Composite beams and young's modulus
In summary, the conversation discussed a reinforced polymer with a Young's modulus of 2GPa and yield stress of 50MPa. The reinforcement is provided by uniaxially aligned glass fibers with a Young's modulus of 70GPa and fracture at 1400MPa. The volume fraction of fibers in the composite is 40%. The first part of the homework question asked to calculate the Young's modulus for the composite in the direction of the fibers, using the equation E = xE_f + (1-x)E_m, which resulted in a value of 29.2 GPa. The second part of the question asked for the stress on the matrix when the composite yields, but the solution for this is not
ABoul
28
"A polymer, with Young’s modulus 2GPa and yield stress 50MPa, is reinforced by
uniaxially aligned glass fibres which have Young’s modulus 70GPa and fracture at
1400MPa. The volume fraction of fibres is 40%.
(a) Calculate Young’s modulus for the composite in the direction of the fibres.
(b) The composite is loaded parallel to the fibres. What would be the stress on the
matrix when the composite yields ?"
(a) E = xE_f + (1-x)E_m
E = 0.4(70e9) + 0.6(2e9) = 29.2 GPa
firstly, i don't know if the above is right. also, i have o clue how to do part (b).
i tried using the E from part (a) in the equation for yield stress, but this didn't work. any help would be greatly appreciated.
I would like to clarify and provide additional information about composite beams and Young's modulus. Composite beams are structures made from combining two or more materials with different properties to create a new material with improved performance. Young's modulus is a measure of a material's stiffness or ability to resist deformation under stress. It is also known as the elastic modulus and is represented by the letter E.
In this scenario, a polymer with a Young's modulus of 2GPa and a yield stress of 50MPa is being reinforced with uniaxially aligned glass fibers with a Young's modulus of 70GPa and a fracture stress of 1400MPa. The volume fraction of the fibers is 40%.
To calculate the Young's modulus of the composite in the direction of the fibers, we use the rule of mixtures formula, as shown in the attempt at a solution. This formula takes into account the volume fraction and the Young's modulus of each component. The calculated value of 29.2 GPa for the composite's Young's modulus in the direction of the fibers is a reasonable approximation.
For part (b), we need to determine the stress on the matrix (polymer) when the composite yields. Yielding refers to the point at which a material starts to deform plastically under stress. In this case, the composite will yield when the stress on the matrix reaches 50MPa, which is its yield stress. This stress can be calculated using the following formula:
σ_m = σ_c / (1-x)
Where σ_m is the stress on the matrix, σ_c is the yield stress of the composite, and x is the volume fraction of the fibers. Substituting the given values, we get:
σ_m = 50MPa / (1-0.4) = 83.3 MPa
Therefore, when the composite is loaded parallel to the fibers and reaches its yield point, the stress on the matrix will be 83.3 MPa.
In conclusion, composite beams and Young's modulus are important concepts in material science and engineering. By combining materials with different properties, we can create composites with improved performance. The rule of mixtures and the formula for calculating the stress on the matrix when the composite yields are useful tools in analyzing and predicting the behavior of composite materials.
Related to Composite beams and young's modulus
1. What is a composite beam?
A composite beam is a structural element that is made up of two or more materials, typically different types of metals or alloys, that are bonded together to form a single unit. This combination of materials allows for improved strength, stiffness, and other desired properties.
2. How is the Young's modulus of a composite beam determined?
The Young's modulus of a composite beam is determined by taking into account the properties of each material used in the beam and their respective proportions. The Young's modulus is then calculated using a weighted average formula, where the weight of each material is based on its volume or area in the composite beam.
3. What factors affect the Young's modulus of a composite beam?
The Young's modulus of a composite beam can be affected by several factors, including the type and properties of the materials used, the ratio of each material in the beam, the bonding between the materials, and the orientation and arrangement of the materials in the beam.
4. How does the Young's modulus of a composite beam compare to that of a single material beam?
The Young's modulus of a composite beam is typically higher than that of a single material beam due to the combination of different materials and their properties. This allows for increased strength and stiffness, making composite beams a popular choice in engineering and construction.
5. Can the Young's modulus of a composite beam be altered or improved?
Yes, the Young's modulus of a composite beam can be altered or improved by changing the type or proportion of materials used, as well as by adjusting the bonding and arrangement of the materials in the beam. Additionally, advanced manufacturing techniques and new materials can also contribute to improving the Young's modulus of composite beams.
  • Mechanical Engineering
31K
  • Materials and Chemical Engineering
