Composite function and continuerty
In summary: Since you haven't given us much information about "h", we can't help you with part a). For part b), if f(c) \neq g(c), then h is discontinious.
Mathman23
254
Hello I have the following problem:
Given two function f and g which are continuer on R, and some point c which belongs to R.
I'm suppose to show that if f(c) = g(c), then h is continious on R.
Isn't that the same as showing that that the composite function
h(c) = g(f(c)) is continues on R?
Best Regards,
Fred
You haven't told us what "h" is.
h is definied as follows
[tex]
\begin{displaymath}
h(c) = \left\{ \begin{array}{ll}
f(c) \\
g(c) \\
\end{array} \right.
\end{displaymath}
[/tex]
[tex]c \in \mathbb{R}[/tex] and f and g er continious on R.
Then how do I show that if f(c) = g(c), then h(c) is continious on R?
My own ideer is to show this if f and g are continious on R, then the composite function h is continious on R.
Best Regards
/Fred
I'm afraid I have no idea what that means.
Okay let's look it at another way,
f and g: [tex][a,b] \rightarrow \mathbb{R}[/tex] are continious, [tex]c \in ]a,b[[/tex]. Next, let h be
[tex]\begin{displaymath}h(x) = \left\{ \begin{array}{ll}f(x) \ \ \ \\g(x) \\\end{array} \right.\end{displaymath}[/tex]
h is defined on [a,b]
Now my assigment is the following:
a) Let f and g be arbitrary functions. Show that if f(c) = g(c), then the function h is continious. I sure I need to use the epsilon-delta definition of continuerty, but if there is anybody out there who maybe can explain what I need to do by way of an example I would very much appreciate it :-)
b) If [tex]f(c) \neq g(c)[/tex] the h is discontinious. Anybody who can direct me to a good example on how to show this?
Sincerely and God bless You :-)
Fred
/Fred
FAQ: Composite function and continuerty
1. What is a composite function?
A composite function is a mathematical function that is created by combining two or more functions. It is written as f(g(x)), where g(x) is the inner function and f(x) is the outer function.
2. How do you evaluate a composite function?
To evaluate a composite function, you need to substitute the inner function into the outer function. For example, if f(x) = 2x and g(x) = x+1, then f(g(x)) = 2(x+1) = 2x+2. You can then simplify the expression to get the final answer.
3. What is the domain of a composite function?
The domain of a composite function is the set of all possible input values for which the function is defined. It is determined by the domain of the inner function and the restrictions imposed by the outer function.
4. What is the difference between a composite function and a composite relation?
A composite function is a combination of two or more functions, while a composite relation is a combination of two or more relations. A composite function can be thought of as a special type of composite relation where the output of one function is used as the input of another function.
5. How do you determine the continuity of a composite function?
A composite function is continuous if both the inner function and the outer function are continuous at the point of evaluation. If either function is not continuous at that point, then the composite function will also not be continuous at that point.
