sikatriz
- 1
i'm trying to work out how much energy can be extracted from a compressed air system using an adiabatic process. given how small scale the system is(an most likely unrealistic), the values for the energy that can be extracted seem very high from my calculations.
these equations were taken from wikipedia (hopefully not my first error) http://en.wikipedia.org/wiki/Adiabatic_process#Derivation_of_discrete_formula
(P2/P1) = (V2 / V1)-[tex]\gamma[/tex]
work done = P1V1[tex]\gamma[/tex]((V21-[tex]\gamma[/tex] - V11-[tex]\gamma[/tex]) / (1 - [tex]\gamma[/tex])) (last bit should read 1 minus gamma rather than 1 to the power minus gamma)
the volume of the tank is 8.4cc and i want the air to be compressed to 3cc. initial pressure is 1 bar. [tex]\gamma[/tex] = 7/5
firstly i used equation 1 to find out the pressure when the air is compressed ie. P2,
P1 = 1e5
V1 = 8.4
V2 = 3
and found P2 = 422689 Pa
then to find out how much work can be extracted as the piston is pushed forward i used the second formula using
P1 = 422689
V1 = 3
V2 = 8.4
putting these values into the formula i found a value of ~1MJ for the work done. is this right? if not where am i going wrong? thank you in advance.
