ ℝ because the function has no undefined points or domain constraints.
The range of f^-1(x) would be f^-1(x)>0 since the function never falls below the x axis, therefore y must be positive.
I am not sure if the domains and ranges would be correct, however, the reversal of domains and ranges for the function is true for all inverses so perhaps I have not made an error. I wondered if the range of f(x) would be f(x)ϵ ℝ because the graph is a vertical asymptote to the y-axis, I did not know if this imposed a restriction on the range?
AN630078 said:
Homework Statement:: Hello, I have a question on composite and inverse functions which I have attempted to answer fully but I am little unsure of my solutions, especially my comments in part a on the functions of f and g, I do not know whether I am required to add anything further. I would be very grateful of any advice or evaluation of my methodology. 👍
b.If f:x→log 10 (x)
Relevant Equations:: f(x)
1. a.
fg(x)=2(1/2(x-1))+1
fg(x)=2(x/2-1/2)+1
fg(x)=x-1+1
fg(x)=x
gf(x)=1/2((2x+1)-1)
gf(x)=1/2(2x+1-1)
gf(x)=x+1/2-1/2
gf(x)=x
f(x)=2x+1
y=2x+1
x=2y+1
x-1=2y
(x-1)/2=y
And, g(x)=1/2(x-1)
y=1/2(x-1)
x=1/2(y-1)
2x=y-1
2x-1=y=f(x)
I can't think of anything else you could add, other than to note the domain and range of each function.
I would add, though, that your notation could be confused by some. When you write fg(x), that usually means the product of the two functions, not the composition of f and g.
Instead of fg(x), you should write f(g(x)).
i.e. y=log 10 (x)
x=log10(y)
Thus, y=10^x
f^-1=10^x
This work would look a lot nicer if you used LaTeX.
The last line above could be written as ##f^{-1}(x) = 10^x##.
See our tutorial in the link at the lower left corner of the page.
The graph of ##f(x) = \log_{10}(x)## never reaches the y-axis. The graph is asymptotic to the y-axis.
Your domains and ranges are correct here.
Thank you very much for your informative reply. Right, I may add the domain and range of each function for f(x) and g(x) in part a. Really, I used the notation fg(x) and gf(x) because this was what the question specified and additionally what I had been taught in my textbook, which explained that one should simplify f(g(x)) to fg(x) etc. However, I will use the notation you have suggested if this is correct when defining the product of two functions.
Yes, I agree regarding LaTeX and I have been trying to teach myself, however, sometimes I have been unsuccessful when trying to implement it in my postings so I have abandoned my attempts. Although, I am determined to learn properly and will make use of the LaTeX guide thank you for the suggestion.
Right, sorry my mistake. Even though the graph of f(x) is asymptotic to the y-axis, would the domain still be x>0, since x must be positive as the function is never reaches the y-axis, so it is never less than 0.
Related to Composite and Inverse Functions Problem
What is a composite function?
A composite function is a mathematical function that is formed by combining two or more functions. In other words, the output of one function is used as the input for another function.
How do you find the composition of two functions?
To find the composition of two functions, first evaluate the inner function using the given input. Then take the output of the inner function and use it as the input for the outer function. The resulting output is the composition of the two functions.
What is an inverse function?
An inverse function is a function that "undoes" the action of another function. In other words, if a function f(x) maps an input x to an output y, then the inverse function f^-1(y) maps the output y back to the input x.
How do you find the inverse of a function?
To find the inverse of a function, switch the x and y variables in the function and solve for y. The resulting equation is the inverse function. It's important to note that not all functions have an inverse.
What is the difference between a composite function and an inverse function?
The main difference between a composite function and an inverse function is the order in which the functions are applied. In a composite function, one function is applied to the output of another function. In an inverse function, the original function is "undone" by using the output as the input. In other words, the compositions of a function and its inverse will always result in the original input.
