Composite of piecewise functions
In summary: Then, you'll need to look at f(x), to see what portion of the domain of f(x) has a range that's in the interval, (-∞, -1] , what portion of its domain has a range in the interval, (-1, 0] , and what portion of its domain has a range in the interval, (0, +∞) .In summary, to find f°g for the given functions, you will need to determine the intervals for each function and then combine them to determine the final intervals for the composition of the two functions. This can be done by graphing the functions and analyzing the intervals for each function individually.
smithnya
41
Find f°g for each pair of functions f and g.
f(x) = {x+1, if x≤0 or 2x, if x>0
g(x) = {2x, if x≤-1 or -x, if x>-1
I am able to determine the following:
(f°g)(x) = {2x+1, -2x, -x+1
However, these functions carry intervals, and I don't know how to obtain those intervals
For example, my book gives the following solution,
(f°g)(x) = {2x+1, if x≤-1 or -2x, if -1<x<0 or -x+1, if x≥0
I can obtain the equations, but I don't know how to determine the actual intervals for the individual equations.
Could someone please explain it to me?
It may help to graph the functions.
You're looking for (f○g)(x) = f(g(x)) .
You will have to look at g(x), to see what portion of the domain of g(x) has a range that's in the interval, (-∞, 0] and what portion of the domain of g(x) has a range that's in the interval, (0, +∞) .
FAQ: Composite of piecewise functions
What is a composite of piecewise functions?
A composite of piecewise functions is a combination of two or more piecewise functions, where the output of one function becomes the input of another. It is formed by substituting the expression of one function into the other function.
How do you find the domain of a composite of piecewise functions?
To find the domain of a composite of piecewise functions, you need to consider the domains of each individual function and determine where they overlap. The domain of the composite function is the set of all values that satisfy the domains of all the individual functions involved.
Can a composite of piecewise functions have more than two functions?
Yes, a composite of piecewise functions can have any number of functions. As long as the output of one function is the input of the next function, you can continue to add as many functions as needed to create the composite.
What is the purpose of a composite of piecewise functions?
A composite of piecewise functions allows us to model real-world situations that involve multiple conditions or scenarios. It helps us to break down complex problems into smaller, more manageable pieces and find solutions for each individual piece.
Can the order of functions be changed in a composite of piecewise functions?
Yes, the order of functions can be changed in a composite of piecewise functions. However, it is important to note that changing the order of functions can affect the output of the composite. It is crucial to carefully consider the order of functions to ensure accurate results.
