Compton Scattering and Recoil Velocity
In summary: It seems like you are just summarizing the conversation and not providing a summary of the content. Please provide a summary starting with "In summary," and nothing before it. Thank you.In summary, the conversation discussed the problem of finding the approximate recoil velocity of an electron when a photon of wavelength 200 pm hits it and is scattered exactly backwards. The solution involved using Compton scattering and momentum conservation equations, and after correcting a typo, the final answer was found to be 3.97 km/s.
doggydan42
170
A photon of wavelength ##\lambda_i = 200## pm hits an electron at rest, and is scattered exactly backwards. Find the approximate recoil velocity v of the electron using momentum conservation.
Comptons Scattering:
$$\lambda_f = \lambda_i +\frac{h}{mc}(1-cos(\theta)$$
Momentum of photon:
$$p_\gamma = \frac{h}{\lambda}$$
Momentum conservation:
$$p_1+p_2 = p_1'+p_2'$$
Since it recoils exactly backwards, ##\theta = \pi##, so ##(1-cos(\theta) = 1-cos(\pi) = 2##.
So,
$$\lambda_f = \lambda_i +\frac{2\pi \hbar c}{mc^2}$$
Using ##\hbar c = 197.33## MeV fm, and ##mc^2 = E_e = 937## MeV,
$$\lambda_f = 200 pm + \frac{2*2\pi (197.33 MeV fm \frac{10^{-3} pm}{fm})}{937 MeV} = 200.001$$
So for the momentum,
$$p_\gamma = \frac{h}{\lambda_i} = \frac{2\pi\hbar}{\lambda_i}$$
and
$$p_\gamma' = -\frac{h}{\lambda_f} = -\frac{2\pi\hbar}{\lambda_f}$$
and for the electron, ##p_e = 0## and ##p_e' = mv = \frac{mc^2}{c^2}v = \frac{E_e}{c^2}v##
Using conservation of momentum,
$$p_\gamma + p_e = p_\gamma' + p_e' \Rightarrow p_e' = p_\gamma - p_\gamma' \Rightarrow \frac{E_e}{c^2}v = \frac{2\pi\hbar}{\lambda_i} - (-\frac{2\pi\hbar}{\lambda_f}) = 2\pi\hbar(\frac{1}{\lambda_i}+\frac{1}{\lambda_f})$$
$$\Rightarrow v = \frac{2\pi\hbar c*c}{E_e}(\frac{1}{\lambda_i}+\frac{1}{\lambda_f})$$
Converting ##\hbar c## from MeV fm to MeV pm and plugging in all variables gave me ##v = 3969.65 \frac{m}{s}##.
The multiple choice answers were in km/s, and all had over 1000 km/s. My answer would give me about 3.97 km/s.
I have gone through trying to figure out what I did wrong. I though that I might need to use relativistic velocity; however, I found it negligible even with the largest answer choice.
Momentum of photon:
So,
Using ##\hbar c = 197.33## MeV fm, and ##mc^2 = E_e = 937## MeV.
The mistake is right there.
Are you referring to the missing factor of 2 in the equation for ##\lambda_f##? If so, when. I plugged in the values in the next equation, I added the factor. The first equation missed the factor because of a typo.
I was referring to the very last thing written in the part I quoted.
Related to Compton Scattering and Recoil Velocity
What is Compton Scattering and Recoil Velocity?
Compton scattering is a phenomenon in which a photon (particle of light) collides with an electron, transferring some of its energy and changing its direction. The change in direction is known as the Compton effect. Recoil velocity refers to the velocity of the electron after the collision.
How does Compton Scattering and Recoil Velocity relate to the study of matter?
Compton scattering is an important process in the study of matter, as it provides valuable information about the structure and properties of atoms and molecules. By studying the changes in direction and energy of the scattered photons, scientists can gain insight into the behavior of electrons and the arrangement of atoms in matter.
What factors affect the magnitude of the Compton effect?
The magnitude of the Compton effect depends on the energy of the incoming photon, the mass of the electron, and the angle at which the photon collides with the electron. A higher energy photon, a lighter electron, and a larger collision angle will result in a greater change in direction and energy of the photon.
What is the significance of recoil velocity in Compton scattering?
The recoil velocity of the electron after a Compton scattering event is an important factor in understanding the dynamics of the collision. The magnitude and direction of the recoil velocity can provide information about the energy and momentum transfer between the photon and electron.
How is Compton Scattering and Recoil Velocity used in practical applications?
Compton scattering and recoil velocity are used in a variety of practical applications, including medical imaging, material characterization, and security screening. It can also be used to study the properties of cosmic rays and to measure the composition of distant objects in space.
