Compute the polarization state
Therefore, the overall polarization state of the output light is a linear polarization along the x-axis, with an angle of 0 degrees relative to the x-axis. In summary, the polarization state of the output light in both scenarios is a linear polarization along the x-axis, but with different angles relative to the x-axis.
brad sue
281
compute the polarization state for the following scenarios:
The input light is randomly propagated in the z direction (figure attached) and then passes through a linear polarizer oriented 45° from either the x or y axis.
1-After the linear polarizer, the light passes through a beam splitter, and quarter wave plate with the fast axis aligned with the x axis, and is reflected back by a mirror (M) (See attached figure).
The output is in the –x direction as depicted in the figure.
2-Similar to (1), but the beam splitter is now replaced with a polarization beam splitter.
Please on my proposed solution can you help me to see what is wrong and help me especially with the angles of polarization?
thank you
polarization state in term of angle:
1- the light is polarized at 45 degrees > after the beam splitter, the intensity is divided by 2 but the angle of polarization stays the same > after the quarter wave plate, the linear light become a polarized circular light (clockwise or counterclockwise??) > After the mirror the circular light is reversed > when the circular light pass through the quarter wave plane, it becomes linear again but with what angle? > light comes out
For question 2- I don't see how it will change from the previous question. Also, i don't understand the use of a polarized beam splitter on polarized light?
Thank you
for your help.1- The input light is randomly propagated in the z direction and then passes through a linear polarizer oriented 45° from either the x or y axis. After the linear polarizer, the light passes through a beam splitter, and quarter wave plate with the fast axis aligned with the x axis, and is reflected back by a mirror (M) (See attached figure). The output is in the –x direction as depicted in the figure.The polarization state of the output light can be described as a linear polarization along the x-axis, with an angle of -45 degrees (relative to the x-axis). This is because the light first passes through a linear polarizer oriented at 45 degrees relative to the x-axis, which imparts a linear polarization along the x-axis. Then, it passes through a quarter wave plate, which transforms the linear polarization into a circular polarization. Finally, it reflects off the mirror and passes through the quarter wave plate again, transforming the circular polarization back into a linear polarization along the x-axis, but with an angle of -45 degrees relative to the x-axis. 2- Similar to (1), but the beam splitter is now replaced with a polarization beam splitter. The polarization state of the output light can be described as a linear polarization along the x-axis, with an angle of 0 degrees (relative to the x-axis). This is because the light first passes through a linear polarizer oriented at 45 degrees relative to the x-axis, which imparts a linear polarization along the x-axis. Then, it passes through a quarter wave plate, which transforms the linear polarization into a circular polarization. Finally, it reflects off the polarization beam splitter, which splits the circularly polarized light into two components: one with a linear polarization along the x-axis, and one with a linear polarization along the y-axis. Since the output is in the -x direction, the light that is transmitted through the polarization beam splitter has a linear polarization along the x-axis, with an angle of 0 degrees relative to the x-axis.
FAQ: Compute the polarization state
What is polarization state?
Polarization state refers to the orientation of the electric field of a light wave. It describes the direction and amplitude of the electric field vector as the wave travels through space.
Why is it important to compute the polarization state?
Computing the polarization state is important in understanding how light behaves and interacts with different materials. It is also crucial in many applications such as optical communication, polarized imaging, and material analysis.
How is the polarization state computed?
The polarization state can be computed by measuring the electric field vector of a light wave at different points in space and time. This can be done using specialized instruments such as polarizers, waveplates, and polarimeters.
What are the different types of polarization state?
The three main types of polarization state are linear, circular, and elliptical. Linear polarization refers to when the electric field oscillates in a single plane. Circular polarization is when the electric field rotates continuously in one direction. Elliptical polarization is a combination of linear and circular polarization.
How does the polarization state affect light's interaction with matter?
The polarization state of light can affect its absorption, reflection, and scattering properties when interacting with matter. Different materials may interact differently with different polarization states, making it an important factor to consider in material analysis and design.
