MHB Computation of bond angles and other angles in tetrahedral
The bond angle of 109.5° in tetrahedral molecules like CH4 and NH4+ is derived from the geometric arrangement of points in a tetrahedron. By using vector mathematics, specifically the dot product, the angle between two bonds can be calculated. The coordinates of the tetrahedron's vertices are used to determine the angle, resulting in the formula that yields 109.5°. This method can also be applied to compute other angles in tetrahedral structures. Understanding these calculations is essential for grasping molecular geometry.
WMDhamnekar
MHB
Hello,
I didn't understand the geometry of molecules in which central atom has no lone pairs of electrons. for example, in $CH_4, NH_4^+$ molecular shape is tetrahedral and bond angle is $109.5^\circ$. How is that bond angle computed? $CH_4$ stands for liquid methane and $NH_4^+$ is a polyatomic cation. Now my other question involve mathematics as well.
If i want to compute other angles of this tetrahedral, how can i compute it?
If any member knows the answer to these question, may reply.
Mathematics news on Phys.org
Dhamnekar Winod said:
Hello,
I didn't understand the geometry of molecules in which central atom has no lone pairs of electrons. for example, in $CH_4, NH_4^+$ molecular shape is tetrahedral and bond angle is $109.5^\circ$. How is that bond angle computed? $CH_4$ stands for liquid methane and $NH_4^+$ is a polyatomic cation.Now my other question involve mathematics as well.
Hi,
I got the answer to the question how is $109.5^\circ$ angle between all the bonds in tetrahedral structure computed.
Hi,
Here is one way to do it.
First consider that the points (+1,+1,+1), (+1,-1,-1), (-1,+1,-1), (-1,-1,+1) span a regular tetrahedron with its center at the origin.
\begin{tikzpicture}
%preamble \usepackage{tikz-3dplot}
\tdplotsetmaincoords{80}{110}
\begin{scope}[scale=3,tdplot_main_coords]
\coordinate[label=below:O] (O) at (0,0,0);
\coordinate[label=A] (A) at (+1,+1,+1);
\coordinate[label=left:B] (B) at (+1,-1,-1);
\coordinate[label=right:C] (C) at (-1,+1,-1);
\coordinate[label=D] (D) at (-1,-1,+1);
\draw[-latex] (O) -- (1,0,0) node[ left ] {x};
\draw[-latex] (O) -- (0,1,0) node[ right ] {y};
\draw[-latex] (O) -- (0,0,1) node[ above ] {z};
\draw[help lines] (-1,1,1) -- (-1,-1,1) -- (1,-1,1);
\draw[help lines] (1,1,-1) -- (-1,1,-1) -- (-1,1,1) -- (1,1,1);
\draw[help lines] (0,-1,1) -- (0,1,1) -- (0,1,-1);
\draw[help lines] (1,1,1) -- (1,-1,1) -- (1,-1,-1) -- (1,1,-1) -- cycle;
\draw[help lines] (1,-1,0) -- (1,1,0) -- (-1,1,0) (1,0,-1) -- (1,0,1) -- (-1,0,1);
\draw[dotted] (C) -- (D);
\draw[dashed] (O) -- (A);
\draw[dashed] (O) -- (B);
\draw[dashed] (O) -- (C);
\draw[dashed] (O) -- (D);
\draw[thick] (B) -- (C) -- (A) -- (D) -- (B);
\draw[ultra thick] (A) -- (B);
\end{scope}
\end{tikzpicture}
The angle between 2 bonds is $\phi=\angle AOB$.
We can calculate the angle $\phi$ from the definition of the dot product:
\[ \overrightarrow{OA} \cdot \overrightarrow{OB} = OA\cdot OB \cdot \cos\phi \\
\cos\phi = \frac{\overrightarrow{OA} \cdot \overrightarrow{OB}}{OA\cdot OB} = \frac{(+1,+1,+1)\cdot(+1,-1,-1)}{\|(+1,+1,+1)\|\cdot \|(+1,-1,-1)\|} = \frac{-1}{\sqrt 3\cdot \sqrt 3} = -\frac 13 \\
\phi=\arccos\left(-\frac 13\right)\approx 109.5^\circ \]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
