Compton effect problem - Find angle and energy of scattered electron
In summary, the student is struggling with conservation of energy and momentum. They are also trying to solve for various scattering angles.
akennedy
http://puu.sh/7Nw8T.png
From what I've read in my textbook I believe I should be using the equations:
Photon:
p=E/c
Electron:
E(kinetic) = (Gamma-1)*m*c^2
p= (Gamma)*mass(electron)*velocity(electron)
For the first part:
Ok, so first of all I wasn't entirely sure what energy the 0.7M electron volts was referring to, but I assumed it meant the incident photon. So I took that 0.7M electron volts and worked out the initial momentum of the system, in the x direction. I also noted that the initial y momentum of the system was zero.
Then, using trig and the angles given, separated this momentum into x and y components for both the photon and the electron. The expressions were in E', v etc.. Basically unknown quantities. I assume I must equate these knowing that.
Px = P(photon)+P(electron) = 0.7x10^-6eV /c
Simularly, Py = P(Photon)-P(Electron) = 0
Given these both have the angles in them I assume there must be some trick to work out the angle. I'm stuck at that point, assuming I haven't made some mistake... Which is quite possible as I'm struggling with quantum mechanics lol.
For the second part, I assume that knowing the angles the particles are scattered I can find the velocity of the electron and hence it's kinetic energy.
Py = P(photon)-P(electron) = 0
akennedy said:
For the first part:
... the pic says "A 0.700MeV photon scatters off a free electron..." so certainly the energy refers to the incident photon.
Good start, it is basically a conservation of energy problem.
Shouldn't that be a +6 in the exponent? Why not work in MeV/c?
You are told that the scattering angle of the photon is twice the scattering angle of the electron. You are also given a very strong hint at the bottom that you have yet to use.
There's also a special relationship that applies to the Compton effect.
Likes 1 person
I had another read of my textbook and I think I found the "special relationship". I assume it's the relationship between incident wavelength - scattered wavelength and (1-cos(theta)). I put in hc/E in place of the incident wavelength and got a messy expression for the scattered one in terms of theta.
Here I'm stuck again. Should I use that scattered wavelength to get an expression for the scattered photon momentum?
I apologize for the lack of intuition on my part. This is the first physics course I've taken in 2 years, and I'm really struggling to recall some of the basic stuff. Thanks for taking the time to help.
Conservation of momentum gets you two expressions, the Compton scattering formula (yes, the delta-lambda one) gives you a third.
Have you used conservation of energy yet?
Did you remember that ##\theta=2\phi## is the photon angle?
When you have the same number of equations as you have unknowns, you can start solving for things.
Alright thanks I'll see if I can finish it from here.
I've given it a huge go and still no luck unfortunately. Am I using the right formula for the momentum of an electron, p= gamma*m*v?
Also, could I get a hint as to what order I should solve the equations?
Note: $$p_ec=\sqrt{E_{tot}^2-(mc^2)^2}$$
You have to get clever about it or you'll get a mess of trig functions.
Show me the 4 equations you are starting with.
You should have something like:
>>> photon enters with ##E_0=p_0c = hc/\lambda## given (700keV),
... and is deflected through unknown angle ##2\phi## from it's initial direction,
... departing with unknown energy ##E_\gamma = p_\gamma c##,
... causing an electron recoil at angle ##\phi##
* conservation of energy: $$p_0c+mc^2 = \gamma mc^2 + p_\gamma c$$ ... mc^2=511keV is the electron rest-mass energy E.
* conservation of momentum: $$p_0c=p_\gamma c\cos 2\phi + p_e c\cos\phi\\
p_\gamma c\sin 2\phi = p_e c\sin\phi$$
* Compton effect tells us:
$$\frac{1}{p_0c}-\frac{1}{p_\gamma c } = \frac{1}{mc^2}(1-\cos 2\phi)$$
Notice how you can express everything in terms of energy just by multiplying through by c?
Likes 1 person
Thanks a lot!
The 4 equations I started with were
The wavelength relationship I posted about above, and the following
c(Gamma*mass(electron)*velocity(electron))cos(electron angle) + c*(h/lambda')cos(theta) = E0
(h/Lambda')sin(theta) = (Gamma*mass(electron)*velocity(electron))sin(electron angle)
(Gamma - 1)*mass(electron)*c^2 + hc/lamda' = E0
lamda' = scattered wavelength of photon
I just realized I wasn't including the electrons initial mass energy in the conservation of energy.
Gah! Probably a good idea to learn LaTeX :/
https://www.physicsforums.com/showpost.php?p=3977517&postcount=3
That list of equations is actually the end of the physics - I would not normally have listed them like that but I decided you had made a credible effort and you'd learn quicker by comparing yours with mine.
The rest is algebra ...
I would work in terms of energy rather than momentum.
Your unknowns are the final energies for the photon and the electron, gamma, and the angle.
##E_{tot}^2=m^2c^4+p^2c^2=\gamma^2m^2c^4## ... can get you out of some trouble.
... you'll want a list of trig identities too.
... well it subtracts from the other side so you get the kinetic energy term left over - but it is good practice to include it at the start: it is total energy that is conserved.
Likes Harry Atkinson
I am stuck on this same question - mainly with the algebra, also isn't the Compton formula meant to have the LHS back to front as below?
$$\frac{1}{p_\gamma c }-\frac{1}{p_0c} = \frac{1}{mc^2}(1-\cos 2\phi)$$
Process is as follows : identify the unknowns - $$p_\gamma\ phi\ p_e\ gamma$$
I need to rearrange equations but I keep getting convoluted formulas that I am sure I have made an error in.
To get rid of some variables I can make an uknown eg $$p_e$$ the subject in two equations and then set them equal to each other right?
Eventually continue on this process until there is only one unknown by substituting the new formula for unknowns into a formula with just two unknowns eg comptons equation
Is this on the right track?
Yep... you can also make an unknown the subject in one equation, then sub the result into all the others.
Did you try drawing a diagram?
Aside: notice that the lhs of the compton equation has to be positive.
This can be used to check which way around the terms have to be.
Your a good man Simon, I'll have another go at it tonight.
Do you use any programs to check your math when playing with formula like this?
Also - I've just clicked regarding the LHS, I made my error when going from the standard formula to your one by just converting the wavelength to momentum*c
If you need to work on this further, please feel free to start your own thread, showing your own work. We prefer that to piggybacking on someone else's year-old thread.
Ok I'll have another go now and then post up where I get stuck.
Is using latex mandatory too?
You can write many equations fairly decently using the subscript and superscript buttons and the Greek letter / math symbol palette (the big ∑ button) in the toolbar of the editing window. That would be OK. On the other hand, using LaTeX for such equations isn't too complicated, either. See for example
https://www.physicsforums.com/help/latexhelp/
and skip over the more complicated parts that you don't need. Your choice. :oldsmile:
I would consder LaTeX as "best practise" rather than compulsory.
So long as we can read it.
Related to Compton effect problem - Find angle and energy of scattered electron
1. What is the Compton effect and why is it important?
The Compton effect, also known as Compton scattering, is a phenomenon in which a photon (light particle) collides with an electron, resulting in a change in the wavelength and energy of the photon. This effect is important because it provides evidence for the particle nature of light and helps to understand the behavior of matter on a subatomic level.
2. How do you calculate the angle of scattered electron in a Compton effect problem?
The angle of the scattered electron can be calculated using the formula θ = arccos[(λ'- λ)/λ], where θ is the angle of the scattered electron, λ' is the wavelength of the scattered photon, and λ is the wavelength of the incident photon.
3. How do you find the energy of the scattered electron in a Compton effect problem?
The energy of the scattered electron can be found using the formula E = E_0/(1 + (E_0/m_e)(1 - cos θ)), where E is the energy of the scattered electron, E_0 is the energy of the incident photon, and m_e is the mass of the electron.
4. What are the units for the angle and energy in a Compton effect problem?
The angle in a Compton effect problem is typically measured in radians (rad) or degrees (°). The energy is usually measured in electron volts (eV) or joules (J).
5. How does the angle and energy of the scattered electron change with different incident photon energies?
The angle and energy of the scattered electron both increase as the incident photon energy increases. This is because a higher energy photon will have more momentum and will transfer more energy to the electron during the collision, resulting in a larger change in angle and energy of the scattered electron.
