Computation of the ratio of barometric pressure
In summary, the ratio of barometric pressure on the top of Custer Peak to the barometric pressure at the bottom of Homestake gold mine is approximately 0.8721, meaning that the pressure at Custer Peak is slightly lower than the pressure at the bottom of Homestake. This could have implications for breathing and boiling temperature at these altitudes. Additionally, the conclusions drawn from the given information are correct, with South Dakota being approximately 1538.4 m above sea level and Custer Peak being approximately 561.6 m above South Dakota.
WMDhamnekar
MHB
381
28
Hi,
The Homestake gold mine near Lead,South Dakota is excavated to 8000 feet below the surface. Lead is nearly a mile high; the bottom of the Homestake is about 900 m below sea level. Nearby custer peak is about 2100 m above sea level.
What is the ratio of barometric pressure on the top of the custer peak to the barometric pressure at the bottom of Homestake?
(Assume that the entire atmosphere is at 300 K and that it behaves as a single ideal gas whose molar mass is 29.
How to answer this question? The known barometric formula is $P=P_0 e^{-\frac{m_gh}{kT}}$ where T=temperature, k=Boltzmann's constant, $m_g$=mass of an individual atmospheric molecule.
Mathematics news on Phys.org
We can fill in 2100 m respectively -900 m into the formula to find the pressures. And then divide them to find the ratio.
Alternatively, we can first express the ratio as a formula and simplify it, and then evaluate it.
That is, let $h_1=2100\, m$ and $h_2=-900\,m$.
Then the requested ratio is:
$$\frac{P_0 e^{-\frac{m_g h_1}{kT}}}{P_0 e^{-\frac{m_g h_2}{kT}}}=e^{\frac{m_g h_2}{kT} - \frac{m_g h_1}{kT}}=e^{\frac{m_g}{kT}(h_2 - h_1)}$$
Hi,
So, $m_g=\frac{29 g}{6.02214e23mol^{-1}}=4.8155e-23 g, e^{\frac{4.8155e-23 g(900 m-2100 m)}{\frac{1.38065e-23J}{K}300 K}} $= $e^{-0.013951577 s^2/m}$
Now, what is the final ratio? What does this answer mean to the readers?
My other conclusions from the information given in this question are
1) South Dakota is about 1538.4 m above sea level.
2)Custer Peak is about 561.6 m above South Dakota.
Are these conclusions correct?
There is something wrong with the units.
The exponent should be dimensionless.
From wiki, it appears the correct formula is $P=P_0 e^{-\frac{m_g g h}{kT}}$.
That is, with an extra $g= 9.81 \,\text{m/s}^2$ in it. Then the exponent will indeed be dimensionless.
Btw, the unit of the $29\,\text g$ should actually be $29\,\text g\cdot \text{mol}^{-1}$. Consequently, the $\text{mol}^{-1}$ cancels against the one in the denominator as it should.
We should find a ratio that is lower than 1 since the pressure high up is lower than a pressure deep down.
If it is close to 1, then the pressure is more or less that same at all altitudes in this range, and we can breathe normally at both altitudes.
If it is close to 0, then we won't be able to breathe normally at both altitudes. And water will boil at a noticeably different temperature.
2) Custer Peak is about 561.6 m above South Dakota.
Yep. Correct.
Yep. Correct.
Hi,
Thanks for helping me in finding out the correct ratio of barometric pressure.. I wrongly omitted $g=9.81m/s^2$ in the barometric formula.
I got the answer dimensionless which is 0.8721. That means if there is 1.25 bar barometric pressure at the bottom of Homestake gold mine, then Custer Peak will have 1.09 bar barometric pressure.
There is a mistake in my computaion of ratio. Correct ratio is as above.
The formula with the substitution looks a bit off...
  1. The unit gram ($\text{g}$) should be converted to the SI unit $\text{kg}$ as part of the calculation.
  2. The gravitational acceleration $g=9.81\,\text{m/s}^2$ (not to be confused with the gram unit $\text{g}$) seems to be missing.
Note that I'm using an upright font for the unit gram and an italic font for the quantity of the gravitational acceleration to distinguish them. It's the recommended typography for SI units.
Either way, I also get $0.71$ so it seems that you did do the correct calculation.
FAQ: Computation of the ratio of barometric pressure
What is the purpose of computing the ratio of barometric pressure?
The ratio of barometric pressure, also known as the pressure altitude ratio, is used to determine the altitude of an object or location. This can be useful for a variety of applications, such as measuring atmospheric conditions or determining the height of a mountain.
How is the ratio of barometric pressure calculated?
The ratio of barometric pressure is calculated by dividing the current barometric pressure by the standard barometric pressure at sea level. The standard pressure at sea level is typically around 1013.25 millibars or 29.92 inches of mercury.
What units are used to measure barometric pressure?
Barometric pressure is typically measured in units of millibars (mb) or inches of mercury (inHg). However, other units such as pascals (Pa) or kilopascals (kPa) may also be used.
How does temperature affect the ratio of barometric pressure?
Temperature can affect the ratio of barometric pressure because it can change the density of the air. As temperature increases, the air becomes less dense and the pressure decreases. This means that the ratio of barometric pressure will also decrease, resulting in a higher altitude calculation.
What are some common uses for the ratio of barometric pressure?
The ratio of barometric pressure is commonly used in aviation, meteorology, and outdoor activities such as hiking and mountain climbing. It can also be used in weather forecasting and in the study of atmospheric conditions.
