Compressions and Rarefactions in longitudinal waves
In summary, compressions in a longitudinal wave represent the highest displacement, while rarefactions represent the equivalent of troughs. This can be seen in a longitudinal wave by observing the alternate compression and expansion zones. For a sinusoidal wave, the maximum and minimum pressures occur where the displacement is zero, and the pressure change is zero where the displacement is a maximum. This can be visualized using the animation provided.
Ali_94
I know this may seem quite trivial but I just want to make sure, do the compressions in a longitudinal wave represent the highest displacement, in a transverse wave this is known as the crest, and do rarefactions represent the equivalent of troughs in longitudinal waves?
Thank you in advance
Yes, they do. You can send a longitudinal wave down a loooong spring and directly see alternate compression and expansion zones
In a longitudinal wave the amount of compression or rarefaction depends on the gradient of the displacement, [itex]\partial u / \partial x[/itex].
For a sinusiodal wave the maximum and minimum pressures occurs where the displacement is zero. The pressure change is zero where the displacement is a maximum.
See this animation: http://www.physics.smu.edu/~olness/www/05fall1320/applet/pipe-waves.html - It's probably easiest to see if you set the "Form of tube" to "both ends closed". You can flip the graph to show either pressure or displacement.
FAQ: Compressions and Rarefactions in longitudinal waves
1. What are compressions and rarefactions in longitudinal waves?
Compressions and rarefactions are regions of high and low pressure, respectively, in a longitudinal wave. They are created when particles in a medium are pushed together (compression) or pulled apart (rarefaction) by the energy of the wave.
2. How do compressions and rarefactions travel in a longitudinal wave?
Compressions and rarefactions travel in the same direction as the wave, parallel to the direction of energy transfer. This is in contrast to transverse waves, where the oscillations are perpendicular to the direction of energy transfer.
3. What is the relationship between the frequency of a wave and the distance between compressions/rarefactions?
The frequency of a wave, measured in cycles per second (Hz), is inversely proportional to the distance between compressions and rarefactions. This means that as the frequency increases, the distance between compressions and rarefactions decreases, and vice versa.
4. How are compressions and rarefactions affected by the properties of the medium?
The properties of a medium, such as density and elasticity, affect the speed at which a wave travels. This in turn can affect the distance between compressions and rarefactions, as well as the amplitude (height) of the wave.
5. Can compressions and rarefactions exist in other types of waves?
Yes, compressions and rarefactions are present in both longitudinal (e.g. sound) and transverse (e.g. light) waves. However, their characteristics and the way they propagate may differ depending on the type of wave and the medium through which it travels.
