Compton vs Photoelectric effect?
In summary, the photoelectric effect occurs when an electron is ejected from a metal after being struck by a photon, while the Compton effect occurs when a photon interacts with any material and ejects an electron. The photoelectric effect is more common and occurs with lower energy photons, while the Compton effect is more significant and occurs with higher energy photons.
pivoxa15
2,255
What is the main differences? Are they essentially the same thing?
From what I have gathered, the two are fundalmentally the same. If a photon gives up all its energy after interaction with an electron than the photoelectric effect applies.
On the other hand if the photon continues to travel and possesses kinetic energy after collision with an electron than the Compton effect takes place.
Also it seems the photoelectric effect happens mainly with electrons in metals whereas the Compton effect is with any material.
They are completely different.
In CE, a photon is elastically scattered by a charge which recoils.
Conservation of energy and momentum results in a change in the energy and momentum of the photon (usually measured as a change in wave length).
In PE, a photon is completely absorbed by a solid, and an electron is ejected in the process.
What determines whether CE or PE occurs? Why is it that sometimes, an electron is able to absorb all of the photon's energy (PE) and sometimes, it just gets pushed around like a "ball collision" (CE)?
I'll have a guess. Is it because PE occurs only if the photon matches a transition state in the atom? Hence the electron is able to completely absorb the photon's energy. When it doesn't occur (i.e. energies don't match) than you get CE?
There are no more "atoms" in a solid. The energy bands that you get in a solid such as a metal is the collective effect of all the atoms in such a way that you no longer get the individual atomic behavior. That is why you get band of energy, rather than discrete states of atoms.
Photoelectric effect will only occur in solids due to the requirement of longitudinal momentum conservatoin. Compton effect occurs when a photon encounter a "free" particle or atoms. It can occur, in a limited sense, in solids, but the effect isn't dominant when compared with other phenomena that can occur.
Zz.
If one looks at the cross-sections of PE and CE, one finds that PE dominates at lower energies. As gamma energy increases, the probability of Compton scattering increases.
PE and CE occur in solid, liquid or gaseous states of any element. The reaction rate increases with electron density, which is a function of the element and state (solid, liquid or gas).
The standard Photoelectric effect doesn't actually occur in gasses. That is more commonly called photoionization. This is different than photoelectric effect because you don't have a continuous energy bands, and you also don't have a "work function".
Zz.
It maybe that nuclear engineers are abusing the term 'photoelectric'. I learned PE means the electron absorbs the photon completely, which is also photoionziation. I think we (nuclear engineers and radiation physicists) misappopriated the term. :smile:
I was wondering about the distinction between the classic 'photoelectric' effect where if the photon (on order of a few eV's) strikes a metal surface resulting in the ejection of a photo-electron, and the interaction of a keV X-ray or gamma-ray which strikes any atomic electron and is completely absorbed. For nuclear engineers and health physicists, there is not distinction. If a photon is completely absorbed, then we called it 'photoelectric effect' and the ejected electron is a photo-electron.
That depends of course on the energy of the photon. In one of our undergraduate labs, students send 662-keV gammas from Cs-137 into a NaI scintilator and do a pulse-height analysis of the spectrum that comes out of the scintillator's photodetector. I don't have a spectrum handy here at home, but the numbers of pulses from photoelectric and Compton interactions are in the same general ballpark, with probably more Comptons.
For higher-energy gammas, say the approx. 1.2 MeV ones from Co-60, the number of Comptons is definitely a lot larger than the number of photoelectrics.
Yup. Compton scattering spectroscopy is usually done in the 100 keV range so that's where CS is a strong enough process to produce decent statistical certainty. It's a pretty handy technique to probe certain things. One can map fermi surfaces, probe coordination and bond lengths etc. with CS. It's pretty painful with lab x-ray equipment but at 3rd gen synchrotrons have increased interest in it.
This looks exactly the experiment I am doing and is what led me to ask this question while thinking about the theory behind it. A convenient reason why the photoelectric effect occur at lower energy levels is because the incoming photons doesn't have enough energy to give energy to the electron and go off on its own (as in Compton). In this regard, the photoelectric and compton effects are much closer related.
Although as Zapper suggested, the type of atom is also important as to which effect takes place.
So, which comparison between CS and PE is correct? I am confuse.
Compton scattering can occur on either free electrons or lightly bound electrons. The defining characteristic is that there is always a recoil photon. For low energies, Compton scattering is sometimes called Thomson scattering. The differential Compton scattering is sometimes referred to as Klein-Nishina scattering. The low energy (classical Thomson) total cross section is about
σ = (8 pi/3) re2 = 0.666 barns, where re is the classical electron radius.
For photon energies over ~0.5 MeV, the Compton cross section drops off due to relativistic effects. It is independent of the nuclear charge Z.
Below ~60 KeV in air (~600 KeV in lead), the dominant photon attenuation cross section is where the photon energy is completely absorbed by a bound electron. For photon energies in the KeV region, this is often referred to as deep core photo-ejection. Very roughly, the cross section is crudely proportional to Z4/Ephoton3. The photo-ejection cross section can suddently jump by an order of magnitude as the photon energy crosses the binding energy (absorption edge) of the K-shell electron (~33 KeV in sodium iodide, ~90 KeV in lead). Complete photon absorption by a bound electron in the visible and UV region is usually called the photoelectric effect or photoionization.
Bob S
Why does not this relativistic effect come into account when photoelectric effect takes place?
Related to Compton vs Photoelectric effect?
1. What is the difference between the Compton and photoelectric effects?
The Compton effect is a phenomenon in which a photon (a particle of light) collides with an electron and transfers some of its energy to the electron, causing it to recoil. This effect is important in understanding the behavior of X-rays. On the other hand, the photoelectric effect is a phenomenon in which a photon collides with an electron and completely transfers its energy to the electron, causing it to be ejected from its atom. This effect is important in the production of electricity in solar cells and in explaining the colors of metals.
2. How do the Compton and photoelectric effects relate to each other?
The Compton and photoelectric effects are two different ways that photons can interact with electrons. The Compton effect involves a partial transfer of energy from the photon to the electron, while the photoelectric effect involves a complete transfer of energy. These effects are both important in understanding the behavior of light and electrons in different situations.
3. What is the significance of the Compton and photoelectric effects in modern physics?
The Compton and photoelectric effects are both important in modern physics because they help us understand the dual nature of light as both a wave and a particle. The Compton effect provides evidence for the particle nature of light, while the photoelectric effect provides evidence for the wave nature of light. These effects also have practical applications in fields such as medicine, energy production, and materials science.
4. How are the Compton and photoelectric effects observed and measured in experiments?
The Compton effect can be observed and measured by directing X-rays at a target material and measuring the energy of the scattered X-rays. The change in energy of the scattered X-rays is due to the energy transferred to the electrons in the target material. The photoelectric effect can be observed and measured by directing light of different wavelengths at a metal and measuring the current produced by the ejected electrons. The energy of the ejected electrons corresponds to the energy of the incident light.
5. What are the practical applications of the Compton and photoelectric effects?
The Compton and photoelectric effects have a wide range of practical applications. The Compton effect is used in medical imaging techniques, such as X-ray computed tomography (CT scans), to produce detailed images of the body's internal structures. The photoelectric effect is used in solar cells to convert light energy into electrical energy, and in digital cameras to capture images. Both effects also play a role in the development of new materials and technologies in fields such as electronics, energy production, and telecommunications.
