MHB Compute Limit: \sqrt[n]{1+x^n}^n
  • Thread starter Thread starter MarkFL
    Limit
The limit to compute is $$\lim_{n\to\infty}\left(\sqrt[n]{\int_0^1 \left(1+x^n\right)^n\,dx}\right),$$ which is shown to converge to 2. The integral is bounded above by $2^n$ and below by a function that approaches 2 as n increases. The argument involves analyzing the behavior of the function $f_n(x) = 1 + x^n$ and the intervals where it exceeds certain values. A critical point is the limit of the expression $$\left(1 - \left(1-\frac{1}{n}\right)^{1/n}\right)^{1/n},$$ which approaches 1 as n approaches infinity. The conclusion is that the limit is indeed 2, confirming the validity of the derived bounds.
MarkFL
MHB
Compute the following limit:
$$\lim_{n\to\infty}\left(\sqrt[n]{\int_0^1 \left(1+x^n\right)^n\,dx}\right)$$
Mathematics news on Phys.org
Saw this on another site. Is there a bounty out for it xD.
[sp]For $0\leqslant x\leqslant1$, $1+x^n \leqslant2$. Therefore $$\int_0^1 \left(1+x^n\right)^n\,dx \leqslant 2^n$$ and hence $$\sqrt[n]{\int_0^1 \left(1+x^n\right)^n\,dx} \leqslant2.$$
Now choose $n$ and let $x_0 = \left(1-\frac1n \right)^{1/n}$. The function $\left(1+x^n\right)^n$ is increasing on $[0,1]$, so on the interval $[x_0,1]$ it is greater than or equal to $\left(1+x_0^n\right)^n = \left(2 - \frac1n\right)^n$. Therefore $$\int_0^1 \left(1+x^n\right)^n\,dx \geqslant \int_{x_0}^1 \left(1+x^n\right)^n\,dx \geqslant \int_{x_0}^1 \left(2 - \tfrac1n\right)^ndx = \left(1 - \left(1-\tfrac1n\right)^{1/n}\right) \left(2 - \tfrac1n\right)^n.$$ Thus $$2 \geqslant \sqrt[n]{\int_0^1 \left(1+x^n\right)^n\,dx} \geqslant \left(1 - \left(1-\tfrac1n\right)^{1/n}\right)^{1/n} \left(2 - \tfrac1n\right).$$
The aim now is to show that $$\lim_{n\to\infty} \left(1 - \left(1-\tfrac1n\right)^{1/n}\right)^{1/n} = 1.$$ That will show that $$\sqrt[n]{\int_0^1 \left(1+x^n\right)^n\,dx} $$ can be made as close as we wish to $2$ for all sufficiently large $n$, and hence $$\lim_{n\to\infty}\sqrt[n]{\int_0^1 \left(1+x^n\right)^n\,dx} = 2.$$
Start with the estimates $-2x <\ln(1-x) < -x$ and $\frac x2 < 1-e^{-x} < x$, valid for $0<x<\frac12.$ Put $x=\frac1n$ in the first inequality to get $$-\frac2n < \ln\left(1-\frac1n\right) < -\frac1n$$ for all $n\geqslant 2.$ Then $$e^{-2/n^2} < \left(1-\tfrac1n\right)^{1/n} < e^{-1/n^2},$$ and $$\frac2{n^2} > 1 - e^{-2/n^2} > 1 - \left(1-\tfrac1n\right)^{1/n} > 1 - e^{-1/n^2} > \frac1{2n^2}.$$ Therefore $$\left(\frac2{n^2}\right)^{1/n} > \left(1 - \left(1-\tfrac1n\right)^{1/n}\right)^{1/n} > \left(\frac1{2n^2}\right)^{1/n}$$, and the result follows from the fact that $$\lim_{n\to\infty}\left(\frac1n\right)^{1/n} = 1.$$
[/sp]
[/sp]
Nicely done, Chris! (Yes)
This is the solution I found elsewhere:
We are given to evaluate:
Let $$f(x)=1+x^n$$ and observe that for all $$x\in\left[0,1\right]$$ and $$n\in\mathbb{N}$$, we have $$0<f(x)$$.
Now, let's define:
$$M\equiv\sup_{x \in [0,1]} f(x)$$
Observe then that we must have:
$$\left(\int_0^1 f(x)^n\,dx\right)^{\frac{1}{n}} \le \left(\int_0^1 M^n\,dx\right)^{\frac{1}{n}}= M$$
Thus, we conclude:
$$\limsup_{n\to\infty}\left(\left(\int_0^1 f(x)^n\,dx\right)^{\frac{1}{n}}\right)\le M$$
Now let $\alpha$ be any non-negative real number strictly less than $M$. By definition, there must be some $x_0\in[0,1]$ such that $f\left(x_0\right)=M$. By continuity of $f$, we can find an interval $(c,d) \subset [0,1]$ such that $f(x)>\alpha$ for all $x\in(c,d)$. Then, for every $n$, we have:
$$\left(\int_0^1 f(x)^n\,dx\right)^{\frac{1}{n}}\ge\left(\int_c^d f(x)^n\,dx\right)^{\frac{1}{n}}\ge\left(\int_c^d \alpha^n\,dx\right)^{\frac{1}{n}}=\alpha(d-c)^{\frac{1}{n}}$$
Taking limits, there results:
$$\liminf_{n\to\infty}\left(\left(\int_0^1 f(x)^n\,dx\right)^{\frac{1}{n}}\right)\ge\lim_{n\to\infty}\left(\alpha(d-c)^{\frac{1}{n}}\right)=\alpha$$
Given that $\alpha$ is an arbitrary real number strictly less than $M$, the above implies:
$$\liminf_{n\to\infty}\left(\left(\int_0^1 f(x)^n\,dx\right)^{\frac{1}{n}}\right)\ge M$$
Thus, we have:
$$M\le\liminf_{n\to\infty}\left(\left(\int_0^1 f(x)^n\,dx\right)^{\frac{1}{n}}\right)\le\limsup_{n\to\infty}\left(\left(\int_0^1 f(x)^n\,dx\right)^{\frac{1}{n}}\right)\le M$$
And this implies:
$$\lim_{n\to\infty}\left(\left(\int_0^1 f(x)^n\,dx\right)^{\frac{1}{n}}\right)=M$$
For $f(x)=1+x^n$, we find $M=2$.
Now, let's define:
Thus, we conclude:
Thus, we have:
And this implies:
[sp]That argument does not work, because the function $f(x) = 1 + x^n$ depends on $n$. In fact, there is a whole sequence of functions $f_n(x) = 1 + x^n$. As it happens, they all have the same supremum $M = 2$. Given $\alpha<M$, each of these functions will have an interval $(c,d)$ on which $f_n(x)>\alpha$. But that interval will depend on $n$, so it should really be written $(c_n,d_n)$. As $n$ increases, that interval may well get shorter and shorter, and no reason is given to justify the conclusion that $(d_n - c_n)^{1/n} \to 1$ as $n\to\infty$. A more delicate argument is needed for that.
In my proof, I used $(x_0,1)$ as the interval on which $f_n(x) > 2 - \frac1n$. There too, I was using a possibly misleading notation, because $x_0$ also depends on $n$. I should probably have called it $x_n$. But my proof takes account of the fact that the interval $(x_n,1)$ decreases as $n$ increases.
So I think that my solution is right and the other one is wrong. :p
[/sp]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
