Compton effect: how can it take place?
In summary: S-matrix, and you can't see what's going on inside.What you can see, though, is that the momentum of the photon is changed, and that the electron recoils. And you can see that the probability for this to happen is given by the formulas you've already written down.
RS6
24
English is not my native language. So, I hope to be understood. :-)
The Compton effect is the dynamics in which high-energy incident photons (X or gamma) are scattered by electrons of certain materials, like graphite. The electrons are supposed to be free, as they are only weakly bounded by their atoms, especially considering the high energy of colliding photons.
Well, the implications ot this effect are to me rather confusing.
If I approach the problem, considering the conservation laws for energy and momentum, I have no difficulty in understanding the wavelenght variation which affects the scattered photon. Of course, I have to consider the quadrivector in that calculation, since I deal with a relativistic process (photons are involved).
Until here, no problem.
But, when I try to interpret the effect I loose my mind.
The conservation laws span over the ends of the timeframe between the arrival of the incident photon and the scattering of the photon. Anyhow, they don't tell me anything about what happens in that interval.
I would like to know it, because I cannot assume that a single photon is directly deflected or bounced like a bowl, even if this is what appears in terms of ending outcome from our point of view. In the matter of fact, a photon is a quantum, so it should not interact partially, i.e. transfer only a certain amount of its energy. A quantum has instead to interact totally or not interact at all. This means, in my opinion, that the incident photon should be absorbed somewhere and that a second photon, with less energy, should be then emitted. I think so to a two-photons process.
There is now a big problem: a free electron can't absorb or emit a photon. So, the photon, in the case, should interact elsewhere. Is then the atom involved? Does the atom (or the internal electrons) 'digest' the incident photon and then release to the free electron the amount of energy needed for the emission of a second photon? Where do I have a misconcept of the process?
Thank you.
Likes Merlin3189
Why do you think this must be the case? The quantum hypothesis just says a photon's energy depends on its frequency: it doesn't say a photon can't change its energy/frequency.
Have you looked at the actual models used to describe Compton scattering?
First, this is based on classical energy-momentum conservation; you can't just assume it still holds when we are using quantum mechanics.
Second, you just said it was a two-photon process, not a one-photon process.
Likes RS6
Energy and momentum is not "weaker" in quantum mechanics. For example, the Heisenberg equation for ##\hat{p}## reads $$\frac{d\hat{p}}{dt}=i[H,\hat{p}].$$If spatial translations are a symmetry, ##[H,\hat{p}]=0## and ##\hat{p}## is constant for all time. This is an operator equation, so not just the mean value of ##\hat{p}## but all its higher moments as well are conserved.
In QFT in particular, in order to get a nonvanishing contribution to an amplitude for a given process in perturbation theory, energy and momentum must be conserved at every vertex. The diagram with two external electron legs and one external photon leg is decidedly disallowed (except in specific circumstances, e.g. strong external magnetic fields), and the lowest-order contribution to Compton scattering comes from diagrams with topology as given in this figure: https://upload.wikimedia.org/wikipe...eynman_diagram_-_Compton_scattering_1.svg.png
Calling this a "two-photon process" is accurate (in the sense that all such diagrams have two external photon legs).
@OP: To make sense of this process at the level you're interested in, you need to know a bit of quantum field theory. Thinking of it in terms of classical billiard balls is guaranteed to mislead you. In fact, about the only intuition that you can bring from classical mechanics is conservation of energy and momentum, which still hold for calculating amplitudes in QFT. But remember that this is quantum mechanics, and thus you can say very little about what "really happens" between the incident photon arrives and the emitted photon departs.
With a bit of knowledge you can easily draw suggestive pictures that seem to tell stories like "a photon is absorbed and then emitted", or more strangely, "a photon is emitted and then another is absorbed". But beware: suggestive though they are, these "stories" describe the formulas you have to write down to calculate amplitudes rather than a literal process such as a water wave reflecting off the shore of a pond. The "black box" you're uncomfortable with is just the best we can do at this time, though the QFT black box gives you a bit more information than the "conservation law" black box you're using.
Likes vanhees71 and RS6
LeandroMdO said:
The diagram with two electron legs and one photon leg is decidedly disallowed
As a diagram with two electron external legs and one photon external leg, yes. But not as an internal vertex in a diagram.
LeandroMdO said:
Calling this a "two-photon process" is accurate (in the sense that this diagram has two external photon legs).
Of course it does; that's the definition of Compton scattering.
This was the general point I was trying to make, and is a better way of putting it.
Likes RS6
Yes, I should have made that clearer.
Likes RS6
Many thanks for answering and explaining!
Sorry, if the following text is long and qualitative. I try to look first for an easy and much as possible intuitive understanding of the phenomenon (remembering that "phenomenon" is a greek word and means "what it seems", which is not "what it is").
Yesss! It should be one of my fundamental misconceptions.
Effectively, the quantum theory states, that there is a minimum and irreducible amount of action, not of energy. The action is the product energy*time, so it is not said that if a photon loses a certain amount of energy it should then also be divided in some way.
After all, photons can undergo redshifts or blueshifts. I think for instance to a photon in the gravitational field or to the Bremsstrahlung.
So, the incident photon interacts with the free (weakly bounded) electron in the Compton scattering and transfers partially momentum and energy to that particle, but it remains the same photon, carrying the typical Planck amount of action (energy*time). Anyhow, since it loses energy, the "time portion" of the carried action has to increase after the energy exchange.
Is all that right? Leaving for a while Compton, can I say, that in a complete absorption a photon like the oncoming one would interact faster than a photon like the scattered one? Generally speaking, make it sense to state that longer-wave photons take a longer time to be absorbed or emitted?
Uhm... I think the mechanical conservation laws are never violated at quantum scale, exactly as it happens at macroscopic scale. This is the reason why a free electron can't absorb or emit a photon (bounded electrons can). I read some articles which report that a free electron could absorb a photon, but should right after emit another one (we are not speaking about virtual particles). In other words, the conservation laws could be infringed, but only very shortly, i.e. in a time interval compliant with Heisenberg principle. Well, it seems those texts are wrong. The mechanical laws of conservation (energy and momentum) operate in each moment, that is: in each possible vertex of a Feynman diagram, as LeandroMdO writes in his post. This is what I got. Hope to be on the right track.
When I wrote about a "two-photon" process, I was meaning that the incident photon is not the same photon that is scattered. I was in sum thinking to an articulated dynamics in which a photon is absorbed and another one released. But it was not my intention to let understand that the absorption is carried out directly by the free electron (what is forbidden, as I wrote). Instead, I was wondering if the atom as a whole or other in it bounded electrons could take part to the energy exchange process.
Yes! Looking at photon and electrons only as rigid balls is misleading. This is clear to me. I always assume photons and electrons are waves, which in certain cases can show rigid body behaviour. I hope this can be an adequate approach. Anynow, I didn't look at them as field perturbations. I suppose, this is my essential limit.
Now, I see that these perturbations could behave in many different ways in each quantum phenomenon. If I'm not wrong, Feynman describes an infinite amount of coherent paths which could reflect what from our point of view seems to be a single interaction. This is very complex to me. But I have to accept it.
As wave amplitudes relate to (density of) probability and not to deterministic physical magnitudes, there is an additional difficulty in trying to describe what really happens between the arrival and the departure of the photon in the Compton effect.
To summarize:
1) The incident photon can lose energy and become the scattered photon in the Compton effect;
2) The way this happens possibly involves also other particles, not necessarily only the free electron, and is not determined in the microcosmic environment;
3) The incident photon and the scattered photon can also be two different entities;
4) Various (infinite) paths are possible for 3), i.e. for the photon absorption and emission;
5) We can't know what really happens inside the black box, but we can predict how the box behaves.
I'm absolutely not sure of what I wrote.
Does someone tell me where it make sense and where not?
Thanks.
Your points make sense! As was mentioned before, for a full understanding you have to learn some QFT (here QED, which should be the first theory you study anyway). Here are some qualitative remarks:
You cannot consider a photon to be a classical particle or a classical wave. The only adequate description is relativistic QFT, which tells us that a photon does not even have a position observable. It also tells us that indeed all we can interpret in some sense as "particles" (or "quanta" to emphasize that we talk about "particles" in the sense of QFT) are socalled asymptotic free states, i.e., particles which are far from any other particles they can interact with and thus can be considered free. A scattering process is described by QFT in terms of a socalled S-matrix element. It's absolute square provides the transition probability rate that a given asymptotically free state of some particles (usually two particles with quite definite momenta and energies) ends up after a scattering/interaction process in another given asymptotically free state. For these asymptotically free states for each particle the energy-momentum relation ##E=\sqrt{\vec{p}^2+m^2}## (I use units, where ##c=\hbar=1##, which is very convenient in high-energy particle physics) and overall energy and momentum conservation holds, i.e., the sum of all four-momentum vectors of the asymptotic free in-particles equals the sum of all four-momentum vectors of the asymptotic free out-particles.
QFT provides a formalism to evaluate such S-matrix elements using perturbation theory, i.e., you start with non-interacting particles and treat the interactions as perturbation, leading to a formal series in powers of the interaction strength (or coupling constant, in the case of QED it's the charge of the electron). Each contribution to this series can be depicted by Feynman diagrams, which are suggestive for "depicting" what's really going on, and in many popular-science books they are sold with such a meaning. However one has to be careful with that. Strictly speaking they are just very clever notations for the mathematical formulae needed to evaluate the S-matrix perturbatively.
Whether in the Compton scattering the outgoing photon is the same as the ingoing is a meaningless question according to QT. You cannot distinguish photons of a given energy/momentum from any other of the same energy/momentum. As already said above, we also cannot follow a photon like a classical particle somehow and know what's going on with it during it's interacting with the electron at all. All we can observe is that we shoot a photon to an electron and then it scatters (with some probability) ending again with an asymptotically free photon and an electron.
It's also impossible to call it "several paths a photon takes". The very notion of "path" (i.e., trajectory in the sense of a classical particle) doesn't make sense. While in non-relativistic quantum theory you can describe the quantum theory in terms of socalled path integrals (also an ingenious discovery of Feynman) which some over all paths of a particle in space-time, but this is equivalent to the formulation of non-relativistic QT of a particle in terms of a Schrödinger-wave function. This is not possible for relativistic particles since usually in scattering processes you always have some probability to destroy some particles in the initial state and create new particles in the final state. It's not possible to describe that with a single-particle wave function, and that's why we use QFT, which is a formalism to describe processes, where the particle numbers are not conserved and creation and destruction of particles can occur. There is a path integral formulation of QFT too (and it's very elegant, particularly for the modern gauge theories which build the foundation of the Standard Model), but here one doesn't some over space-time trajectories of a particle (or some finite conserved number of several particles) but over field configurations, i.e., it's a pretty abstract "sum over paths".
Likes RS6
Thank you, vanhees71!
Thank you also for the simplified way you write. But it all remains a bit criptic to me.
I see perhaps the condition: in QFT it's a question of a boundle of relations reflecting integrated states that evolve as a global probability distribution in space and time (better said: in space-time). In other terms, it's not a question of single separated waves (even if intended as probability wave functions).
As far as I understand from your great post, the evolution is caused by perturbations, a kind of parallel to the concept of interaction in the classic world. More than a parallel: perhaps it's the real meaning of what an interaction is. Anyhow, the best we have at that scale.
So, if I got it, one has always to consider first an immaculate state, or at least a stationary state (?). This is the starting point. Then, one has to introduce a perturbation (mathematical series in power) and make a projection for a possible ending state. At that point one can establish the matrix and evaluate the actual probability of that specific evolution of the system.
Not knowing experimentally what the (more frequent) ending states are, a grat amount of calculation is required to formulate predictions, i.e. to detect the most probable transition. Instead, knowing the ending condition, we get a kind of integrated description of what could happen during the process. But, unfortunally, only the matrix has a clear indentity, not what it is made of. Ok, better than nothing.
Hope not to be too wrong with all this.
If each perturbation is depicted by a Feynman diagram, how many perturbations/series should be involved in the matrix calculation? May be it should be convenient to consider only the most relevant diagrams, i.e. the series that influence at most the outcome. Or, may be, with QFT is not as with the Feynman non-relativistic path-integarls. Or what?
My interpretation: This is so, because the matrix, which is the best we have to reflect reality, is an integrated instrument. The matrix reflects relativistic evolution of two or more particles as a whole, not as a sum of classic interacting parts. In the complex whole we cannot distinguish the fate of the single component or what component can be produced and destroyed. Mathematics helps us to depict/predict the transition between its end, but not what depelopes in the intermediate timeframe. It seems to me, that even what happens first and what after is not any more clearly distinguished in the matrix abstraction.
I'm afraid what I wrote is a misconception. I'm here to learn.
There is a physical constant with units of action, yes, but it does not always represent "a minimum and irreducible amount of action".
Photons don't have identifying labels on them, so there is no meaning to the question of whether the scattered photon is "the same photon" as the incident one. All you can say is that a photon goes in and a photon comes out.
This isn't really any better than thinking of them as little billiard balls. Photons and electrons are excitations of quantum fields. They're not like anything in your ordinary experience.
Likes vanhees71
I don't understand. How is it possible to get an energy exchange where less than a Planck quantum is involved? Or, may be, you refer to 2π...
Yes, ok. It was a simplified sentence, pointing to the different energies of the photon before and after the collision. Even the word "collision" could not be adequate in this context.
Ok, I agree here too. My post was before the explanation on the QFT. May be I'm too rough, but if I see a wave on a lake, for instance, I interpet it as a perturbation of the water surface. In reality, the wind or a stone or something else is the actual perturbation and origin of the wave. It was just a way to say. But it's ok to go at the substance... even if the substance is not clearly identified.
There is no such thing as "a Planck quantum". Planck's constant is not the size of a little packet of anything. It's just a physical constant that appears in the equations.
The above comments apply just as well to ##\hbar = h / 2 \pi##.
@PeterDonis Ok, if I said that h is the smallest energy content that Nature can allow to be trasported in an em field at a given frequency would you accept it? May be, referring to energy is more up to date than to a classic concept like the action.
Anyhow, to me h is what implies that the electrons levels in an atom have to be discrete.
No.
It's more complicated than that. Again, ##h## is just a physical constant.
To see what's wrong with your logic here, consider that ##h## "applies" to all electrons, not just electrons in atoms. So if ##h## means energy levels are discrete, why don't free electrons (electrons not bound in atoms) also have discrete energy levels?
You are basically taking a complex domain--quantum mechanics--and trying to simplify it down to a single statement involving a single constant ##h##. That won't work.
I did not write that h "means" that energy level in an atom are discrete. I wrote that it implies it. It seems to me it's very different. It implies also other things, like the Heisenberg principle.
I'm afraid, my English is not good enough to express my thoughts.
Of course, h applies to all electrons.
When I refer to h I think to absorption or emission. I have already had the chance here to see very well how some interactions don't need at all a quantum exchange. This was after all my inital question and misconception related to the Compton effect. The users have very well clarified how complex can be the energy transfer from the arriving photon (matrix construction). You are now going back again to the subject. May be I'm wrong.
I still think that h is the smallest energy content that Nature allows to be carried from A to B in an em field at a given frequency, i.e. with a photon. This, regardless of what happens in A or in B. What I have to add to avoid misundertanding, is that the photon doesn't interact during its propagation (for example, just in a scattering effect) between the two space-time coordinates. Describing h only as a constant in quantum equations let one think it has no meaning. I think that something which is mathematically constant in a science, an equation system, a matrix, a constant value, could be a reflex of a physical truth.
I'm not trying at all to reduce quantum mechanics to the constant h. I'm just trying to understand some dynamics in a forum that is supposed to help in that. But it's true that I try to simplify. I'm convinced that one has really got a knowledge when he is able to simplify what he knows in the best way. Fore sure, this is sometimes very hard. To simplify is not easy.
If I'm misplaced or inappropriate I really apologize and leave. Perhaps the section is only for discussion among experts in QFT.
This is just quibbling over words. My objection remains the same with the word "implies". What implies that energy levels of electrons in atoms are discrete, while energies of free electrons are not, is not "h". It's quantum mechanics. And there is a lot more to quantum mechanics than just a finite value of ##h##.
It's not the "smallest" energy content of a photon at a given frequency, it is the energy content of a photon at a given frequency, via the formula ##E = h \nu##. And the qualifier "at a given frequency" destroys your argument, since it shows that all you have to do to transfer an arbitrarily small amount of energy is to use a photon with an arbitrarily small frequency. Yes, there are practical limitations on how low a frequency we can actually produce, but those limitations have nothing to do with the finite value of ##h##. So the finite value of ##h## does not put a lower limit on the amount of energy that can be transferred from A to B.
What is true is that electron levels in atoms are quantized, because their energy status is a stationary vibration (a bit like a harmonic vibration on a guitar string, but in the space). Otherwise, the electrons would fall towards the nucleus. This shows the undulatory nature of the electron. On the other hand, the photoelectric effect shows that you have to release the sufficient amount of energy to that vibration to get a jump to ionisation. This illustrates instead the particle behaviour of the radiation. Now, this energy, carried by photons quanta, depends only on the frequency and not on the intensity of the radiation (number of photons). But the energy amount of photons is also quantized, as Planck discovered. Briefly, the comparison of this discrete amount with the emission of electrons particles (current) demonstrates that the inner atoms levels are discrete and also where they are. Note that the comparison involves h, discriminant and mervellous, a value which is always the same, while the energy (h*freq) can differ from case to case.
As for free electrons, we have a quiet different situation (in reality, you write here the exact opposite of your post above, but let's say I understand the intention). In this case there is no binding energy. As we have seen with the Compton effect, for instance, an electron can then receive only a % of the photon energy.
...and it's me the one who quibbles over words! Please. :-)
I don't see how you can derivate your assertion. It's rather bent what you attribute to me. I think we are now really going off-topic.
"At a given frequency" means of course that if you change the wavelenght also the carried energy varies. In fact, the energy raises with the frequency. And this is all.
So, h still corresponds to the smallest energy that can be transferred from A to B in an em field at a given frequency (i repeat: supposing the photon doesn't interact along his "path").
No, that's not correct. If it were, energy eigenstates of free electrons, which can also be described by "stationary vibrations" (waves whose wave parameters do not change with time), would also be quantized, but they aren't.
I'm not sure what you mean by "undulatory nature". I suspect you are basing your understand on pop science sources instead of actual textbooks and peer-reviewed papers. I strongly suggest that you spend some time with the latter.
Are you aware that the photoelectric effect can be analyzed using a classical (non-quantized) model of the EM field?
Once again, I suspect you are basing your understanding on pop science instead of actual science.
Yes, and that % can be arbitrarily small, despite the finite value of ##h##. So ##h## does not set any lower limit on energy transfer.
The energy increases with increased frequency (shorter wavelength); the energy decreases with decreased frequency (longer wavelength). Make the frequency low enough (wavelength long enough) and the energy can be as small as you like, despite the finite value of ##h##. So ##h## does not set any lower limit on energy transfer.
Likes RS6
Of course, I mean quantized in the atom.
But, you're right, my sentence was not rigourosly expressed, as it should.
The electron can notoriously show particle behaviour or wave behaviour, according to the condition. In the mentioned effect it behaves like a particle.
Yes, I'm aware. As long as you refer only to the radiation frequency. But, if you know that radiation is the effect of quanta (since Planck, black body), you have to take this into account. At that point you can't avoid comparing h to the electrons level.
I completely agree. Too bad I never stated something else. There is no lower threshold for an energy change, this is true. But, I was referring to an energy transfer at a given frequency without interaction from A to B.
Of course. It's trivial. This is why I specified "At a given frequency". :-)
(Sorry for the mess with the quote. Hope it appears right now)
If all you mean by "undulatory nature of the electron" is "the electron can show wavelike behavior", then yes, you can say the electron has an "undulatory nature". But you have to be very careful, because it's very tempting to start saying more than that--for example, to say that somehow the electron "is a particle" sometimes and "is a wave" other times, and talk about wave-particle duality and so on. And doing that will cause you to misunderstand things and make incorrect predictions and inferences. That's why, IMO, it's better to stick with the more neutral "the electron can show wavelike behavior"; it's less likely to lead to misunderstandings and incorrect inferences.
How can any energy at all be transferred if there is no interaction?
After the second or third post in this section, especially with you, I am careful! :-)
Anyhow, I agree with you. An electron is not a wave, nor a particle. It's something different which can show a double nature before our eyes.
I admit that I find myself mentally more comfortable in supposing it's rather a wave that can shrink or dilatate. But this doesn't mean that I think it's really a wave. Besides, one has always to consider the probabilistic aspects. In this sense an electron, after interaction, should be geometrically simply a point, if it makes sense.
The energy is released in B. It is a total release (absorption if possible) or a % release (like in Compton).
Let's take the Compton effect. The incoming photon originated in A. Nothing happens for a certain time. In B it interacts with the free electron of the graphite. We know the energy transfer from the photon to the electron is at that point only a partial amount of the carried energy. But this doesn't matter. In the matter of fact, the photon has transferred his energy from A to B, the smallest possible amount at his (medium) frequency.
I resume tomorrow, if I can. ;-)
Thank you in the mean time...
Ok, good.
Yes, and without that interaction, no energy would be transferred. That was my point.
I'm not sure why you keep saying "the smallest possible amount". At a given frequency, there is only one amount of energy a photon can carry: ##E = h \nu##.
Also, I'm not sure what "medium frequency" you are referring to here. The amount of energy that is transferred in Compton scattering is not, in general, the same as the ##E## corresponding to either photon frequency--the one it has before the experiment, or the one it has after. It's the energy corresponding to the difference in those two frequencies. (And even this assumes that the photon state going in and coming out is a state with one particular frequency, which is not actually the case: the actual photon states involved are coherent states of the quantum field, which are not frequency eigenstates.)
Likes RS6
Yes, I see the point. But I had a different concept.
I guess it's also a question of word usage. May be more correct words are "carriage", "transportation" or similar (English is not my language).
With "transferred" energy I meant "carried from A to B". In other terms, the time-space coordinates of B are the recipient, not a particle or a composite system.
Of course, you cannot establish that the photon energy is in B, until the photon itself interacts. But this happens right after B. And when you realize that it has happened, you know that a fixed and minimum amount of energy at that frequency should have been carried through space-time to B. In the scattering effect that amount is then partly diverted in the outgoing photon, partly in the moved electron.
Sure. But you can't get less than one photon for that carriage. Instead, you can have many photons. So, the photon itself is a lower limit.
Yes, this is clear to me.
I'm not sure to realize what you mean here. As for me, I was wondering if a photon is characterised by a uniform wavelenght, since this relates also to the meaning of "at a given frequency". I think, in the case, this has to do with states superpositions. Here you can for sure teach me something intersting.
@PeterDonis, I could brighten which were the main misunderstandings and misconceptions in my topic questions.
But now I need your expertise to go on...
Could you help me in that?
Ok, it's the week-end and we are in different fuses, I presume.
Regards.
This is getting into the details of QED, the quantum field theory of photons (i.e., of the electromagnetic field); a full discussion of those would be much too lengthy for a PF thread, you would need to spend some time working through a textbook, But briefly:
In QED, the word "photon" is a way of referring to an excitation of the quantum electromagnetic field. This field can be thought of as an infinite collection of harmonic oscillators. Each oscillator has a definite frequency; the more precise technical name for the oscillators is "energy eigenstates of the quantum electromagnetic field". So when you talk about a photon with a definite frequency (and wavelength), strictly speaking, you are talking about a quantum field state in which precisely one of these oscillators is excited (i.e., is oscillating). This state will be an eigenstate of the energy operator, with eigenvalue ##h \nu##, where ##\nu## is the frequency. It will also be an eigenstate of the photon number operator, with eigenvalue ##N##, where ##N## is the "number of photons" (usually taken to be one when we are doing mathematical analysis of experiments like Compton scattering).
However, in practice the "photons" that we actually create in the lab and use in experiments like Compton scattering are not in the quantum field states I just described. The states we actually create in the lab are usually called "coherent states", and in terms of the harmonic oscillators I described above, they are quantum field states in which many of the oscillators are excited, not just one. These states are not eigenstates of either the energy operator or the photon number operator. When we talk of the "energy per photon" of such states, what we really mean is the expectation value of the energy (and strictly speaking, we should divide this by the expectation value of photon number, but as above, that is usually taken to be one when we are doing mathematical analysis).
It so happens that, for cases like Compton scattering, the mathematical analysis ends up giving practically the same answer whether we use coherent states or energy eigenstates; and since energy eigenstates are much simpler to work with, those are the ones that are used in the analysis. Similar remarks apply to cases like black body radiation: the actual radiation is composed of photons in coherent states, but for purposes like computing Planck's formula, you can get the right answer much more simply by assuming that the radiation is composed of photons in energy eigenstates.
Likes RS6 and vanhees71
Your English is fine. The problem is that your intuition about many of these issues just isn't right. It's not that you're communicating them properly, it really is a conceptual issue. That is fine, but you mustn't fool yourself thinking you understand more than you do. After all, identifying misunderstandings and trying to figure out where you can improve is the reason you posted here, right?
The first thing I should tell you is that hbar is 1. In the units that physicists like to use, the ones that really elucidate the fundamental structure of physical laws, hbar is 1, c is 1, G is 1, and so on. Any intuition you develop that depends on the specific value of these quantities is guaranteed to be wrong because the specific value is just a unit conversion factor. Saying that hbar is the minimum energy that can be carried by a photon at a given frequency doesn't make sense if that minimum energy is 1 (but notice that even in ordinary units hbar has units of energy * time, and not just energy, so the assertion fails even then).
What you really ought to understand are Sturm-Liouville type problems. Both the fact that electron energies in atoms are quantized as well as the fact that the energy of a photon is hf are just consequences of this fundamental mathematical structure.
Likes RS6
@PeterDonis Sorry, I had dinner. Thank you for the feedback.
Ok. I remember this.
Precisely one of the oscillators, ok. The others are zero or have zero probability. Right? The energy is then defined. This means also that the E-operator applied on this state returns the same state. Do I remember well?
Ok. Is this, because it's not possible in the lab to start from a really indisturbed condition? So, some oscillators are more probable than others, right?
Is a coherent state a condition of the particle, better said of the field, where the oscillations are anyway not too complex, i.e. where the wave function doesn't spread dramatically around the medium position and, generally speaking, where evolution is simple? With "simple" I mean related to some constant value in the time or to periodic evolution and also with position and momentum in some constant relation? To start from such a condition one should apply an appropriate operator, right?
Ok. The number of photons forms an integral part of the problem and is subsumed to the probability approach. Right?
So, we can admit that a single photon (N=1) comes to the free electron with a fixed amount of energy, carried at a fixed frequency. And that the scattered photon is also in an energy eigenstate. And the moved electron too. Right?
Of course. Anyhow, my so colled "intuitions" are just trials, which should be an underlaying premise, but which are possibly misunderstood. In this case: my fault.
I'm not convinced about this. But, I'm not sure I got correctly what you wrote. What have the units of measure to do in this context? How do they relate to "intuition"?
Anyway, the "the minimum energy that can be carried at a given frequency" does not mean that a photon at that frequency could carry also other energy amounts. The "by a photon" you wrote was not in my original sentence.
I will give a look to this. I thought that h was simply a choice taken by Mother Nature.
I edited my poor English: means not ---> does not mean
Sorry.
Yes.
Yes.
Not really. It's because it's not possible in a real experiment to excite exactly one of the oscillators.
RS6 said:
Is a coherent state...
All of these questions are getting into details that are too much for a PF thread. You could try looking at this Wikipedia article and the references it gives:
https://en.wikipedia.org/wiki/Coherent_states
No. What you describe is a simplified mathematical model that happens to give the right answer for some particular problems. But we know it's not right because we can do other experiments on photons from the same sources that show that the photons and electrons are not actually in energy eigenstates.
Likes RS6
PeterDonis said:
RS6: Is this, because it's not possible in the lab to start from a really indisturbed condition?
Ah, yes. I see.
I will give a look. Usually I don't trust very much Wikipedia.
PeterDonis said:
RS6:So, we can admit that a single photon (N=1) comes to the free electron with a fixed amount of energy, carried at a fixed frequency. And that the scattered photon is also in an energy eigenstate. And the moved electron too. Right?
I have misspoken. When I say "admit" I mean "we can do as if". Is then my statement right?
That's a good general policy. :wink: That particular article looks OK to me for a start, but also note that I said to look at the references as well. Even Wikipedia articles that aren't very accurate by themselves can give useful references.
Likes RS6
  • #31
Not in any practical sense, because, as I said, we can't actually create photons in the lab that are in energy eigenstates. (Or electrons, for that matter.)
Likes RS6
  • #32
True.
PeterDonis said:
RS6: When I say "admit" I mean "we can do as if". Is then my statement right?
Not in eigenstates, but, so far I got it, we can sometimes assume they are in coeherent states.
So, if my "we can do as if" is not adequate to the condition in a "practical sense", then I try following inferences:
1) We can address the phenomenon (e.g. scattering) to eigenstates in a mathematical convenient sense;
2) The results are consistent with the lab observations;
3) But we don't know what are the real states of the involved particles (photon and electron);
4) The real energy state of the particles could differ significantly from an eigenstate;
5) The in the lab measured energies are a superposition of different oscillators.
Am I on a better track?
  • #33
With the particular lab observations we are talking about (Compton scattering), yes. But the results from this model are not consistent with other lab observations we could make using photons from the same sources.
Yes, we do; they're in coherent states (at least the photons are). More precisely, we can verify that the photons from the sources we use are in coherent states by making other observations (besides Compton scattering) on photons from those sources. The electrons, since they are bound in atoms in Compton scattering experiments, are in whatever bound states correspond to the atomic orbitals they occupy. Those are not the same as the electron states used in the mathematical analysis of Compton scattering; the latter states are simpler mathematically, as I said, and happen to give the right answer for Compton scattering, but they are free states, not bound states.
I don't know what you mean by "the real energy state". Either a state is an energy eigenstate, or it isn't. There are no "energy states" in any more general sense.
No, they aren't; they're just real numbers, like all measurement results. The expectation value of energy--the real number we compute from the theory and compare with the experiment result--would be derived from the quantum field state we used in our model, which in the general case will be a superposition of energy eigenstates (oscillators). But in the simplified model that is used to make predictions for Compton scattering, simple energy eigenstates are used. Actually, what we derive from the model is a distribution of the probability of different measurement results for the photon energy; we then compare that distribution with the distribution of the actual results from lots of runs of the experiment. The probability for each individual measurement result for energy is derived by summing Feynman diagrams whose input and output photon states are energy eigenstates (the known energy expectation value of the photons from the source for input, and the measurement result for energy whose probability we are calculating for output).
Likes RS6
  • #34
PeterDonis said:
RS6: We can address the phenomenon (e.g. scattering) to eigenstates in a mathematical convenient sense;
Ok, you wrote this before.
PeterDonis said:
RS6: we don't know what are the real states of the involved particles (photon and electron)
Yes, yes. It was my big mistake, sorry.
Coherent states.
In the analysis we suppose that they are free, because they are weakly bound, at least compared to the radiation energy (X or gamma, i think). This big difference makes that the end theoretical results do not differ from the observed reality. Right?
PeterDonis said:
RS6: The real energy state of the particles could differ significantly from an eigenstate
I don't understand what I wrote, either. :-)
The sentence cointains one "energy" too many. This is what I meant: The real state of the particles could differ significantly from an eigenstate.
The answer should be in agreement with my previous point 5): yes, because it's a coherent state and there are many oscillators, not one.
Right?
PeterDonis said:
RS6: The in the lab measured energies are a superposition of different oscillators
Ok. I wanted to say that the lab values are the result of the presence of different oscillators.
Ok. This confirms what I just wrote. More precisely, "expectation value" should mean:
1) The energy values we expect to detect, but which are not necessarely detected in each test;
2) As it's about coherent states and not eigenvalues, the energy is note defined.
Right?
Ok. Clear recap of the above. Thanks.
Hm, I have to consider this better, before I can say I really got it. May be tomorrow...
Anyhow: Eigenstates for both, input and output, in the calculation (S-Matrix?), because we can use simpler eigenstates in place of coherent states, as you explained. Right?
But, at my level, I'm very unsure on "measurement result whose probability we are calculating". Does this mean that we use experimental output data to obtain how the probability distribution of these output data looks? I'm confused.
  • #35
That's how I understand the reason for using the free particle approximation, yes.
Not just "could", "does" differ significantly from an energy eigenstate, yes.
There are many oscillators that are excited. All of the oscillators are always "there", they just aren't always excited.
The result of many different oscillators being excited, yes.
It's not really an S matrix calculation, but it's similar to one.
Yes. More precisely, when we are using Feynman diagrams, we are using energy eigenstates (more precisely, energy-momentum eigenstates); at least that's how path integrals are usually done, as integrals in momentum space.
No. It means that we calculate, from the theory, the probability of measuring a whole range of different output energies for the photon (in Compton scattering), for a given input energy. Then we run the experiment many, many times with the same input energy for the photon (more precisely, with the source set up the same way, to provide photons with the same expectation value of energy), and record the output energy each time, and then compare the probability distribution of the actual output energies with the distribution we calculated from the theory.
Likes RS6
