Compute the circulation of F along C
  • MHB
  • Thread starter Uniman
  • Tags
    Circulation
In summary, Uniman is new to the forum and is seeking help from experts on a multivariable calculus question involving finding the downwards flux of a vector field. He has asked for clarification and guidance on using Latex for future posts.
Uniman
Hi,
This is my first post. So if I made any mistakes that is the way I asked the questions, kindly let me know.
The work done so far
Circulation:
C {0,0,1} to {1, pi,1}
C eq: {y=pi*x, z=1}
dr={dx, pi*dx, 0}
F={cos(y/z), -x/z*sin(y/z),xy/z^2*sin(y/z)}
F.dr = -dx [dot product and simplified]
Integral[F.dr]{0 t01} = -1
Am I in right track?
Mathematics news on Phys.org
Welcome to MHB, Uniman! For future reference and searches later, I believe you should type out the question using LaTeX. It will make it easier for all of us to read and discuss your approach. :D
Last but not least, this looks like a multivariable calculus question. Perhaps it belongs in the Calculus sub-forum. (Nod)
Adjust your http://www.mathhelpboards.com/f16/compute-downwards-flux-f-2170/ accordingly! ;)
Latex? Is it a software available online...Sorry I post these two threads in the wrong section. Am I able to move this thread...
Waiting for the experts to check my answers. By the way this forum looks great...
Hi Uniman,
Welcome to MHB! :)
You can read up on Latex here but in short it's a way to output nice looking equations which are difficult to write otherwise.
For example \frac{x^2+3x-2}{\sqrt{2x^2-11}} outputs \(\displaystyle \frac{x^2+3x-2}{\sqrt{2x^2-11}}\). We have a forum dedicated to Latex which you can find http://www.mathhelpboards.com/f26/.
I am not sure where this thread belongs so I'll ask one of the moderators to move it to a new place if needed. Sorry I can't help you myself but rest assured that you should be getting some help soon.
Jameson
Hi there,
Based on the information you provided, it seems like you are on the right track in calculating the circulation of F along C. The integral you have set up is correct and you have correctly used the dot product to simplify the calculation. However, it is always a good idea to double check your work and make sure all the units and dimensions match up. Also, it would be helpful to provide more context and background information on what you are trying to solve and what the values of t and t0 represent. Overall, keep up the good work and don't hesitate to reach out for further clarification or assistance. Best of luck!
FAQ: Compute the circulation of F along C
What is the definition of circulation of a vector field?
The circulation of a vector field F along a closed curve C is the line integral of F along C, which represents the total flow of the vector field around the closed curve.
How is the circulation of a vector field calculated?
The circulation of a vector field can be calculated by evaluating the line integral of the vector field along the closed curve. This involves breaking down the curve into small segments, calculating the dot product between the vector field and the tangent vector of each segment, and adding up all the resulting values.
What is the physical significance of circulation in fluid mechanics?
In fluid mechanics, the circulation of a vector field represents the amount of fluid flow around a closed path. It can also indicate the presence of vortices or swirling motion in the fluid.
Can the circulation of a vector field be negative?
Yes, the circulation of a vector field can be negative. This indicates that the vector field is flowing in the opposite direction of the closed curve, resulting in a counter-clockwise circulation.
How is the circulation of a vector field related to the curl of the field?
The circulation of a vector field is directly related to the curl of the field. The curl of a vector field at a point represents the tendency of the field to rotate around that point. Therefore, a non-zero curl at a point indicates the presence of circulation around that point.
