Compressed air under immersion
In summary, the conversation discusses the design of a machine that uses compressed air underwater. The speaker is looking for information on the physics of gas underwater, specifically how far a jet will travel before floating upwards and how much pressure is needed to evacuate all the water from a container underwater. The conversation also mentions the difficulties of this problem and suggests experimenting or making basic estimates. It is also noted that the pressure needed to evacuate the water will depend on the ambient water pressure at the exit point. The possibility of using a movable barrier to push the water out is also mentioned. Finally, the conversation discusses the potential buoyancy of a container filled with compressed air and the importance of allowing air to vent if the container begins to rise.
Colby Lippincott
Hello everyone,
I am designing a machine that will utilize jets of compressed air underwater. Does anyone have information about the physics of gas underwater? I would like to know how far the jet will travel before floating upwards, based on the pressure of the air and diameter of the nozzle. I also need to know how much pressure is needed to evacuate all the water from a container underwater.
Thanks!
Colby
This is actually a very difficult problem that's still a very active area of research. This is kind of a hybrid problem combining multiphase flow (gas and liquid) and turbulent buoyant jets (air is certainly buoyant in water). Each of those problems individually are difficult and active research areas in their own right.
The short answer, though, is that the jet will float upwards right as it leaves the jet, so you will have the qualify that criteria with "before floating upward a specified distance." Once you decide on that, you are probably better off experimenting or trying to make some very basic estimates based on the various jet-related topics you can find in textbooks and papers.
Determining how much pressure is required to evacuate a container underwater is easier. Air will continue to flow out of the container as long as the pressure in the container is greater than the pressure in the water at the exit point. You will never fully evacuate the container based on air pressure alone since eventually its pressure will fall below the ambient water pressure and water will begin to come into it.
Sorry, I meant evacuating the water out of a container using compressed air. The setup is a tank filled with water and immersed. There is an outlet hole where the water and air will flow out, and an inlet hole where the compressed air is hooked up. Assuming there is a continuous flow of air into the container, how much pressure would be needed to remove all the water from the container?
Just more than whatever the ambient water pressure at the outlet is. That's all you need to maintain flow going outward.
The problem will be that unless the outlet is in a place such that all the water flows toward it naturally (e.g. if the tank was placed in air, all the water would evacuate itself), then eventually you will reach a point where there is still water in the tank and only air is coming out. Think of a standard compressed gas cylinder and its shape. If you just used that and placed it sideways, eventually you would lose enough water with your setup that the water level would fall below the level of the outlet and only air would escape. Just something to keep in mind when you design your system.
An alternative might be to essentially place a piston or some other movable barrier between your air and your water and let the air push the barrier, which pushes the water. That might get unnecessarily complicated depending on what you are trying to do, though.
A container being filled with compressed air at depth will become more buoyant and may begin to rise. If it rises, the air within will gradually expand and be progressively expelled as bubbles from the water drain hole.
If the tank begins to rise before all water is expelled, the remaining water will be expelled as it rises, which will progressively increase the buoyancy until all the remaining water has been expelled.
If the tank cannot vent air as it rises, the internal pressure will remain the same as the hydrostatic pressure at depth, which might result in bursting of the tank as the confining pressure is reduced.
Related to Compressed air under immersion
1. What is compressed air under immersion?
Compressed air under immersion refers to the process of submerging an object or material in a container of compressed air. This is typically done to remove any impurities or contaminants from the surface of the object.
2. How is compressed air under immersion used in scientific research?
In scientific research, compressed air under immersion can be used to clean and prepare samples for analysis. It can also be used to study the effects of pressure and immersion on various materials.
3. What are the benefits of using compressed air under immersion?
Using compressed air under immersion allows for a more thorough and efficient cleaning process compared to traditional methods. It also eliminates the need for harsh chemicals, making it a safer and more environmentally-friendly option.
4. Are there any potential risks associated with using compressed air under immersion?
Yes, there are some risks involved when using compressed air under immersion. If not used properly, it can cause damage to delicate materials or harm to the user. It is important to follow proper safety precautions when working with compressed air under immersion.
5. Can any object be cleaned using compressed air under immersion?
While many objects can be cleaned using compressed air under immersion, it is important to consider the material and its sensitivity to pressure and water. It is best to consult with a professional or conduct a small test before submerging an object in compressed air.
  • Mechanical Engineering
