Composition goes to 0? f(x)/x -> 0 and g(x) -> 0 prove g(f(x))/x->0
  • Thread starter brian44
  • Tags
    Composition
In summary, the conversation discusses a lemma and its corresponding proof in a math book, where the last step of the proof is questioned by one of the speakers. A counter-example is given to disprove the lemma, and it is suggested that the book may have an error.
brian44
23
I've been looking at different math books that have analysis problems to get more perspectives on how to approach various analysis problems. I was following along in the "Derivatives" section of the book "Mathematical Thinking" by D'Angelo and West, second edition, and arrived at a lemma with corresponding proof that doesn't make sense to me.
16.5 Lemma: Suppose e is an error function (any function such that [tex]lim_{h \rightarrow 0}\frac{e(h)}{h} = 0[/tex] ). If [tex]s(h) \rightarrow 0 [/tex] then the composition [tex]e \circ s[/tex] is an error function.
The proof given goes like: for every [tex] \epsilon > 0 [/tex] we can choose [tex] \delta > 0 [/tex] such that [tex] |t| < \delta \Rightarrow |e(t)| \le |t| \epsilon [/tex]. Therefore [tex] |e(s(h))| \le |s(h)| \epsilon [/tex] for [tex] |s(h)| < \delta [/tex]. Since [tex] s(h) \rightarrow 0 [/tex] we can choose [tex] \delta ' [/tex] s.t. [tex] |h| < \delta ' \Rightarrow |s(h)| < \delta [/tex] and hence [tex] |h| < \delta ' \Rightarrow |e(s(h))/h| < \epsilon [/tex]. This proves that [tex] (e \circ s)(h) / h \rightarrow 0. \blacksquare [/tex]
QUESTION:
However, I don't follow the last step. It seems to me that we only have [tex] |h| < \delta ' \Rightarrow |e(s(h))/s(h)| \le \epsilon [/tex], how can we say this implies [tex] |e(s(h))/h| < \epsilon [/tex] ? The only way this is true would be if [tex] h > s(h) [/tex] but as s(h) is some function of h, I don't see how this could be true universally.
I would greatly appreciate help, it's bugging me I can't figure it out.
Maybe the proof is wrong and the error was overlooked, if so is there another way to prove it?
Thanks,
Brian
[tex]
|h| < \delta \Rightarrow |e(s(h))/h| < \epsilon
[/tex]
Note that,
[tex]
|h| < \delta \Rightarrow |e(s(h))/h | = | e (\delta) / \delta | < \epsilon
[/tex]
Which of course implies what was to be proven.
I don't see why this is so...
[tex]
|h| < \delta \Rightarrow |e(h)/h | < \epsilon
[/tex]
for that specific h, it does not imply [tex] |e(h)/d | < \epsilon [/tex] for any [tex] d < \delta [/tex], obviously this is false because we could make d arbitrarily small while fixing e(h). Similarly, [tex] |h| < \delta [/tex] and [tex] |s(h)| < \delta [/tex] in no way implies they are equal, e.g. define [tex] s(h) = h/2 \Rightarrow s(h) < \delta [/tex] if [tex] h < \delta [/tex]. In fact, even if f(x) goes to 0, this does not imply [tex] f(x) \le x [/tex] for small x, consider srqt(x) on [0,infinity). sqrt(x) goes to 0 as x goes to 0, but sqrt(x) > x for x < 1 !
I might be misunderstanding what you are trying to say, in any case I fail to see your point.
Note the problem I was having with understanding the proof is due to this implication:
[tex]
[/tex]
I don't see why it holds, obviously if it holds I see the proof is finished.
An idea that may work:
for a particular h (with abs. val. < delta and delta'), if |s(h)| <= |h| then obviously [tex] |e(s(h))/h| \le |e(s(h))/s(h)| < \epsilon [/tex]. On the other hand, if |s(h)| > |h|, then because e(x) -> 0 as x->0 if we can say e(h) > e(s(h)) then we can say [tex] |e(s(h))/h| \le |e(h)/h| < \epsilon [/tex]. However, I am not sure this holds.
I realized my previous example (using sqrt(x)) gives a counter-example which disproves the given Lemma, i.e. the book is WRONG. I wasted all that time for a stupid error in a book... They probably meant to say s(h) is also an error function, than it would hold, just going to 0 isn't enough.
Counter-example: take e(h) = h^2 , s(h) = sqrt(h) (or sqrt(|h|) on reals). Then e(h)/h = h ->0 as h -> 0. sqrt(h) -> 0 as h -> 0. But, e(s(h)) = h (or |h| on reals), so that e(s(h))/h -> 1 (or does not exist on reals) as h->0 => e(s(h)) is not an error function.
FAQ: Composition goes to 0? f(x)/x -> 0 and g(x) -> 0 prove g(f(x))/x->0
What is composition in mathematics?
In mathematics, composition refers to the operation of combining two functions to form a new function. This new function is obtained by applying one function to the output of the other function.
How does composition relate to the limit as x approaches 0?
The limit of a composition of functions is equal to the composition of their limits, as long as the limits of both functions exist. This means that if f(x) and g(x) both approach 0 as x approaches 0, then g(f(x)) will also approach 0 as x approaches 0.
What does f(x)/x -> 0 and g(x) -> 0 mean?
This notation indicates that as x approaches 0, the functions f(x) and g(x) both approach 0 as well. In other words, the value of f(x) and g(x) become smaller and smaller as x gets closer to 0.
How do you prove that g(f(x))/x -> 0?
To prove that g(f(x))/x approaches 0 as x approaches 0, we can use the limit laws and the definition of composition. We can show that the limit of g(f(x))/x is equal to 0 by breaking down the composition into individual limits and using the fact that both g(x) and f(x) approach 0 as x approaches 0.
What is the significance of g(f(x))/x -> 0 in mathematics?
This result is significant because it tells us that the composition of two functions, when both functions approach 0 as x approaches 0, will also approach 0. This is helpful in solving various mathematical problems and can be applied in various fields of science and engineering.
