Compton scattering; conservation of momentum violated?
In summary, when considering special relativity, it is important to remember that energy and momentum are not separately conserved, but the total 4-momentum is. Therefore, comparing the magnitudes of the momenta gained by the electron and lost by the photon is not a meaningful physical quantity and does not violate conservation of momentum. The magnitude of the total momentum is conserved, but the magnitude of the sum of the outgoing photon's momentum and the recoiling electron's momentum is smaller than the magnitude of the outgoing photon's momentum.
Fosheimdet
While reading the derivation of the formula [itex] \lambda' - \lambda = \frac{h}{ m_ec}(1-cos(\theta)) [/itex] on Wikipedia, they point out that the momentum gained by the electron is larger than the momentum lost by the photon:
$$ p_e=\frac{\sqrt{h^2(\nu-\nu')^2 +2h(\nu-\nu')m_ec^2}}{c} > \frac{h(\nu-\nu')}{c} = p_{\gamma}-p_{\gamma'} $$
How is this not a violation of conservation of momentum?
I don't think that's the right of way talking about it! When we consider SR in analysing phenomena, we should keep in mind that it is no longer true that energy and momentum are separately conserved, but it is the total 4-momentum [itex] P^\mu=(\frac E c, \vec p) [/itex] which is conserved. So such a comparison has no meaning and violates nothing!
Momentum is a vector quantity. The incoming and outgoing photons are in different directions. The difference in the magnitudes of their momenta is not a meaningful physical quantity, as far as I know.
Likes PeroK
Shyan, what you wrote is wrong. It is not necessary to reply to every single question here, particularly if you don't know the answer. If the energy-momentum 4-vector (or any 4-vector) is conserved, each and every component is separately conserved.
jtbell - and Wikipedia - has it right. Comparing the magnitudes of two vectors is, in general (and in this particular case) comparing them along two different directions. You don't expect equality here.
Likes Matterwave and Nugatory
...but the magnitude of the 3-momentum is not. (just to make this explicit)
I don't think that helps. The magnitude of the 3-momentum component is conserved, since each of the three components is conserved separately. What we have here is a comparison between two 3-vectors pointing in two different directions. These are, as you said, not going to be equal. You would only get equality if you compared the total initial 4-momentum with the total final 4-momentum.
You're right, that was a bad way to put it. I was thinking of the fact that the magnitude of the 3-momentum is not "additive". That is, the sum of the magnitudes of two momenta does not generally equal the magnitude of the total momentum.
Right, the magnitude of the total momentum is conserved. Before the interaction, the total momentum is the incoming photon's momentum. Afterwards, the total momentum is the sum of the outgoing photon's momentum and the recoiling electron's momentum. The magnitude of the sum is smaller than the magnitude of the outgoing photon's momentum.
Related to Compton scattering; conservation of momentum violated?
1. What is Compton scattering?
Compton scattering is a phenomenon in which a high-energy photon collides with a target material, resulting in the photon losing energy and changing direction. This is due to the interaction between the photon and the electrons in the target material.
2. How does Compton scattering violate conservation of momentum?
According to the law of conservation of momentum, the total momentum of a system must remain constant. However, in Compton scattering, the photon loses energy and therefore has a lower momentum after the collision. This violation is due to the fact that the interaction between the photon and target material involves a transfer of momentum.
3. What is the explanation for the violation of conservation of momentum in Compton scattering?
In Compton scattering, the target material's electrons are free to move, and when they absorb the photon's energy, they also gain momentum. This transfer of momentum from the photon to the electrons results in a decrease in the photon's momentum, violating the law of conservation of momentum.
4. Is there any way to reconcile the violation of conservation of momentum in Compton scattering?
Yes, the violation of conservation of momentum in Compton scattering can be reconciled by considering the entire system, including the target material and the scattered photon. The total momentum of the system remains constant, but it is distributed differently between the electron and photon after the collision.
5. How is Compton scattering significant in the field of physics?
Compton scattering is a crucial phenomenon in the field of physics as it provides evidence for the particle-like behavior of photons and the wave-like behavior of electrons. It also helps in understanding the interaction between electromagnetic radiation and matter, which has various applications in fields such as medical imaging and materials science.
  • Quantum Physics
  • Sticky
  • Quantum Physics
  • Quantum Physics
15K
